hook all four to a steady vacuum source at the same time,then see if they read the same,if not set them so they do,vacuum is like pressure,they should all read the same like if you had four gauges hooked into the same pressure vessel,you can suck on the pipe and hold the vacuum with your tongue,or if you have an old car with distributor and carby use its vacuum advance port itll be strong and steady,trying to set them individually is the wrong way,even though when they are being used they will be measuring individual vacuums,and you will then be adjusting the vacuum source.
