Author Topic: Shotgun blast when ignition turned off  (Read 1580 times)
Offline wjustinleigh
« on: March 09, 2015, 09:02:13 AM »
I recently rebuilt my 71 cb500 head, got everything put back and am having some trouble getting it going.  I have 120-130 psi in each cylinder so that looks good, have spark and can tell gas is getting to the chamber but despite fluttering I can't get it to catch.  I can't get a timing gun on it since I can't get it to idle so maybe that's an issue.  It's been apart for six months, and I was only planning to have it apart for a month so I hadn't drained and refreshed the gas so that may be an issue too.  The weird part is after attempting to start it for a while when I turn the key off it gives a shotgun blast backfire.  I'll stop attempting to start it, wait a minute, then click the ignition to the off position and bam the neighborhood is under attack.
I can't think why the ignition would have anything to do with unspent fuel in the exhaust finding a hot spot.  Any thoughts?
71 cb500
72 cb500
07 Bandit 1250
Re: Shotgun blast when ignition turned off
« Reply #1 on: March 09, 2015, 09:05:11 AM »
Cam installed correctly? (180deg out?)
« Reply #2 on: March 09, 2015, 09:06:48 AM »
As for timing you can do a 'static time' with a simple test light and the engine not running but ignition on. It will get it very close and you can eliminate that possible cause.
Offline rb550four
« Reply #3 on: March 09, 2015, 09:14:22 AM »
Static time with a test light? You have to be at least close, what did you use to determine spark timing?
after it's fired, when you  turned the key on, that should have burned the fuel in the combustion chamber up. Are you introducing more fuel or how clogged up are the carbs?when it's burned or out of fuel there's nothing to give a blast, it has to be coming from somewhere.
Offline ANDY W
« Reply #4 on: March 09, 2015, 09:18:40 AM »
so what u saying is that the engine wont start and then after u done cranking u shut the ign switch to the off position and it backfires out of the exhaust?
« Reply #5 on: March 09, 2015, 09:23:52 AM »
Good points, thanks!  This was the second go around on the cam due to improper cam timing so I was careful to have it on the T 1-4 mark with the notch flush to the surface so I feel pretty good about the cam timing.  It has dyna coils and ignition, so it's possible that the ignition wires are flipped but I was pretty careful with that first time around.  I'll verify tonight.
Good point on the static timing, forgot about it this time, will do that tonight.  In the past it was always close enough to get an idle and adjust with the gun.
Carbs are very clean, completely disassembled, cleaned (twice).  Feel very good about the clean carbs with functional jets.  I'm not introducing more fuel anywhere, and even if I was I don't know why it would care about the position of the key.  Maybe that's just coincidence but the timing was exactly when the key was turned and replicated three times.
I think the fuel has to be passing through unburned, due to the attempts to start it probably had some flooding which would pass the gas through.  The whole engine is still cold though, I don't know how it could be hot enough to backfire.
ANDY W - that is exactly correct.
71 cb500
72 cb500
07 Bandit 1250
Offline ANDY W
« Reply #6 on: March 09, 2015, 09:33:55 AM »
is it backfiring when u crank it? or only when the key is switched off?
« Reply #7 on: March 09, 2015, 09:40:52 AM »
Only when the key is switched off.  When cranking it sounds good, just doesn't quite catch.
71 cb500
72 cb500
07 Bandit 1250
Offline ANDY W
« Reply #8 on: March 09, 2015, 09:52:11 AM »
id start by checking for power to the ignition coils when the ignition switch is on and off. sounds like ur getting power to the coils with ur ign switch is in the off position not the on position, causing a spark plug to fire and ignite the unburnt fuel from cranking with no spark
« Reply #9 on: March 09, 2015, 10:05:32 AM »
I can tell I'm getting power to the coils when switched on - I can hold the spark plug against the head and see the spark.  I can also hear it trying to start, which I wouldn't get without a spark.  I'll put the tester on the coil to see if I can see anything odd when flipping the ignition on/off.  I was thinking there might be some grounding issue that was creating a spark somewhere when moving to the off position.
71 cb500
72 cb500
07 Bandit 1250
Offline stewonepot
« Reply #10 on: March 09, 2015, 10:17:47 AM »
Hi try swapping the points wires around blue yellow.
maybe!
regards Stew
« Reply #11 on: March 09, 2015, 10:20:49 AM »
maybe!
regards Stew
+1   ;)
« Reply #12 on: March 09, 2015, 10:23:56 AM »
I was going to trace them back to make sure they were backwards before I tried it, does it damage the engine to try starting it with the coils reversed?
71 cb500
72 cb500
07 Bandit 1250
« Reply #13 on: March 09, 2015, 10:25:59 AM »
No.  PMs
« Reply #14 on: March 09, 2015, 11:05:06 AM »
I just use one of these for a simple static timing light, can use a meter also.   There have been some other very good suggestions so far.
« Last Edit: March 09, 2015, 11:07:36 AM by ekpent »
« Reply #15 on: March 09, 2015, 11:13:35 AM »
If you have a Dyna S ignition and Dyna's 3-ohm coils, you have a bigger problem... If you have their 5-ohm coils, it should start, but the battery is probably low. The backfire is unburned fuel that is being lighted by the coil when the power is switched off (which makes it spark) while the intake valve is open on a cylinder. If the battery is low, especially with the 3-ohm coils, this can happen.
« Reply #16 on: March 09, 2015, 11:30:42 AM »
Mixed up yellow and blue wires from ignition to coils?
I had similar problem when I had mounted the ignition rotor 180 degrees wrong. Switch yellow and blue confirmed it when it worked. I corrected rotor and connected yellow-yellow and blue-blue.
Offline stewonepot
« Reply #17 on: March 09, 2015, 12:26:45 PM »
Cheers Guys
I think you are right on the wiring.
Stew
« Reply #18 on: March 09, 2015, 07:34:40 PM »
This is a characteristic of some electronic ignition systems; they may generate a spark either when switched on or off. My bike almost started once, simply by switching the Gerex ignition on! ;D
Offline Bodi
« Reply #19 on: March 10, 2015, 05:43:50 AM »
It's not just with electronic ignition, a points setup will spark whichever coil is powered when you turn the key off. The problem here is that the engine isn't firing normally but he obviously has fuel.
Reversed points leads should still fire the points - but at the wrong time near BDC: that usually gives you plenty of carb backfires when it sparks before the end of the intake stroke.
I would check that it's sparking at all - plug held against engine case - and also confirm that the static timing is close. Is this a new DYNA installation?
« Reply #20 on: March 10, 2015, 08:51:51 AM »
Dyna installation - ignition and coils.  It's not a new installation though, I had it on there before I took the head apart.  Checked static timing, it's good.  Plugs have spark (test that against the head first).  Tried with ignition leads switched and didn't get any engine fluttering at all.  I found the adjusting screws on the carbs were only out about 3/4 turn so I put them to 1 3/4 (book says 1 1/2 - 2) but no change.
Since the screws were in so far it probably wasn't getting much air, I'm thinking it flooded it.  Maybe when I stopped for a bit it disapated then when I switched the key off it would backfire.  New plan is to pull the plugs, re-test compression and spark, replace any questionable plugs, then try it fresh with the new carb screw settings.
71 cb500
72 cb500
07 Bandit 1250
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #21 on: March 10, 2015, 11:02:42 AM »
I'm with Fly I would 2X check the cam position. If it's one or two degrees it will want to start but not easily. You can get some popping and backfiring.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
