Uh Kenny, is that tire on backwards? (Rotation direction… the one in the shadow I didn’t notice, like a snake…). Haven’t seen them with arrows in both directions, what is up with that?
I haven’t either, and I thought it was on backwards too because of the tread but it’s on there correctly. According to Avon, it can be used as a front or rear tire.
https://www.avontyres.com/en-us/tyres/roadrider-mkii
Funny - I just refreshed some Lesters and had Avons to put on. Started to try to fit the tires myself, decided Nah and took them to a local shop. Front was just the bare wheel w/no speedo drive or brake disc on yet and I had to let them know which side was which, so I took a quick glance and told them what was what and, of course, muffed it. Got home and took a look at wheels on the bike and realized I had said it backwards - then got the call from them that the tires were on. I went and picked them up and they hadn't looked at the rotation arrows on the front tire and put it on the way that looks right based on the tread - which is opposite the tire rotation arrows. So, tire ended up being on the right way. Sometimes it pays to be dumb lucky.
That’s hilarious and some nice luck!
Today I got the front brakes all finished up and filled with fluid. Since I got that upper line installed, I was finally able to get the new front end put together as well.
LED headlight
New aftermarket turn signals
New headlight brackets and ring
Joker collars holding up the new OEM fork gaiters
I have parts from Marcel to rebuild the gauges- faces, glass, rubber seals, and the black metal covers, and new crimp rings if needed. I have an idea on how to get them put back on. I’ll definitely post that process.
