Author Topic: the name of it in english  (Read 1521 times)
Offline mazingerzeca
« on: October 01, 2014, 11:40:37 AM »
Hello all.
I've lost the "part" that goes under the speedo of my CB750 K7 (on the left side in some models) which turns the partial odometer to 000000. I think that it will be difficult to find that part, given that I don't know the name of it in english, even I don't know it in spanish, my own language!
So, if you know the name of it, to start a search, or if you know where to find it, it would be very helpful. Thank you.
Re: the name of it in english
« Reply #1 on: October 01, 2014, 11:43:52 AM »
« Last Edit: October 01, 2014, 11:47:51 AM by 70CB750 »
« Reply #2 on: October 01, 2014, 12:26:00 PM »
its a sandcast....high preised... ???
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: October 01, 2014, 01:37:26 PM »
Not sure about a K7, but on the F2 (same gauges?) it is a moulded on part. The spigot sticking out of the speedo looks threaded but isn't. If you look closely it's just concentric rings. I found this out when I reconditioned a speedo, went to remove the knob but it wouldn't unscrew. Thinking it was just tight and I could replace it, I cut it off. After trying to screw on a few different knobs the penny dropped.
Am I right in thinking the spigot is missing as well as the knob? Might be a case of finding an old speedo to cannibalise.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #4 on: October 01, 2014, 03:10:36 PM »
Thanks for the responses. I found it at 20 euro, very expensive too.
I don't know about the F2, mine is the one which is screwed on the bottom of the speedo, not on the left side. Mine is not a moulded on plastic piece. I remember when I reassembled the speedo that it had a male thread in which the knob was screwed anti-clock wise.
Offline martin99
  • UK Based, Non-
« Reply #5 on: October 01, 2014, 03:19:30 PM »
Gotcha. It is on the side on the F2.
Don't know how they justify those prices for a little piece of plastic. Robbing bastids!
Build threads:
1977 CB750 F2
« Reply #6 on: October 02, 2014, 03:19:25 AM »
Mine is on the bottom too.  There is a metal shaft that screws in CCW (Counter Clockwise) and the plastic piece holds on it with little positioning screw.  I took it out yesterday to refresh my memory  ;)
Ask Bill Benton, he may have a used one and shipping of a small part like that is not that expensive even over the sea.
Or have one made?
« Reply #7 on: October 02, 2014, 10:08:48 AM »
get made one i aluminium...it a bit heavyer then plastic..its easy to make that surfase..there are a special roller vho makes /press this" rilles"..
i can make one...but find a local machinist..he make it for 4 beers...i dont have a reverse tap for 4-5 mm threads
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
« Reply #8 on: February 07, 2015, 06:10:07 AM »
