Author Topic: re filling damper in gauges  (Read 4850 times)
Offline guitarkev66
« on: March 02, 2015, 04:54:49 PM »
Has anyone attempted to refill the needle dampers in the gauges if so how and what to refill with?
1970 K0 CB750 JDM Blue
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Offline trueblue
Re: re filling damper in gauges
« Reply #1 on: March 03, 2015, 04:16:38 AM »
There was a thread on this a couple of years ago, the fella was using rc car diff oil or some such thing. I used speed hut gauges.  ;D
1979 CB650Z
Offline chewbacca5000
  • I polish covers!
« Reply #2 on: March 03, 2015, 04:57:20 AM »
Aparently the lid is glued on.  Remove the glue and refill.  Greenjeans did one recently.  Thread about opening up the "pot" by removing the glue
http://forums.sohc4.net/index.php?topic=136617.msg1539982#msg1539982
http://forums.sohc4.net/index.php?topic=117107.0
« Last Edit: March 03, 2015, 05:01:44 AM by chewbacca5000 »
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: March 03, 2015, 06:25:04 AM »
I believe the concensus was to use 50,000 weight silicon differential oil (for RC cars)    I got it at a hobby shop.
I can double-check on the weight when I get home tonight, but I think that was it.
  • I polish covers!
« Reply #4 on: March 03, 2015, 06:27:31 AM »
How much to top me off?  I'll send you the gauges.
Offline greenjeans
  • 1972 CB750K2
« Reply #5 on: March 03, 2015, 06:29:41 AM »
I found that both of mine still had some sort of fluid in them.   Do your needles bounce around after things are cleaned ?
The thing that took me the longest was finding that impossibly small circlip after it shot across the room.
« Last Edit: March 03, 2015, 06:32:57 AM by greenjeans »
  • I polish covers!
« Reply #6 on: March 03, 2015, 06:39:46 AM »
Some of my gauges were stored upside down, and the fluid leaked out.  Have a good collection that would benefit from a refill.  Gotta love those circlips.  Sounds like a fun time.  More fun if someone else is doing it.
« Reply #7 on: March 03, 2015, 07:17:35 AM »
Hate when that happens.  I literally cleaned my whole garage to find a valve retainer clip that shot into the abyss >:( ;D
Offline iron_worker
« Reply #8 on: March 03, 2015, 08:01:25 AM »
Been there. Except I gave up and bought a few from CycleX which I had to have shipped to Canada... and of course I found the "lost" one after the new ones arrived.
Typical.
IW
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: March 03, 2015, 08:18:21 AM »
Same here except it was a retainer clip/keeper from a cb175 twin which is about half the size of one from a 750, my kid and I turned the garage upside down but we eventually found it.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: March 03, 2015, 08:22:52 AM »
Worse:  scouring the entire garage to find the clip that you lost, only to realize that you didn't actually loose it, or even worse that the part you were working on didn't use a clip in the first place  :-[
mystic_1
- John Augustus Shedd
Offline guitarkev66
« Reply #11 on: March 03, 2015, 09:56:43 AM »
Thank you for the information.  This will be my first gauge restoration a little nervous will hate to screw up K0 gauges.  What do you seal the damper back up with?  Anything else I should know before I tackle this project?   I will post my project as soon as I get my parts....
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Online 01Thomas
« Reply #12 on: March 03, 2015, 11:45:02 AM »
I found my lost valve retainer after some 15 years and 3 relocations... It had buried itself not in the garage but in my workbench.
Typical.
IW
Offline greenjeans
  • 1972 CB750K2
« Reply #13 on: March 03, 2015, 05:34:34 PM »
I sealed my up with some nail polish
Offline David B
« Reply #14 on: March 03, 2015, 09:50:11 PM »
I'll bet Marcel has a great solution too and is willing to share his method. Also, he has a specific color of Testors Orange paint that he uses on the tips of the needles. I think it's supposed to be a good match to the stock color. He told me once but I wasn't smart enough to write it down.   ::)
« Last Edit: March 04, 2015, 04:21:27 PM by David B »
DB
Offline guitarkev66
« Reply #15 on: March 04, 2015, 03:41:43 PM »
does the speedometer have an oil damper?  I removed the cover and it doesn't look like there is a place for oil...Maybe I'm not seeing it and don't really want to take it all apart if I don't have to.  I also purchased BA9S LED bulbs today for fear of the old bulbs getting too hot and melting my new gauge faces.  Plus I hate when I am out ridding and the gauges start to condensate on the inside of the face which is why I usually ride with my light off.  I am hoping they look close to stock I got the warm white led"s
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
« Reply #16 on: March 04, 2015, 10:00:55 PM »
It's disappointing that there isn't someone here in the states that can rebuild gauges at a reasonable cost.
There is a guy on the Kaw Triples forum that does a complete restoration for a little over $100 a gauge.  I'll be sending him my Kaw gauges, they are not even close to being accurate.
  • I polish covers!
« Reply #17 on: March 05, 2015, 05:51:05 AM »
Why not you?
« Reply #18 on: March 05, 2015, 08:02:38 AM »
Why not you?
Not into it.   Should be you!
  • I polish covers!
« Reply #19 on: March 05, 2015, 03:24:02 PM »
Why not you?
I would, but get so frustrated when those little clips fly off into the abyss!  I maybe to tackle a refill as it seams cheap enough.  I noticed that they now sell reusable trim rings so you can change face plates at will.
