Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 113571 times)
0 Members and 8 Guests are viewing this topic.
Offline Davez134
Re: 1972 CB750K2 (start from scratch) project. Small leak!!! Damn!
« Reply #300 on: March 22, 2015, 09:37:34 AM »
Davez134.
I'd be interested to hear your thoughts about how all the modifications you have made to your engine have improved the performance and enjoyment of riding the machine? Was it all worth it?.
Have followed your build story from the other side of the planet with interest.
Cheers
So far, the performance of the engine is great. I have not taken it past 6000 rpm yet, as I have just over 100 miles on it. Also I have never ridden one with a stock motor before, but compared to my last bike with 836cc, non-ported head, stock cam, this one has noticeably more power. With the ported head and webcam 41, it is very practical to ride daily on the street. To me, it was worth it, not so much for the extra horsepower, but knowing that I have gone through every part of the motor. I know that everything was done right, nothing was half assed, and I know I will be able to enjoy riding it for a long time with no issues. That was worth the most to me. Also all the money I saved on a shrink. This is my therapy ;D
Offline Davez134
« Reply #301 on: March 23, 2015, 09:52:34 AM »
Well, everything was going too good. Have a leak around base gasket. Front left, right where stud is. Not too bad but was really hoping to be leak free!! Damnit.
Wiped clean in the pic, but coking from here
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #302 on: March 23, 2015, 11:09:23 AM »
That sucks. Almost makes you wanna cry doesn't it?
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline Davez134
« Reply #303 on: March 23, 2015, 12:18:34 PM »
Yes very frustrated. Spent so much time trying to prevent this. Especially all the way down at base gasket. All I can think of is thicker weight oil and re torquing studs. I have kibblewhite HD studs torqued to 20 ft/lbs and max is 22. Might try it since I have frame kit installed.
« Reply #304 on: March 23, 2015, 12:31:07 PM »
That sucks.  I had a base gasket leak on my 550, and I ended up using HD studs and fixed the leak.  I would give re-torqueing the studs at 22 ft/lbs AND maybe a new base gasket a shot before having to pull the motor and re-deck surfaces.
Offline Davez134
« Reply #305 on: March 23, 2015, 01:55:10 PM »
Going to try going to 22 ft lbs first, then if that doesn't stop it I'll pull head and jugs to try new gasket. I have mls head gasket, would I have to replace? Keep same piston rings?
Offline Davez134
« Reply #306 on: March 23, 2015, 02:07:52 PM »
Cal, in Las Vegas. And if I do anything drastic, I'm going all out. Taking it out to the desert for a bonfire!!
« Reply #307 on: March 23, 2015, 02:22:46 PM »
There are lots of bodies buried in the desert.  Hopefully, this bike won't suffer the same fate!
Offline edwardmorris
  • Youngish
« Reply #308 on: March 23, 2015, 02:51:07 PM »
I haven't gone back and read, but did you use a sealant on the base gasket?
Offline Davez134
« Reply #309 on: March 23, 2015, 03:46:06 PM »
I did not, read on their site to install dry. Wish I would have though. If I end up replacing, I definately will
  • Youngish
« Reply #310 on: March 23, 2015, 09:49:56 PM »
Sorry for your troubles. From what I've been reading, it seems like installing gaskets dry is the way to go when both contact surfaces have been decked. Otherwise some sealer is almost necessary. I'll be using permatex #2 non hardening sealer when I get to mine, soon. Lets hope the higher torque squeezes this one shut for you, I can only imagine the frustration of getting the sweet taste of riding only to have it taken away, even if its temp.
Offline Davez134
« Reply #311 on: March 23, 2015, 11:56:52 PM »
Got a new base gasket on order just in case. Don't want to do it, but know how it goes if I have to.
Offline hotdog
« Reply #312 on: March 24, 2015, 12:49:12 AM »
Bummer, did you coat the base gasket with anything Dave.?
Edit - Sorry have just seen this asked above....
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
« Reply #313 on: March 24, 2015, 09:24:51 AM »
What type of base gasket did you use Dave? Viton/steel or fiber?
Offline Davez134
« Reply #314 on: March 24, 2015, 09:32:28 AM »
Mike, I used the steel/viton base gasket
I'm wondering, If I need to replace gasket, do I need to replace piston rings as well? Do they seat against cylinder wall a certain way? Or do the rings rotate around in their grooves anyway? I only have 150 miles on this thing!
« Last Edit: March 24, 2015, 01:07:43 PM by Davez134 »
Offline hotdog
« Reply #315 on: March 24, 2015, 01:40:02 PM »
Only the gasket Dave, rings will be fine.
« Reply #316 on: March 25, 2015, 06:20:37 PM »
You need to use a small amount of 1194 around the cam tunnel and oil return "triangles". I have used the viton/steel on my FJ and found i HAVE too use it on the right side of the base gasket around the oil feed to the head. It will leak otherwise.
Offline Davez134
« Reply #317 on: March 25, 2015, 07:22:28 PM »
Got it. I used a fiber gasket on my last one coated with a copper spray sealant, no leaking issues. I may just do that again. Only reason I used the steel/viton one was that it came with the cycleX kit I orders. What are the advantages of that one? So far I see none haha. I'm going to ride it for a few months though. Leak is very minor and I'm being really picky. The thing runs waaaay to good to just take it back down already. When the temps here get into the 100's I'll fix it. Final pics up in a couple days!
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #318 on: March 25, 2015, 07:56:42 PM »
I was kicking around doing the copper spray instead of aviation permatex like I've been planning. Hmmm.
Offline timbo750
« Reply #319 on: March 25, 2015, 07:57:21 PM »
Mike, can you tell me what the next best thing is to ghe 1194? It does not seem to be available here in Aus. I can get 1104NEO and 1211 but the 1211 is very expensive compared to the others.
Offline hotdog
« Reply #320 on: March 26, 2015, 12:31:53 AM »
Timbo, my 2c. - Threebond 1211 is all I use and all I ever will use. Designed specifically for motorcycles, snowmobile, ATV's etc. It can be used on head gaskets as it has a 100 deg Celsius (250c) higher rating than the 1104 it also has a longer working time before it tacks off. Only ever used 1104 once and it wasn't for me.
Offline timbo750
« Reply #321 on: March 26, 2015, 01:06:32 PM »
Thanks hotdog and sorry dave for temporary highjack. We shall now return to the normal running of this build thread.
Offline Davez134
« Reply #322 on: March 26, 2015, 01:40:09 PM »
So, I'm calling this bike done! Re torqued studs, put 20w50 oil in there (it is upper 80's today!) and went on a ride with the wife for lunch. Looks dry at base gasket. So here's a summary and some pics:
Started with this
And
Motor gone through 100%, Trans inspected, cleaned, bearings replaced. HD primary and cam chains, cycleX tensioners, New rod and crank bearings, new rod bolts, 836cc wiseco pistons, JMR ported head, webcam 41, cycleX clutch, HD kibblewhite studs, painted wrinkle black and cast aluminum.
Carbs sourced locally and rebuilt/painted
Frame kit, tapered steering bearings, bronze swingarm bushings, new grease fittings
Forks sourced here, polished, new tubes, progressive springs
Hagon rear shocks, rebuilt front brake, slingshot cycles braided lines. All new wiring, pamco ignition, ricks reg/rec, led signals, Here she is now:
« Last Edit: March 26, 2015, 09:53:05 PM by Davez134 »
Offline iron_worker
Re: 1972 CB750K2 (start from scratch) project. Call it done!
« Reply #323 on: March 26, 2015, 01:47:37 PM »
Dang! She's a looker.  8)
Did you end up using sealer on your base gasket and/or head gasket? Did you stick with the MLS? I ask because I've also had some trouble getting my MLS gasket to seal up completely.
IW
Offline Davez134
« Reply #324 on: March 26, 2015, 01:51:00 PM »
I did not use sealer on either. Base gasket seems ok now after re torque, we will wait and see. Head gasket has been leak free since first start-up no issues there. I did have head and cylinder surfaces trued though.
