Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 124886 times)
Offline timbo750
Re: 1972 CB750K2 (start from scratch) project. Call it done!
« Reply #325 on: March 26, 2015, 02:12:39 PM »
Dave, how did you find the Hagon shocks when riding 2up. I need to order some shocks soon and also plan some 2up riding.
Offline Davez134
« Reply #326 on: March 26, 2015, 03:13:32 PM »
Felt good. I went with the next available stiffer rate spring than stock recommendation, as we planned on riding together a bit.
« Reply #327 on: March 26, 2015, 03:18:37 PM »
Tim, go with the Ikons{Koni's} mate, they are a better shock and are made locally, not knocking the Hagons they are fine, and better than stock shocks for sure, but the Ikons are a step up again, made in Australia and are rebuildable. I've used Ikons/Koni's on these old bikes {and others} since the late 70's and they are good, I've also done 1000+ Kilometer days 2 up several times. I still have some Ikons {30 year old and still good}, that i'll be using, in my garage... ;)
Dave, that bike looks excellent, love the color... ;)
« Reply #328 on: March 26, 2015, 04:18:33 PM »
Dave!
Gorgeous bike.  It turned out great.
Don
Offline Davez134
« Reply #329 on: March 26, 2015, 07:01:40 PM »
Dave!
Don
Thanks! Now I just need to take the wife on a bunch of rides until she wants one of her own 8)
« Reply #330 on: March 26, 2015, 10:28:24 PM »
Dave!
Don
Good luck with that.  My better half has no desire to ride.
Offline Davez134
« Reply #331 on: March 30, 2015, 10:30:47 AM »
Well, the leak came back. New gaskets on order. If you are undecided on installing a frame kit do it! As soon as gaskets get here, it should be about a hour job.
Offline Ravie
  • Definitely not a
  • Soul to Soul
Re: 1972 CB750K2 (start from scratch) project. Leak is back
« Reply #332 on: March 30, 2015, 10:44:36 AM »
What do you plan to use to seal it this time?
Im still undecided as to aviation permatex or copper spray. The copper spray is spendy and I already have the permatex on hand.
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline Davez134
« Reply #333 on: March 30, 2015, 10:55:09 AM »
I'm going to use Hondabond 4, since I have a whole tube of it.
« Reply #334 on: March 30, 2015, 11:49:14 AM »
Welcome to the suck.  Been there!  Go sparingly on the Hondabond.
Offline edwardmorris
  • Youngish
« Reply #335 on: March 30, 2015, 12:32:02 PM »
Dave,
    I was chatting with Mark about this and he suggested that the thickness of the o-rings is generally the culprit here. Before installing the new gaskets, check to make sure the o-rings are thicker/taller than the gasket. I'll dig up the exact numbers if I can. I have two vesrah kits collecting dust right now, as I've decided to go with MLS head and base gaskets after talking to a few people.
Offline Davez134
« Reply #336 on: March 30, 2015, 12:45:42 PM »
Dave,
I remember reading that. Thanks! I will check for sure. Let me know I you get the numbers. I believe it was between 2.5 or 3mm thick?
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #337 on: March 30, 2015, 12:49:43 PM »
:-O makin me scared about my vesrah kit now.
  • Youngish
« Reply #338 on: March 30, 2015, 01:06:47 PM »
Dave,
Here you go
Quote from: PM Excerpt
................. Set the gasket in place and measure the depth, or the height of the O-rings above the gasket, to make sure they are taller than the gasket and hole combined. They should be between 0.14 and 0.20mm thicker than the gasket top...............
Offline strynboen
« Reply #339 on: March 30, 2015, 01:43:52 PM »
my vesra kit leaked 14 days after total reno..i have not done anything yet..after 3 years it are not blead to death...
i hate all this v-w.... vords
Offline Davez134
« Reply #340 on: March 30, 2015, 02:21:01 PM »
Do you think I should put coating on the gasket itself, or the surfaces? I also have a can of copper spray? should I use that instead of hondabond? This is the LAST time I want to do this haha.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #341 on: March 30, 2015, 02:56:20 PM »
Hondabond sets up too fast in my opinion. Seems like coating the whole thing would be better...
  • Youngish
« Reply #342 on: March 30, 2015, 04:26:06 PM »
What kind of gasket? MLS won't need any coating if the o-ring thickness is correct...
Offline Davez134
« Reply #343 on: March 30, 2015, 06:42:42 PM »
Head gasket MLS, going on dry. Base gasket is Viton/steel.
  • Youngish
« Reply #344 on: March 30, 2015, 07:09:07 PM »
Spray might be easiest unless you want to put in the work to get threebond/permatex#2 on it evenly. I know Flybox1 used copper spray thing on his base gasket and was leak free, he might have better tips.
Offline Davez134
« Reply #345 on: March 30, 2015, 07:19:29 PM »
I am leaning toward spray and correct o-rings, as I already have it, used it on my last base gasket without leaks.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #346 on: March 31, 2015, 04:06:22 PM »
Looked in my harbor freight O ring set and found the right size ring and measured it against the ones that came in the vesrah kit.  Vesrah rings measure 2.35mm and the HF rings measured 2.45.
Are there any issues with using them from a heat standpoint? Seems they'd be the better choice from the thickness standpoint.
Offline Davez134
« Reply #347 on: March 31, 2015, 06:21:50 PM »
Heat would not be an issue. As far as the thickness goes, seems like it will be based on base gasket thickness. I'm going to measure mine as stared in reply #354 in this page
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #348 on: March 31, 2015, 08:49:38 PM »
I measure about .69mm that the HF one sticks up above the channel when installed. The base gasket from my kit measures .47mm so roughly .20mm. That is a huge difference since the Vesrah kits o rings would have been half that height.
Offline Davez134
« Reply #349 on: March 31, 2015, 10:01:44 PM »
Would go with the HF one then
