Author Topic: 72 cb750 Project,GSXR front end- Version 2.0 coming  (Read 56229 times)
Offline jojo
Re: 72 cb750 Project,GSXR front end- Oil leak, Warped Clutch cover
« Reply #200 on: March 31, 2014, 10:01:32 AM »
If it's only sputtering in mid range I would suspect air:fuel issue as opposed to electrical. Electrical would usually either be a problem all the time or it would come on randomly/intermittently.
Is it idling better after the sync?
IW
Idles way better after the sync, the electrical checked out and also the timing advance mark "F" moves as it should. I believe the new pods may be the culprit. looks like i will need to rejett my carbs to match the new pods. already replaced my plugs and no change in the issues. Definitely sounds like its starving for fuel.
Offline jojo
« Reply #201 on: April 08, 2014, 11:50:52 AM »
fixed a small air leak but i tested the timing advancer with the light and it wasnt working correctly. Gonna do a full rebuild on the carbs, resync, then fix the advancer and voila! should be done finally.
Offline iron_worker
« Reply #202 on: April 08, 2014, 02:26:08 PM »
IW
Oh .... pods....
Yep, there's your problem! lol
IW
Offline jojo
Re: 72 cb750 Project,GSXR front end- Almost Finished...Finally
« Reply #203 on: April 09, 2014, 07:14:50 AM »
Yep, they were already on there when i first got it so i had to replace them bc the seals on them were falling apart and they were dirty as can be  >:( :(
Offline jojo
« Reply #204 on: April 21, 2014, 03:05:59 PM »
still fighting jetting problems, but things have halted for now as on my way to the revival show some lady decided to jump out on the intersection and forced me to put my bike down(not my honda) and managed to bang myself up pretty good and break my left elbow. wont be able to work much for the next few weeks but at least im ok!
« Reply #205 on: April 21, 2014, 03:52:52 PM »
Ouch!!  That sounds really really painful.  She's lucky you didn't ride over her like the Toecutter gang in Mad Max.  I'd make her pay for your hospital bill and bike repair.
Offline Seeparkfly
Re: 72 cb750 Project,GSXR Front end--almost there!
« Reply #206 on: April 22, 2014, 01:49:50 PM »
Couple of questions for yall.
1.) cb550 swing arm is a bit longer than the 750 so my chain is now too short. What is the better solution, new chain(current chain isnt but a few months old) or smaller rear sprocket?
2. anyone make brake lines? the current line for my second caliper is too short (old wheel was smaller, 17 inch vs 19 inch) and now it rubs against the wheel.
3.) carbs seem to be sticking, not sure if its the cable or a bad return spring will be loading a video soon.
Thanks again everyone for your help, im almost there.  :o 8) ;D
Hey JoJo,
Sweet bike man. I'm glad I found your thread bc I've been thinking about a longer swingarm. After seeing photos for comparison I'm in.  Did you get a longer chain? If so what length? I have a 76 CB750 F and hoping the swap is the same as yours.
« Last Edit: April 22, 2014, 02:20:56 PM by Granuc »
« Reply #207 on: April 22, 2014, 01:55:07 PM »
Hey JoJo,
[/quote]
(1) Buy a new chain.  A new sprocket will affect the gearing.
(2) Slingshot (member here on the forum) makes steel braided brake lines at an affordable price (discount for forum members, too).
Offline Seeparkfly
« Reply #208 on: April 22, 2014, 02:22:50 PM »
Hey JoJo,
[/quote]
Thanks for the info. Do you know the length of chain I will need?
« Reply #209 on: April 22, 2014, 02:45:44 PM »
Hey JoJo,
[/quote]
No.  I do not have the measurement.  But it's my understanding that the 550 swingarm you are using is approximately 2" longer than the stock 750 swingarm.  If so, you would need a chain 4" longer than a stock 750 chain.
Offline Seeparkfly
Re: 72 cb750 Engine Rebuild/ GSXR Front End--Houston we have a roller!
« Reply #210 on: April 22, 2014, 06:53:35 PM »
i also decided against welding the holes on the rear of the frame after im chopped it up a bit. I think in the future i may weld a loop in there so i used welding plugs to seal them up. Fit right in there super snug and used some sealant to keep the moisture out.
Uploaded with ImageShack.com
Need to do the same for my bike, where did you find the plugs??
Offline riverfever
« Reply #211 on: April 22, 2014, 07:36:11 PM »
Love the build. Any more pics of the seat mounting?
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #212 on: April 22, 2014, 10:09:08 PM »
I want to see someone put bar end turn signals in there.
www.CognitoMoto.com
www.CognitoMoto.com
GSX-R Fork Conversions/Laced Hubs and Cafe Racer Parts
www.facebook.com/cognitomoto
« Reply #213 on: April 22, 2014, 10:28:35 PM »
www.CognitoMoto.com
Great idea.  Motogadget makes some pricey but cool looking ones!
Offline Seeparkfly
« Reply #214 on: April 23, 2014, 12:37:37 PM »
Buy a 110 link chain, then adjust to fit. Remember to fit it based upon your axle being farthest forward in the swing arm. Then take slack out by moving axle rear ward. Pretty simple...
Got it. Thank you.
Offline jojo
« Reply #215 on: April 30, 2014, 01:50:23 PM »
Hey JoJo,
1. the 550 swing arm is a bit longer, close to 2"(mine was off a 78). I too had a newer chain but i opted to change it out for a longer one instead of messing with the sprockets.
Offline jojo
« Reply #216 on: April 30, 2014, 01:53:44 PM »
those are just welding plugs i found on ebay to match the hole size of the frame
Offline jojo
« Reply #217 on: April 30, 2014, 01:54:28 PM »
I will take some more and post them up as soon as i have a chance.
Offline jojo
« Reply #218 on: April 30, 2014, 01:56:37 PM »
www.CognitoMoto.com
Devin- i had something like that in mind since my ducati tail light doesnt leav much clearance and i already busted one when i hit a bump and the tire smashed the plastic cover. I bought a new one since i really liked the look but still having the same issue. May go to a smaller tail light without integrated turns and use bar ends so i dont have to do any fabrication. Hard to do that with one arm :D
Offline jojo
« Reply #219 on: April 30, 2014, 02:01:10 PM »
probably use something like this. will be uploading some pics of it soon. Also finally sorted out the rev issue. Turned out to be jetting issues now that i had them synced and mounted the new pods. It was running WAY too rich so i stepped it down to the original 105's. Previous owner had 125's on there so it wasnt running very well.
http://www.surfsidemoto.com/store/product/KAS20400452.html?gclid=CIa3tfiMib4CFa_m7Aod53YA3A
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #220 on: May 15, 2014, 10:40:36 AM »
How are you healing up?
www.CognitoMoto.com
www.CognitoMoto.com
Offline Ford40
« Reply #221 on: May 16, 2014, 07:58:13 AM »
You could try something like this, I think it would be a cleaner look.
http://store.revivalcycles.com/collections/lighting-1/products/led-light
Offline jojo
« Reply #222 on: May 23, 2014, 07:19:57 AM »
ive been looking into something like that. i also found a different tail light so gonna have to order everything up and get it switched out. in the mean time im riding dirty with my tail light strapped to my seat with a bungy cord haha
« Reply #223 on: August 16, 2014, 06:46:31 PM »
Update?
Offline jojo
« Reply #224 on: May 30, 2019, 01:53:41 PM »
Its been quite a long time since I posted on here. Update: the bike is, unfortunately, sitting in storage (after 3 years of riding the finished build) as I moved for fork and only recently made it back home. I will slowly start a version 2.0 and now that have some more time work on the things I wanted to change once I finished the build the first time.
