Author Topic: Baking Dupli Color  (Read 2955 times)
Offline rocco
Baking Dupli Color
« on: November 08, 2015, 02:08:41 PM »
Hello all,
Quick question about baking Dupli-Color, the can says to do it at 300F for 2 hours, however, I've read through every other thread on this site and no one does that hot for that long. Should I consider doing it shorter and colder?
Thanks,
Reilly
1978 Honda CB550K.
"It is vain to do more with what can be done with less" - William of Occam (Occam's Razor)
Offline Powderman
Re: Baking Dupli Color
« Reply #1 on: November 08, 2015, 02:13:20 PM »
150-200 for an hour should be plenty. If doing in a oven I leave the heat on but the door cracked so it isn't contained.
Offline rocco
« Reply #2 on: November 08, 2015, 02:14:47 PM »
Thanks,
I'll be doing it in a "hot box" in the garage. With a hairdryer I guess. I think my heat gun is too hot, puts out 480F on the lowest setting...
1978 Honda CB550K.
Offline rocco
« Reply #3 on: November 08, 2015, 05:41:12 PM »
Maybe a stupid question but...
I was baking the parts in a box. When it was done, I picked up the box to move it into my house to cool so they wouldn't go below 60F, one of them fell over, the oil pan, and bumped up against the head. Not hard or anything. Put the paint came off real easy. Now I know they were still really hot. So part of me is saying, well, the paint is soft because it's hot. The other half of me is saying, the engine is going to get hot a lot. Is it just this first curing time that the paint can't be touched until it cools?
1978 Honda CB550K.
« Reply #4 on: November 08, 2015, 07:03:15 PM »
What's wrong with your controlled temperature oven with the timer?
Offline Jore
« Reply #5 on: November 08, 2015, 09:59:14 PM »
I've been using my gas kitchen oven with no problem whatsoever, I just got a large faced thermometer to monitor it doesn't get to hot or too cold. If you wait a week between painting and baking it hardly smells, it also helps if you dry parts in the sun for a couple of days prior to baking.
After baking the paint is usually really though and doesn't scratch or peel if you run your fingernail over it. So far the only problem I had was with some paint curling, but that was do to the layer being too thick and just waiting a day to bake after painting.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #6 on: November 09, 2015, 07:20:15 AM »
Its all in the prep.
30 min @ 250F was a I did.  All items have held up well.
Offline przjohn
« Reply #7 on: November 09, 2015, 07:57:01 AM »
Did you use a primer before applying the heat resistant paint? If so, was the primer rated for heat resistant? If the primer was not rated for heat resistance then maybe that is your problem. I have never primered an engine and just used VHT directly to the clean surface and cured as directed, never had a problem.
Offline rocco
« Reply #8 on: November 09, 2015, 08:44:15 AM »
The paint came off as irregular chips. Not a peeling pattern. I could drag my nails across it with no issue today.
1978 Honda CB550K.
Offline rocco
« Reply #9 on: November 09, 2015, 11:33:09 AM »
Haha, definitely not what I had expected. From initial degreasing  to cleaning to re-painting, it's probably the longest part of my build!
Once again, thanks for the info!
1978 Honda CB550K.
« Reply #10 on: November 09, 2015, 12:29:57 PM »
You can also do the hot box method and run it through 2 heat cycles to help it cure.  Most likely, the outside was firm but the paint underneath was still uncured.  Since you are not using an actual oven, I would err on cooking it longer.
