Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Yes, this can happen because the gears aren't aligned quite right while you're trying to shift. Try shifting while you rotate the final drive sprocket by hand, you'll probably find you are able to shift through all gears then.mystic_1
