Author Topic: Anyone know this guy?  (Read 2770 times)
Offline wjustinleigh
« on: February 26, 2015, 11:43:49 PM »
Just finished wiring up the headlight bucket it looks like everything is a go - I don't have the tank and exhaust on to fire it up - but when I was done this little guy is hanging out like a leftover Ikea bracket.  Front and rear blinkers, head/tail light, high/low, horn, indicator lights, speedo/tach are all operational.  Anyone recognize him?  It's a 71 cb500 four.
71 cb500
72 cb500
07 Bandit 1250
Offline mronegear
  • Honda CB 550 F 1976
Re: Anyone know this guy?
« Reply #1 on: February 27, 2015, 12:43:50 AM »
If it is grey, it goes from the blinkers shifter to the blinker relais under the left side cover. That's from the wiring diagram of
the 550 four, but should be the same.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: February 27, 2015, 01:36:31 AM »
The brown is a spare inside the headlamp.
« Reply #3 on: February 27, 2015, 02:49:57 AM »
Extra brown in my lamp too. CB750-K6.
It's written in the circuit diagram too. Brown is 5A for rear light (except brake light that will blow the main fuse when shorted)
Offline Flyin900
« Reply #4 on: February 27, 2015, 04:49:06 AM »
It is a spare as noted and it is switched, so not constant live and can be used to run an accessory.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Airborne 82nd
« Reply #5 on: February 27, 2015, 05:31:42 AM »
That spare brown wire is used in some over seas bikes that have a small bulb  in the bucket used as a parking lamp. Not used in the USA
« Reply #6 on: February 27, 2015, 09:47:57 PM »
Awesome, thanks all!  I will ignore it without a nagging feeling now.
71 cb500
72 cb500
07 Bandit 1250
Offline goldarrow
  • one day, i'll be an
« Reply #7 on: February 27, 2015, 10:31:16 PM »
I have that headlight with small bulb in it, and I'm in the USA. I'm using it.  And yes it is wired to that Brown wire ;)
CB550 K0
« Reply #8 on: February 28, 2015, 05:23:27 AM »
PO at it again :)
wjustinleigh You may find some extra green (ground) wires one by the coils and one under the left side cover. At least they are on a 750.
Offline goldarrow
« Reply #9 on: February 28, 2015, 08:00:29 AM »
PO at it again :)
Nahhh. It's the factory job. JDM bike
CB550 K0
Offline strynboen
« Reply #10 on: February 28, 2015, 09:15:23 AM »
its a parking /pos light 5 w...ifr the key are turned in pos 3..... rear light, and this littel light in main light go on. and cut the rest elektric off
.used in most  europa..
i hate all this v-w.... vords
Offline Powderman
« Reply #11 on: February 28, 2015, 02:01:32 PM »
Factory optional air conditioning hook up.  :) Might also be the blinker fluid level indicator light that was also optional.
« Reply #12 on: February 28, 2015, 03:21:04 PM »
You sure it's not for the CB radio?
Offline goldarrow
« Reply #13 on: February 28, 2015, 03:29:48 PM »
That's only available as an option on the Custom bikes if being run in the US
FTFY
CB550 K0
