Author Topic: 77cb550f dual caliper mount  (Read 2754 times)
Offline IBleedHondaRed
    • OEM Parts diagrams from my shop
« on: February 19, 2014, 10:51:00 AM »
what parts (right caliper, mount, hub) will work on the unused stock holes in the right side lower fork. if nothing then what is the purpose of it being there?
OEM DIAGRAMS http://www.shopstarcitypowersports.com/OEMpartfinder.htm
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
1989 Hawk GT 647 (Adventure)
1989 Hawk GT 696 (Barely street legal track bike)
2007 XT225
2008 650 Gladius
2012 CB1000R
2012 VT750 Phantom   SER #000105
2013 F6B Goldwing      SER #000082
2013 KTM 300 XC-W
2014 CTX 700             SER #000043
Offline Ewan 500K1
    • Adams Bros Probe 2001
Re: 77cb550f dual caliper mount
« Reply #1 on: February 19, 2014, 03:01:55 PM »
bog standard caliper, caliper arm, caliper mounting brackets and hub . Search for dual discs and you'll find plenty info
« Last Edit: February 19, 2014, 03:05:27 PM by Ewan 500K1 »
jings, crivens, help ma boab
500 four K1 cafe racer build thread at :
http://forums.sohc4.net/index.php?topic=100883.0
« Reply #2 on: February 20, 2014, 06:01:17 AM »
Pardon my ignorance but what is "bog"
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
Offline iron_worker
« Reply #3 on: February 20, 2014, 06:57:41 AM »
I believe it just means unchanged from original or stock.
IW
Offline Ewan 500K1
« Reply #4 on: February 20, 2014, 08:20:01 AM »
IW
 ;D ;D ;D ;D thats the one
.. but need a nonbog speedo drive plate
« Last Edit: February 20, 2014, 08:22:13 AM by Ewan 500K1 »
« Reply #5 on: February 20, 2014, 08:53:52 AM »
Would it not be better to replace the master cylinder with one with a bigger plunger for the dual brakes?
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
Offline dagersh
    • Photos
« Reply #6 on: February 20, 2014, 09:27:39 AM »
Definitely going to need a bigger MC.
I am not sure of the measurement, but again, do a search for Dual Disc Conversion and all the info is in here.
I have not done it yet, but the modification for the Speedo Drive plate is not that difficult, and once you have it all apart, it becomes obvious what needs to be done.
Good Luck!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Ewan 500K1
« Reply #7 on: February 20, 2014, 05:48:41 PM »
Good Luck!
Gersh
goldwing gl1000 master cylinder is the one people generally use. Oh yeah and you'll need longer disc bolts ... again goldwing ones do the job.
« Last Edit: February 20, 2014, 05:51:24 PM by Ewan 500K1 »
« Reply #8 on: February 20, 2014, 08:12:56 PM »
Good Luck!
Gersh
The stock 14mm master cylinder will work fine. ;)
Offline dagersh
    • Photos
« Reply #9 on: February 21, 2014, 03:39:26 PM »
I thought the lever ended up too "wooden" feeling with the stock 14mm?  I may be wrong, though.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Puntas13
  • '73 cb500 '74 cb750 '09 Triumph Speed Triple
« Reply #10 on: February 22, 2014, 06:45:49 AM »
I just finished up a dual disk setup on my 500. I initially ran modern Nissan 14mm master then switched to the same thing but in 5/8ths. The 14mm had a better and more progressive feel but I could squeeze it hard enough to were it would touch the bars. The 5/8ths has a more wooden and less proggresive feel but it will not contact the bars. If they made a master cylinder sized right in the middle I think it would be perfect.
I ran the Nissan 14mm for a while with just a single disc and it was an improvement over the stock unit.
« Reply #11 on: February 22, 2014, 07:36:18 AM »
I happen to have a front fork assembly with caliper and bracket in good shape on it in my garage. rotor is a 4 bolt though so hopefully I can dig up the rotor that came on this 500 frame
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
Offline Puntas13
« Reply #12 on: February 22, 2014, 08:26:41 AM »
I had a pretty pain free time doing mine. I was able to sand down(bench grinder) the bottom tab of the caliper bracket to were it mounted up perfectly without the need for shims. The only down side is you'll have to take off one side of the the brakes to remove your wheel now.
« Reply #13 on: February 24, 2014, 01:54:12 PM »
anyone with first hand master cylinder advice/experience? preferably from another Honda model with dual fronts?
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #14 on: February 24, 2014, 02:56:56 PM »
What scotly said, original MC works perfectly well with dual disc brakes.
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #15 on: February 24, 2014, 04:31:44 PM »
Ewan
I think you have the mudguard bolted to the inside of the caliper swing arm. It should be on the outside. From your pics I can see that the brake pad is not contacting the disk and will wear at an angle. Also the brakes will not work properly until the pads wear down to compensate for the offset caused by misalignment.
Offline Ewan 500K1
« Reply #16 on: February 25, 2014, 12:00:26 PM »
Ewan
cheers for worrying about me The P  ;D.  The pictures show the right hand side, ie the side with the extra caliper added.  On the standard left handside the mudguard bracket does sit on top of the pivot arm bracket right enough. On the right handside the mudguard of course bolts straight onto fork casing when a second disc isnt added. You are right, I have the mudguard bracket mounted between the fork leg and the upper pivot arm bracket. With this arrangement I have it set up with a uniform 0.006 inch clearance between the inner pad and the disc with the mudguard bracket between the fork leg and the caliper arm bracket. ... either the photo was taken before I was finished tweaking or the photo doesnt have good persective to show the true alignment (photo was taken when forks were still on the workbench) ...right enough its not back on the road yet ... time will tell ;)
Another wee issue is that the speedo cable rubs of the the new disc, so a wee adition needed to hold it off the disk. Also added a grease nipples to each caliper arms pivot
Cant say it was all straight forward ... but that was mostly ddue to the mongrel basket of parts I used. Pain and agony recorded here: http://www.sohc.co.uk/index.php?topic=5571.15
« Last Edit: February 25, 2014, 12:22:59 PM by Ewan 500K1 »
Offline jonda500
« Reply #17 on: February 26, 2014, 04:04:23 AM »
I ran longer 750 forks with twin discs on my 500 for a bit- the standard master cylinder worked fine, no problems- braking seemed a little better though prob just psycological. I converted back to single disc to save money on rebuilding and replacing hoses costs and to make wheel removal easy again, but mainly because I wanted to go back to the standard length 500/550 forks which in Australia never seem to have the extra lugs needed for the extra caliper.
A starter clutch thread:
Offline flatlander
« Reply #18 on: February 26, 2014, 05:10:36 AM »
i'm also using the bog standard master cylinder with dual discs on my 550. works fine, definitely can be done.
but the real question would be: does anyone have direct experience comparing the bog stadard with a different cylinder, with dual discs?
« Reply #19 on: February 28, 2014, 12:50:31 PM »
haven't found one yet. I actually think that the parts bike had the caliper and rotor removed. dad doesn't remember removing it but that was like a year ago and hes 60 now lol
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
