Author Topic: feeling frustrated and stupid - where to start - my F1 wont start!  (Read 3790 times)
Offline fr33man
Hi,
sorry for being a noob - but my 750f1 wont start - it has battery - started fine a few month ago - now there is no reaction from starter switch and i cant push nor kickstart it ..
battery is fully charged and all lights are working fine..
was looking at wirechart and bike befroe and my brain melted - hope there is a friendly soul that can point me in a good direction to start! as i do consider myself skilled enough to solve it and have worked out some other electrical issues before lol .. feels like monday morning!
:P
Re: feeling frustrated and stupid - where to start - my F1 wont start!
« Reply #1 on: March 04, 2015, 03:11:12 AM »
Did you check the kill switch?
That is not an insult, btw, it happens.  ;D
« Reply #2 on: March 04, 2015, 03:13:39 AM »
The next step  safety features, I mean neutral switch and clutch switch, based on the schematics, your bike has both.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #3 on: March 04, 2015, 03:52:03 AM »
Initial checks :-
+1 re safety cut outs (these stop power to coils)
Is there a spark at plug (in neutral, remove plug and with metal contact between plug body and engine kick over with ignition on)
Is there fuel getting to plugs (are they wet)
Is there compression
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline fr33man
« Reply #4 on: March 04, 2015, 04:08:13 AM »
Kill switch is not off .. didn't test it internally
« Reply #5 on: March 04, 2015, 07:40:26 AM »
Fuses?
« Reply #6 on: March 04, 2015, 07:46:05 AM »
Do you get a neutral light?
Offline fr33man
« Reply #7 on: March 04, 2015, 07:59:50 AM »
Yes to neutral
Offline fr33man
« Reply #8 on: March 04, 2015, 08:00:56 AM »
Fuses are good as well
« Reply #9 on: March 04, 2015, 08:07:07 AM »
Checked the clutch switch?
Offline fr33man
« Reply #10 on: March 04, 2015, 08:09:06 AM »
How is that done? Press the clutch and try to start?
« Reply #11 on: March 04, 2015, 08:19:34 AM »
In neutral?
Offline fr33man
« Reply #12 on: March 04, 2015, 08:20:16 AM »
Yes in neutral
Offline fr33man
« Reply #13 on: March 04, 2015, 08:45:30 AM »
starter spins with direct power from battery
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: March 04, 2015, 09:59:06 AM »
Have you tested for +12V at the coils, when the kill switch is on?
(black/white wire)
Even if the safety interlocks are buggered you should be able to kick start it.
mystic_1
« Last Edit: March 04, 2015, 10:00:42 AM by mystic_1 »
- John Augustus Shedd
« Reply #15 on: March 04, 2015, 09:59:30 AM »
When checking ignition... do not remove a plug to test with, use an extra that you might have. If plugs are old time to buy a set.
Test with starting fluid, spray in all carbs or in the filter box. Engine will start if you have ignition.
I guess the coils have no power due to the kill switch or neutral circuit including the clutch switch.
Offline fr33man
« Reply #16 on: March 04, 2015, 10:33:13 AM »
coils have 12v from kill switch and clutch switch is ok -
but i still wonder how i get the starter to spin when i press the button?? shouldnt that be main issue as that is what i have observed now - and before there were both spark and fuel as it was running fine before? please enlighten me =)
« Reply #17 on: March 04, 2015, 10:38:35 AM »
 Check the points with a static light. Everyone should learn how to check the timing anyway.
 Edit, brain fart this has nothing to do with the engine not cranking over just an engine not starting.
« Last Edit: March 04, 2015, 11:09:12 AM by Don R »
« Reply #18 on: March 04, 2015, 10:49:09 AM »
When you push the button, the starter relay gets power and connects the high amp power to the starter.
Hmm, did you check the lead from battery to the relay and from relay to the starter?
Offline fr33man
« Reply #19 on: March 04, 2015, 11:02:37 AM »
the solenoid gets 12 v from battery and when i push the starter button i get 12 v on the yellow/red wire coming from the button but nothing happens.. is that a dead solenoid then?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #20 on: March 04, 2015, 11:04:53 AM »
Solenoid? With everything on, key, kill switch, in neutral, Try quickly and carefully jumping across the two solenoid terminals with a screw driver. If you get the starter to jump it's time to take the solenoid apart for cleaning.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #21 on: March 04, 2015, 11:10:04 AM »
Before you dig into the solenoid, connect one of the low amp connectors to + and the other one to the - on the battery.  It should click the solenoid, ie close the circuit.  If that happens, the solenoid is ok, and your problem is either diode, neutral swtich or clutch switch.
http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php#class
As you can see from the diagram, the solenoid is not just + and - but on the - side is the "safety feature"
« Last Edit: March 04, 2015, 11:11:51 AM by 70CB750 »
Offline Nayl
« Reply #22 on: March 04, 2015, 11:36:02 AM »
Just maybe you have the same issue I did when I first got my F1, it would light up, but would not crank.  Turned out a connector had fallen loose during shipping, I found it under the left sidecover, was a green wire iirc.
Offline fr33man
« Reply #23 on: March 04, 2015, 01:00:53 PM »
tried to take the solenoid apart for cleaning - now its broken =) got another one - but im out of battery so put in back on charge - hope its a brighter day tomorrow =)
thanx for all your input!
« Reply #24 on: March 04, 2015, 02:10:46 PM »
There is a spare green ground wire there. Just ignore that.
