Author Topic: Cb650 high idle  (Read 9989 times)
Offline DaveBarbier
Re: Cb650 high idle
« Reply #25 on: September 13, 2014, 04:43:57 AM »
Is it worth tryin to pull out these jets to clean them or will it just ruin them? I may just get a set of 82 carbs and go from there instead
If you're going to get a rack of carbs with the removable jets anyway you can try to remove the ones you have and see how clean they are. In my pressed in pilot jets in my 550k I had to remove them to get them really clean. I then soaked the jets in carb cleaner for a few hours and used a tiny copper wire to get all the crud out. Careful though, maybe soak the area in PB Blaster for a bit. You need to grab strong with pliers but if you use vice grips you risk collapsing the jet.
In that post I sent you earlier there's a link to a site where a guy shows how to convert the press type into a threaded type...if you're so inclined.
1978 Honda CB550K
Re: Cb650 high idle
« Reply #26 on: September 13, 2014, 08:28:43 AM »
The suspense is killing me, cant wait when you finally find the problem  ;D  :D
Offline Davecb650c
Re: Cb650 high idle
« Reply #27 on: September 13, 2014, 09:36:01 AM »
Yeah ill try pulling them, unfortunately on the 81 cv style carbs the jets are wayyy down in that tube so it looks like getting them out is a major pain.. Guess ill try it, and it works, great, if not ill slap the 82s on there and give that a try
You and me both! I'm really itchin to ride it!
Offline Davecb650c
Re: Cb650 high idle
« Reply #28 on: September 24, 2014, 04:36:06 PM »
Ok so I still haven't had any luck with these carbs, ordered a set from an 82 off ebay and the spacing is all wrong, and they're larger in general. I think they must be off of a 750 or something. Can anybody verify? I'm gonna contact the seller I guess unless anyone on here has any interest in them
Offline trueblue
Re: Cb650 high idle
« Reply #29 on: September 25, 2014, 03:04:01 AM »
What is the number on the side of the carb?  Should be VB-XX if memory serves correctly.  Definitely not SOHC 650, could be off an '83 DOHC 650 or 750.  ;D
1979 CB650Z
Offline Davecb650c
Re: Cb650 high idle
« Reply #30 on: September 25, 2014, 04:05:56 PM »
They are 750 carbs, I contacted the seller he said he had a couple sets of them for 650s and 750s and mixed it up so he's sending the right set to me
Offline cb650
Re: Cb650 high idle
« Reply #31 on: September 26, 2014, 07:54:35 AM »
The 83 dohc went back to a diaphragm style.  No big domes for the "piston".  And yes the spacing is off.
Offline trueblue
Re: Cb650 high idle
« Reply #32 on: September 27, 2014, 02:57:58 AM »
Fair enough, I haven't had anything to do with the DOHC models, I was only throwing it out there  ;D
1979 CB650Z
Offline Davecb650c
Re: Cb650 high idle
« Reply #33 on: October 02, 2014, 05:07:27 PM »
Well I got the right carbs on there and that seems to have fixed the problem! I set the idle at a little over 1000 an it seems to run good at idle now. I rode it down my road and back and it seems to run decent but it has a bog if I go wot from about 1/4 throttle suddenly, but it revs smoothly if I gradually open it up. I don't currently have an air box or anything on it so ill have to get that all squared away before I screw with it much more. Thanks for all the help!
Offline DaveBarbier
Re: Cb650 high idle
« Reply #34 on: October 02, 2014, 09:26:52 PM »
Good to hear. I hope my idle issue is as easily resolved. Having to tune the carbs seems normal considering your setup. Get it dialed in and hopefully you'll be good as gold.
1978 Honda CB550K
Offline Davecb650c
Re: Cb650 high idle
« Reply #35 on: October 22, 2014, 03:14:10 PM »
Just an update, thing runs like a top! Got new tires, chain and bars and she looks pretty good. Thanks for the help everyone!
Offline juntjoo
Re: Cb650 high idle
« Reply #36 on: February 20, 2018, 08:20:07 AM »
hey so you never resolved the issue with the original carbs?  have the exact same problem but I'll be damned if I gotta get a new set of carbs. I've got the 82's with the removable slow jets and all mine are clear. Exact same idle issue.
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline juntjoo
Re: Cb650 high idle
« Reply #37 on: February 20, 2018, 12:06:56 PM »
I got it, it's the fast speed idle linkage, the one bendable arm, if adjusted too close to the throttle it will open it too much.
-Ben
82 Nighthawk 650..
