Author Topic: Newbie Project '76 CB550  (Read 6075 times)
Offline yeyoPR
« on: August 12, 2014, 01:25:16 PM »
Hi all.  This is my first project!
Bought this bike with 8,900 miles and last ridden in 1999.  Im still not sure if Im going for stock or for cafe/brat.
I would really like to go the stock way, but the problem is I would have to replace all the chrome parts, or rechrome.  Making it a brat wouldnt be too hard.
Heres what Im dealing with:
Re: Newbie Project '76 CB550
« Reply #1 on: August 12, 2014, 01:48:55 PM »
Yeyo,
Don't worry so much about the design right now.  Concentrate your efforts on getting the bike running reliably and safely.  Give it a thorough tune up, replacing engine oil, fork oil, brake fluid, replacing worn brake lines, fork seals, rebuilding the brake master cylinder, checking your brake pads.  Clean the gas tank and fuel lines first (before attempting to fire the bike), clean and synch the carbs.  Check the wear on your tires -- replace cracked tires and inner tubes if they are leaking.  After getting it running, check the charging system for any shorts.
Use Coke and aluminum foil to remove rust off your chrome pieces, spray with WD40 after.
Get used to your bike before asking what you want it to become.  If you enjoy it stock, keep riding it and restore it as you ride. If you want to cafe or brat it, modify it as you ride it.
Offline yeyoPR
« Reply #2 on: August 12, 2014, 02:38:57 PM »
Hi...thanks for the reply!
I like your last advice about restoring/modifying as I ride, but I'm afraid its too late for that!  The bike is already stripped to the frame and engine!
I'm now concentrating on getting everything that's not related to design.  Already cleaned and rebuilt the carbs, I'm getting brakes lines/pads, fork seals and oil, master cylinder is done, fuel lines, etc.  Both tires need to be replaced, and also I'm gonna need a rear wheel.
I tried the coke/aluminum thing on some chrome parts but it seems they are way too damaged.  Whats a good source for oem parts?   Check out this rear wheel and spokes!
« Reply #3 on: August 12, 2014, 02:47:47 PM »
That rear wheel is toast.  Unless you are undertaking a strick restoration, I would suggest buying aluminum rims (Buchanans) to replace your rusty OEM D.I.D. steel rims.  The aluminum ones are much lighter.  You can get spokes there, too.
Parts:  OEM (West Hills Honda, Western Honda, David Silver Spares, CMSNL); Performance (Dynoman, Cycle Exchange, APE); Aftermarket (Cycle Exchange, Dime City Cycles, 4into1, Cognitomoto); GSXR front end conversion (Cognitomoto, All Balls)
Offline yeyoPR
« Reply #4 on: August 12, 2014, 03:07:07 PM »
Thanks guys!  Those contacts really help the research.
Offline Tews19
  • I am no
« Reply #5 on: August 14, 2014, 07:38:44 AM »
Try using steel wool 000 for the rust. I tried the coke and tin foil trick. Didn't work as well as steel wool.
1970 Honda CB750 survivor.
Offline yeyoPR
« Reply #6 on: August 14, 2014, 01:26:18 PM »
Thanks, Tews. I'll give it a try.
Just spent 1hr+ on your build thread, awesome job!
Offline goldarrow
  • one day, i'll be an
« Reply #7 on: August 14, 2014, 01:59:18 PM »
with that much of rust, i wouldn't waste time cleaning the chrome.  i would either send them off to rechrome or source the parts.
CB550 K0
Offline yeyoPR
« Reply #8 on: August 14, 2014, 03:16:40 PM »
Thanks for the ideas!
My first option is to restore to stock but I don't wanna spend a fortune re-chroming or buying new original chrome parts.  I have a LOT of rust.  So I'm gonna try and save to as much chrome as possible and then do the math on the parts I couldn't save.
If its too much I'll go with the cafe/brat.
I haven't checked prices, but I understand re-chroming is about the same price as powder coating?...and buying new can be cheaper than re-chroming?
Offline Mcwilliams570
« Reply #9 on: August 14, 2014, 04:42:08 PM »
That rim looks pretty bad I think new ones would be the easy way to go. Nice project.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #10 on: August 14, 2014, 06:47:25 PM »
+1.  Not sure what your budget is, unless it is the sky, consider good used parts from this forum or ebay.
Offline yeyoPR
« Reply #11 on: August 14, 2014, 07:44:54 PM »
......... then full-on, over the top restoration SohRon's 550 build). Your choice to use as inspiration.
Took me a while to find SohRon build thread, I'm on page 5 now and all I can say is WOW!!!....what a great source with narrative and pics.  Definitely an inspiration!  Thanks for pointing that out, and thanks to SohRon!
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #12 on: August 14, 2014, 07:59:25 PM »
Looking good man, Wish I had those pipes!
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline yeyoPR
« Reply #13 on: January 19, 2015, 07:33:50 PM »
Hey all!   Just thought I give an update....here's were I'm at so far.  Little by little, a couple of hours every weekend.
I'm mocking up the parts Im getting just to see what else I will need.
Next thing to buy is the exhaust.  From my research I would like MotoGP werks 4into1, but I cant find them anywhere.  I think Im gona go with the Carpy's.  Any suggestion?
« Last Edit: January 19, 2015, 07:40:46 PM by yeyoPR »
Offline GV1390
  • Express Gratitude.
« Reply #14 on: January 20, 2015, 05:17:52 AM »
I ran Carpy's exhaust on my last CB550 and I wouldn't go back to him for various reasons, primarily because the customer service plain out sucks. I talked to Chris from MotoGPWerks last week. He only makes X sets a year and only has one extra one which has my name on it....Lossa would be a good option, but I've never done business with them so I couldn't say completely.
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Offline yeyoPR
« Reply #15 on: January 20, 2015, 11:27:13 AM »
I checked on the Lossa, and what turns me down is that they will not work with the center stand and cant remove the oil filter with them on.  I can deal with the oil filter thing, but I love the center stand!  Theres that, and also the Lossa is like $120 more with the options I want (black ceramic, baffle, etc).
Another thing I have to consider is the shipping, my options are more limited because I'm not in the USA and not everybody ships here.
Anyway, I have time to think about it and do more research.  But for now Carpy's are winning.
Offline GV1390
« Reply #16 on: January 20, 2015, 11:32:41 AM »
I can't speak about the center stand as I never ran one, but I do know you have to remove the entire exhaust to access the oil filter with Carpy's unit.
Offline yeyoPR
« Reply #17 on: January 20, 2015, 11:52:39 AM »
Thanks for the replies!
Is the center stand on a 500 different from a 550?  Because theres some pics on Carpy's site of a 500 with the center stand on.  Maybe that's were I'm mistaken.
http://www.cb750cafe.com/wp-content/uploads/2014/03/Kevs-500-carpy-shot.jpg
I've seen the only 4into1 with access to the oil filter are the Mac's, but I haven't read great reviews about those.
I don't mind removing the exhaust for tune ups, doesn't take that long.
Offline GV1390
« Reply #18 on: January 20, 2015, 11:58:05 AM »
I'll make it easier for you....
Ditch the center stand, mirrors, gauges, blinkers, side-covers and anything else I forgot. Don't be a wuss. :)
Offline yeyoPR
« Reply #19 on: January 20, 2015, 12:06:47 PM »
hahah  ;D
Might have to ditch all that, except the blinkers.  I don't want a ticket every time I ride.  :'(
ohh and the gauges, I like!
Offline GV1390
« Reply #20 on: January 20, 2015, 12:14:11 PM »
Is your left arm functional? If so, ditch em! But hey, some of the old timers on here will give me grief for my opinion, haha.
« Last Edit: January 20, 2015, 12:24:42 PM by GV1390 »
Offline yeyoPR
« Reply #21 on: January 20, 2015, 12:20:16 PM »
Yeah left arm works!  I've even used it 2 times to pull the reserve handle  :P
But beside giving the police an excuse to stop me, if you see how people drive their cars around here you'll want 3 foot blinkers!
« Reply #22 on: January 20, 2015, 04:10:15 PM »
I have not seen a single 4-1 Yosh replica exhaust that is compatible with the center stand -- other than the picture you linked.  IF YOU GO WITH CARPY, confirm beforehand (preferably in writing) that the pipe he is supplying is compatible with a  center stand (as pictured).  To do so, the pipe MUST offset to one side of the frame.  The MGP and Lossa pipes do not offset like the one pictured.
MGP
Pros: highest quality (spring mounts, 2-piece) and comes with baffle
Cons: no mount for the end portion of the pipe
Lossa
Pros: good quality and design (2-piece) and Jay will provide a baffle,coating and mount upon request; no production number limitations
Cons: no spring mounts
« Reply #23 on: January 22, 2015, 05:35:45 PM »
Another option for exhaust is the 550F header.  I have one on my '76 550K paired with a Yoshi can, bought it that way.
However, I lust after the MotoGP pipe and will own one, one day...
