Author Topic: CB750K2 front sprocket side to side play  (Read 1320 times)
Offline jeremyillingworth
« on: October 02, 2015, 12:45:05 PM »
I'm installing new sprockets and chain. I noticed when the new Sunstar front sprocket went on it has some side to side play. I put the old one back on I noticed, now that I'm looking for it, that it has some play but not as much. Is it normal to have some play?
I also laid the new sprockets on top of the old to check the wear. They were actually were good and the teeth were pretty much the same, but if I hadn't done this I wouldn't have noticed that the previous owner swapped a 46 onto the rear, while I ordered a stock size 48. I guess I'm getting some extra acceleration.
jeremy
Offline dhall57
Re: CB750K2 front sprocket side to side play
« Reply #1 on: October 03, 2015, 03:23:05 AM »
Ive replaced chains and sprockets on both of my 750's several years ago. Remembering back I think their was just a little movement(side to side) on the front sprockets. Think thats just normal.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #2 on: October 03, 2015, 04:04:43 AM »
I think some of them had play - my K0 for sure - and on some models they went to tight fit; the 78F engine had none.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: October 05, 2015, 08:29:48 AM »
Just replaced mine a month or two ago. They have a little play.
--Evan
1975 CB750K "Rhonda"
Offline riffman12
« Reply #4 on: October 05, 2015, 11:02:34 AM »
yes some play side to side is normal
is there a lot more play on the new one vs the old one? Is it the same width?
« Reply #5 on: October 05, 2015, 11:39:10 AM »
Yes, my front sprocket has rather much play as always. It will line up easier with rear then :)   CB750K6-76
I use threadlocker on the small M6 bolts keeping the washer locking into the sprocket. One bolt went loose last year, one lost...
