Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 284984 times)
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- BUILD RESUMED
« Reply #650 on: September 03, 2014, 11:48:24 PM »
It was marked R2, lift is. 285, and. 301..... Not sure of year..
Offline edwardmorris
  • Youngish
« Reply #651 on: September 05, 2014, 07:06:46 PM »
Its pre K3! so its gonna go great with the head getting reworked by JMR  8)
  • Youngish
« Reply #652 on: September 05, 2014, 07:10:14 PM »
Some progress this evening, followed the caveman approach to installing bearing races, won't describe here for that reason. Did the stacked height measurement, will be going with the thin spacer for the lower.
  • Youngish
« Reply #653 on: September 05, 2014, 07:18:50 PM »
Did some digging, asking around etc. and decided to do one wrap with rubber tape (instead of electrical tape that disintegrates over time). The rim band looked pathetic on its own, hopefully the tape will provide a better seal/seat. Had some excellent pointers from Jerry h on how to mount the tires, so dove right in and quickly realized I'm still not physically well enough to do it. So called in a favor, had my local autoshop mount the tires in no time. Wheels are ready, just waiting on some sanding and polishing supplies to arrive to complete the last two pieces on the rear wheel.
Offline goldarrow
  • one day, i'll be an
« Reply #654 on: September 05, 2014, 08:04:30 PM »
Some sacrifices were made
CB550 K0
  • Youngish
« Reply #655 on: September 05, 2014, 08:44:58 PM »
Thanks gold dude! You're a life saver, PM incoming.
Offline goldarrow
« Reply #656 on: September 05, 2014, 08:47:23 PM »
And those screws are more rare than 8 bolts, be costly! ;)
« Last Edit: September 06, 2014, 08:49:12 AM by goldarrow »
CB550 K0
  • Youngish
« Reply #657 on: September 06, 2014, 05:14:47 PM »
Another piece done and wrapped up. One of the tricky ones. El cheapo kit from e-bay, no match for a wheel, but adequate for one of the least visible parts on the bike. Pic in somewhat better lighting.
  • Youngish
« Reply #658 on: September 06, 2014, 08:27:37 PM »
Sprayed the undersides of the fenders with a $2 chrome rattle can  ::) The nice rubberized undercoating just wasn't feeling right :P Steering stem got a nice finish with the VHT caliper paint.
  • Youngish
« Reply #659 on: September 07, 2014, 05:23:20 PM »
So this is done, just about have all the pieces to get a roller going. Head may be a few days before it makes its way back so I might just assemble the top end in-frame.
  • Youngish
« Reply #660 on: September 08, 2014, 05:06:09 PM »
Cooling fin inserts made by Joe/FrankenFrankestuff, or as I like to call them, Franken Finserts arrived today!
Offline Tews19
  • I am no
« Reply #661 on: September 08, 2014, 05:08:11 PM »
Rafi are you selling Molly pills? ?????
1970 Honda CB750 survivor.
« Reply #662 on: September 08, 2014, 05:39:12 PM »
Yeah, he started making those shortly after I'd dished out big bucks for a set of OEMs!   :(
  • Youngish
« Reply #663 on: September 08, 2014, 08:38:43 PM »
That's the thread that led me to them ;) Gotta love the search function  ;D
  • Youngish
« Reply #664 on: September 08, 2014, 08:41:14 PM »
Love, Hate or don't care input on these two psychedelic colors please people, which set do you guys think would look better? Yellow on the left is more vibrant, Clear/Blue on the right is less so, but close to the carb bodies' iridescent finish.
« Reply #665 on: September 08, 2014, 09:29:50 PM »
Clear/Blue
« Reply #666 on: September 10, 2014, 01:26:41 AM »
Clear/Blue
+1 Rafi, looks much nicer in my opinion. You're doing great work mate, give yourself a pat on the back. What tires are you using? Cheers, Terry. ;D
  • Youngish
« Reply #667 on: September 10, 2014, 07:55:39 AM »
Terry!  ;D ;D Its decided then, uncle Tez says blue, so it shall be  :P The yellow set will go on my spare set and eventually on sale (project treasury is behind now :o)
I went with Conti Twins Terry, for the sake of a more close to stock look, and this bike will be a straight line rider (at least while its still all shiny ;)).
Minor set back yesterday, was putting the gauges back together and noticed that the gauge lenses have scratches that were hidden behind the road film? Blatantly visible after cleaning :( To make things worse, I'm regretting not buying a set of crimp rings when I bought the new faces from LeCram. I had the old ones replated with the rest of the chrome parts, waste of time. As soon as I started crimping them, the chrome scratched up and fell back into the housing somehow ugh. Ordered new rings (DAMN these are pricey!) last night, will have to get back to the gauges later.
  • Youngish
« Reply #668 on: September 10, 2014, 10:16:38 PM »
Follow up question. Which set should I go with?
Pic 1 is the 657As that were on the bike but with franken parts. I now have all the correct parts (ALMOST) from James/harisuluv and Bill Benton to get that set together and workable. The bodies are nice and clean on the outside, some corrosion in the bowl area. Correct for later K2s.
Pic 2 is the 7As set I bought form Bill, had a few franken pieces but pretty much complete now (thanks again, James). The bowl areas are immaculate, but bodies #1 and #4, the two most visible ones have corrosion on them on the outsides :( This is actually the correct set for the super early K2s (mine).
  • Youngish
« Reply #669 on: September 10, 2014, 10:20:00 PM »
Had very little time today, so tackled the last two bearing that needed removal. Clutch lifter plate and the counter shaft end cover. The clutch lifter bearing simply fell out, no heat or effort of any kind. Is this good or bad? The CS cover, I just toasted it with a heat gun raised off the floor and it fell out. These will be getting new SKFs.
  • Youngish
« Reply #670 on: September 12, 2014, 10:09:52 AM »
No input on the carb bodies  :(?
Offline jerry h
« Reply #671 on: September 12, 2014, 04:11:35 PM »
How early is your bike again?   Mine has 657A's  (2/72  2022907 vin)
Personally,  I'd go with which ever set is in the best condition overall to give you a good running bike.  In reality, when the bike is all back together, you only see a fraction of the carbs anyway.
« Reply #672 on: September 12, 2014, 05:25:09 PM »
+1 Rafi, and don't think it won't be original if you do, Honda tended to use whatever they had in their parts bins when they made these things, so there are lots of bikes from one model with parts from another model straight from the factory.
For example, Marcel (LeCram) bought a K0 that came from the factory with K1 speedo and tach, because by late in the K0 model run, they'd run out of K0 gauges.
And there's nothing wrong with those Conti tires mate, I put them on my bikes back in the day, and they crapped all over the factory Bridgestone's of the era, they were terrible! Good work mate, keep going, I'm impressed! Cheers, Terry. ;D
  • Youngish
« Reply #673 on: September 12, 2014, 05:37:43 PM »
Thanks Jerry and Terry, I'll go with the 7As. Correct for my bike, and absolutely no corrosion whatsoever in the bowl area/jet posts etc. The corrosion on the outside, I'll live with it. Last bits of original Keihin's came in today from James, so hopefully I'll get the racks back together soon.
Jerry, mine's a 11/71 2000xxx something, has a lot of K1 parts, the one off dashboard and many other early K2 oddities, most likely K1 engine too.
  • Youngish
« Reply #674 on: September 13, 2014, 09:44:45 PM »
Monumental waste of a day. Safe to say never again  >:(
The oil tank cap I liked shining up though ;)
