Author Topic: ooops . riding around with choke on?  (Read 4819 times)
Offline linktothepast23
« on: January 09, 2014, 10:31:24 AM »
So went for a ride last night turned on the choke and never took it off..I was riding in 3rd gear for a mile before I noticed. Did I damage anything??
Offline Carver
Re: ooops . riding around with choke on?
« Reply #1 on: January 09, 2014, 10:35:16 AM »
Your plugs at least, they probably are fouled/on the verge of being fouled. would change them.
Cb 750 k3
Cb 450 dohc k4
« Reply #2 on: January 09, 2014, 10:46:15 AM »
What model of bike. Never tried but I don't think any of my pre 1976 750's would even run down the road with the choke on warmed up. Barely use it when cold ,more like tickling it up and down while holding the rpm's up a little.
  Don't fret on it, little extra gas is all.
Offline Vinhead1957
« Reply #3 on: January 09, 2014, 10:49:16 AM »
Simply no!
Offline lucky
« Reply #4 on: January 09, 2014, 11:31:12 AM »
I agree, your plugs are NOT 'ruined".
« Reply #5 on: January 09, 2014, 11:34:44 AM »
Its a 78 750k. I feel like an idiot that I even did that. But thanks guys I won't worry to much about it
« Reply #6 on: January 09, 2014, 12:18:07 PM »
Im surprised you didn't get some seriously high revs when stopped.  :o (assuming you have the proper PD carbs)
With the choke pulled, the fast idle cam is engaged, holding your slides up....or in your case, not holding them up.
Best to get it working properly  ;)
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #7 on: January 09, 2014, 01:21:46 PM »
You've got to get out of this habit of calling yourself an idiot each time you learn something. At this rate you'll be one of the most knowledgeable idiots I've ever heard of ;)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline iron_worker
« Reply #8 on: January 09, 2014, 01:23:23 PM »
Just go rev 'er out on the highway to blow the carbon out!  ;D
IW
« Reply #9 on: January 09, 2014, 01:36:03 PM »
IW
+1
Spark plugs will self clean if the mixture and cylinder temps are correct.  High power output makes the chambers toasty.   Whooo HOO!
Offline Vicman
« Reply #10 on: January 09, 2014, 02:05:47 PM »
I really like that post. ;)
Fluent in three languages, English, sarcasm, and profanity.
« Reply #11 on: January 09, 2014, 02:09:38 PM »
Dude, don't feel so bad.  I have rode around all day long with the choke partially on...all the while wondering, "What the hell is wrong with my bike?" :)
Offline Roach Carver
« Reply #12 on: January 09, 2014, 02:13:39 PM »
I rode with my helmet on backward. boy did I feel stupid.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #13 on: January 09, 2014, 02:17:26 PM »
Me too, I couldn't see for the first few hundred yards.  ;D
« Reply #14 on: January 09, 2014, 02:20:56 PM »
I prefer FNG.  As in, 'That FNG wondered what that whizzing metal sound was as he wore a nice groove in the center stand after taking my his shi##y stock pipes off'   :o ::)  ;D
Offline Honda550k
« Reply #15 on: January 09, 2014, 02:28:50 PM »
Nothing wrong. The plugs I believe will self clean themselves. It happens to a lot of us. We forget things here and there. I once took off with the petcock off and the bike died. I thought to myself Oh shoot what the hell just happened. Turned it back on and laughed to myself.
« Reply #16 on: January 09, 2014, 02:41:48 PM »
I do this almost every time I ride.
« Reply #17 on: January 09, 2014, 04:13:58 PM »
Hah I'm a first time rider and I've done all that stuff already! It did rev really high when I stopped but I had no clue what was going on at the time. I'll go tear up the roads now :D
Offline bjbuchanan
« Reply #18 on: January 09, 2014, 04:27:28 PM »
I'm surprised it didn't run like total crap, but yeah no harm done really
Black 750K8
« Reply #19 on: January 09, 2014, 08:31:17 PM »
Better than running around with your reserve on.   ;) It is a bad felling when you run low and go to turn the valve just to find that is already on
« Reply #20 on: January 10, 2014, 04:46:22 AM »
Probably better than driving the bike with only one working point as I did on a holiday in France long time ago. I had to drive 40-60km on 2 cylinders to a local HONDA shop where they could repair the point.
I did not see any damage on cyl 2-3 pistons/bores when I took the bike apart  23 years later. I think it was the left point that suddenly gave up. (Yes, it was an almost new Daiichi point ~4000km old)
If you could drive that long on Choke, it was not at max position?
I do not remember OEM carbs but my Mikuni VM29 cannot be driven on full choke. That is very visible and rich with much higher idle. Only possible the first minute when cold.
« Reply #21 on: January 10, 2014, 05:15:35 PM »
That is correct. I have a 78K also and we do have a fast idle cam, so you would have gotten high revs and crappy engine braking with high revs. I would check that fast idle cam and adjust if needed. It is a great feature.
 Your bike is fine.
Offline vrm
« Reply #22 on: January 10, 2014, 09:30:37 PM »
I was riding one time, the fuel ran out and I reached down to turn on the reserve. When I did this I accidentally tripped the choke, which would not have ordinarily been much of a problem except at that same time there was an 18 wheeler passing me on the left. I lost power but I didn't know why. He was signaling that he wanted to turn right at the next turn. He slowed down to let me get ahead, which I would have very much liked to do but my bike wasn't cooperating because the choke was on. He slowed down more to let me know that he wanted me to go ahead. Eventually we came to a complete stop and I was able to wave him on.
Ride it like you stole it from your ex-wife's new husband.
Iron Butt Association membership number 49866.
