Author Topic: 76 CB550F - Oct 2021 - Rear tail light and rebuilding gauges  (Read 42240 times)
Offline KennyRedman
  • 1976 CB550F, Indiana
Re: 76 CB550F - Oct 2021 - Rear tail light and rebuilding gauges
« Reply #125 on: November 17, 2021, 12:36:18 PM »
Today I received the new brake line and it fits perfectly. That’s a 10” line with a 45° top on 400F bars for reference.
Also, is there supposed to be anything in that rectangle on the ignition? Looks like it would be a decal or something.
« Last Edit: November 17, 2021, 02:20:01 PM by KennyRedman »
« Reply #126 on: November 18, 2021, 06:51:09 AM »
That brake line looks great, where did you end up getting it?
No decal on the ignition switch, that would not be visible with the OEM plastic surround installed
Offline KennyRedman
« Reply #127 on: November 18, 2021, 07:22:02 AM »
I ordered it from Apex Brakes- very well built and quick turnaround.
« Reply #128 on: November 18, 2021, 07:29:39 AM »
Good to hear, I hadnt ordered from them in quite awhile...
Offline KennyRedman
« Reply #129 on: November 18, 2021, 07:39:16 AM »
I looked around all over the place, and this was the only one I could find where I could customize it and order it online. Some others had great customization tools, but then they’d send a quote the next day or so and then you’d have to order. Any other place you’d recommend or like?
Offline Gman
« Reply #130 on: November 18, 2021, 05:40:17 PM »
Uh Kenny, is that tire on backwards? (Rotation direction… the one in the shadow I didn’t notice, like a snake…). Haven’t seen them with arrows in both directions, what is up with that?
I haven’t either, and I thought it was on backwards too because of the tread but it’s on there correctly. According to Avon, it can be used as a front or rear tire.
https://www.avontyres.com/en-us/tyres/roadrider-mkii
Funny - I just refreshed some Lesters and had Avons to put on.  Started to try to fit the tires myself, decided Nah and took them to a local shop.  Front was just the bare wheel w/no speedo drive or brake disc on yet and I had to let them know which side was which, so I took a quick glance and told them what was what and, of course, muffed it.  Got home and took a look at wheels on the bike and realized I had said it backwards - then got the call from them that the tires were on.  I went and picked them up and they hadn't looked at the rotation arrows on the front tire and put it on the way that looks right based on the tread - which is opposite the tire rotation arrows.  So, tire ended up being on the right way.  Sometimes it pays to be dumb lucky.  :)
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline KennyRedman
« Reply #131 on: November 20, 2021, 02:02:54 PM »
That’s hilarious and some nice luck!
Today I got the front brakes all finished up and filled with fluid. Since I got that upper line installed, I was finally able to get the new front end put together as well.
LED headlight
New aftermarket turn signals
New headlight brackets and ring
Joker collars holding up the new OEM fork gaiters
I have parts from Marcel to rebuild the gauges- faces, glass, rubber seals, and the black metal covers, and new crimp rings if needed. I have an idea on how to get them put back on. I’ll definitely post that process.
« Last Edit: November 21, 2021, 07:51:27 AM by KennyRedman »
Offline Gman
« Reply #132 on: November 21, 2021, 05:51:31 PM »
Looking good!!!
'76 CB550K
Offline KennyRedman
« Reply #133 on: November 21, 2021, 07:03:27 PM »
Looking good!!!
Thanks a lot. I’m not quite sold in the brake light. I’d like something a little bigger that will fill the space in a bit more.
Offline Alan F.
« Reply #134 on: November 21, 2021, 07:26:12 PM »
I'd suggest that you have someone record some video of you out on the bike. Perhaps your impression of the light will change?
Offline KennyRedman
« Reply #135 on: November 21, 2021, 07:42:54 PM »
That’s a good idea. I’m thinking more aesthetics- it almost seems too small. I don’t know, maybe I’m just overthinking it.
« Reply #136 on: November 22, 2021, 08:28:28 AM »
Seems I always hear that the [OEM] tail light is too big! Bike is looking good...
Offline KennyRedman
« Reply #137 on: November 22, 2021, 08:39:25 AM »
Thanks. It’s friggin huge! Lol. I have what I think is a repro light for a 350, and it would be the perfect size and keep the CB feel better than the one I put on. I’d just have to figure out a mounting system since I shortened the fender about 6”. Wonder if I found the 350 bracket if I could tuck it up under a bit. Might as well try.
« Last Edit: November 22, 2021, 08:41:21 AM by KennyRedman »
« Reply #138 on: November 22, 2021, 08:44:25 AM »
the 1971 CB750 tail light is about the right size, in '72 they went to the larger size.
Offline KennyRedman
« Reply #139 on: November 22, 2021, 09:05:25 AM »
That looks perfect. Thanks Steve!
Offline Kelly E
  • Geriatric Hooligan
« Reply #140 on: November 22, 2021, 11:04:24 AM »
I used a small cat eye taillight on my 74' 550. I made a bracket to use the factory bolt holes in the fender.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #141 on: November 22, 2021, 11:30:44 AM »
Honda S90 has a minature version of the style on the other CBs...
Offline KennyRedman
« Reply #142 on: November 22, 2021, 12:06:05 PM »
That’s pretty cool. How did you make your bracket?
Offline KennyRedman
« Reply #143 on: November 22, 2021, 04:04:56 PM »
I’ll check that out too!
Offline Kelly E
« Reply #144 on: November 22, 2021, 06:31:17 PM »
I made a pattern from chipboard to figure it out then I made it from sheet metal.
1983 Honda CB 1100F
Offline Alan F.
« Reply #145 on: November 24, 2021, 05:08:52 PM »
Maybe the taillight mount from a 78K model will fit the bill? It'll fit all of the 750 taillight styles.
Offline KennyRedman
« Reply #146 on: November 26, 2021, 07:28:28 AM »
That would be a good option too. The only problem is the angle of the base- I shortened the fender, so the area where it’s mounted is flatter and the angle would make the brake light angle upwards.
Offline Alan F.
« Reply #147 on: November 26, 2021, 08:13:35 PM »
Maybe add some rubber spacers to correct the angle?
Offline KennyRedman
« Reply #148 on: November 28, 2021, 12:14:44 PM »
I found the perfect bracket on eBay to hold a 350 tail light on my setup.
I also am going to rebuild my gauges. I have all the parts from Marcel, except I ordered the wrong gauges because I think I ended up using the ones from the 77K donor. So I have those coming in both dark and light green and I’ll see which looks best.
« Last Edit: November 28, 2021, 12:17:22 PM by KennyRedman »
« Reply #149 on: November 28, 2021, 01:41:31 PM »
Tail light bracket looks awesome.  What bike was it listed for?
