This is standard for me.
I did not know about anything else before reading about a strange sealed complete lamp on this forum a couple if years ago.
Bulb is of type H4. Very common in cars and motorcycles. Available as stronger ones with much more wattage ( 100/90W), but will drain the battery.
I have a LED version lamp that I will fit into my bike, maybe today. My headlamp is full of extra stuff and the lamp need additional space when its longer (fan) and additional electronics in a box. It will fit when I have placed relays outside the lamp.
http://www.ebay.com/itm/301375731172?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITThis will use less W (20/30W instead of 60/55W) Charging system will like that. We have daylight law here. The bike is more visible then, my safety.
Better brand of bulbs comes from Philips, General Electrics, Osram. Too cheap and the low beam will be very bad, not focused as it shall. I got H4 lamp and parking light (W5W) with my reflector. They were both very bad, got short circuit and stopped work causing a general power failure. Never happened before, lamp stop work one thing, but not causing a general shortage. Must have been cheap China lamps. Bought new from Philips.
These reflectors are less common today. 20-30 years ago it was easy to visit nearest car shop and buy a standard 7" (170mm) reflector. Hella and Bosch good brands.
I bought a reflector with parking light bulb on its side when my bike has parking light on the right handle bar switch.
Photo show the mess. Most of the connectors are replaced by thicker ones (std cheap crimp sockets/pins)
