Hi,
I managed to buy a new old stock genuine Honda CB750F1 top gasket set (part no 06110-393-S00).
It has only two rubber 'o' rings for the oil feed to the cylinder head. (part no 91310-426-000) 11x2.5mm.
When I dismantled the motor it had two fitted with the cylinder base gasket and two fitted with the cylinder head gasket.
My question is have Honda deleted the requirement for other two 'o' rings from the cylinder base gasket or the cylinder head gasket?
Not sure where to fit the two supplied 'o' rings!
regards
Skoti.
