Author Topic: Head work — Long Beach  (Read 1365 times)
Offline SKTP
« on: May 13, 2015, 09:55:50 AM »
So last rebuild I really didn't touch the head at all.
Anybody know someone in the LA/OC area that has experience porting and lapping cb750 heads?
I saw this http://cbrzone.com/sohc.html But my bike is not going to be a race machine. I just want this to be the last time I ever take the engine out (finger's crossed).
I want it to be clean and dependable.
Any leads appreciated
thanks
also — prices, How much should I expect to pay?
I live in Long beach.
« Last Edit: May 13, 2015, 09:57:53 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline vames
Re: Head work — Long Beach
« Reply #1 on: May 13, 2015, 10:38:25 AM »
Maybe give Carpy a call to see who he uses. He probably has a list of buddies who do decent work.
Offline Pat_at_APE
    • APE Race Parts
« Reply #2 on: May 13, 2015, 10:57:47 AM »
We can do that work for you.  We do standard valve jobs also.   If you head needs anything we have it in stock.
Regards,
Pat at APE
ph: 661-256-7309
« Reply #3 on: May 13, 2015, 11:49:08 AM »
Quality parts as APE has is worth the little extra compared with cheaper alternatives you can find on ebay.
CB750? Ported head wake the engine. I should check valves and guides at the same time. Old engine might need new valves plus stiffer springs for a hotter cam. Cylinder job too, 836... New clutch? Std clutch plates with stiffer springs for street use and more hp
Engine kit here http://cbrzone.com/sohc.html
MRieck on this forum is a master of head porting.
The most waste of money I have done is to not install all needed parts of correct quality. But I am married with my bike that I have spent some $$$$ on since 1979 when I bought it.
« Last Edit: May 13, 2015, 12:03:06 PM by PeWe »
« Reply #4 on: May 13, 2015, 02:08:47 PM »
Chris,
For near local, I would recommend APE (you have the link).  They are up next to Willow Springs.
I can see why you'd want to go local rather than ship.  In addition to APE, Mike Rieck and Cycle X can also do the work.  Mike is The Shaolin Master of Porting.
I'd have to imagine that there's someone in our backyard in LB, but I don't know who.
