Author Topic: Performance Front end swap out?  (Read 12143 times)
Offline RainCityRider
  • BRAAAP!
  • instagram @raincityrider76
« on: April 01, 2016, 09:20:26 AM »
I have 3 1978 CB 750K's. I would like to modify one of them. I'm thinking replace the fork, F & R Brakes, and shocks for starters. Just looking for advice and guidance on what will fit and work best with minimal modifications.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline slikwilli420
  • Master of Disaster
Re: Performance Front end swap out?
« Reply #1 on: April 01, 2016, 01:19:44 PM »
Sky is the limit. Gl1000 is a popular swap and is easy. Modern forks are another but require more work. You could go with some betor or ceriani forks if budget and skills allow. Any choice will give better brakes and handling. What goal ate you trying to accomplish?
« Reply #2 on: April 03, 2016, 12:57:53 PM »
What slikwilli410 said.
If you want to stay period correct, swap in a 1975-1976 GL1000 entire front end (including brakes).  If period correctness is not a restriction, the sky is the limit with modern USD fork swaps and brakes.
  • BRAAAP!
« Reply #3 on: April 03, 2016, 08:54:58 PM »
I want this bike to be a resto mod / performance cafe / rat bike. Open to making stuff work. But I'am not a moto mechanic. I have rebuilt one of my engines and done lots of moderate mechanical and cosmetic up grades. I'm a bicycle mechanic (25yrs) by trade so am mechanically inclined. I think a more modern front end with good brakes would be my preference. My other bikes are stockers, so I wanna play with this one a little.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
« Reply #4 on: April 03, 2016, 09:35:26 PM »
If it's going to be a resto-mod, then I would recommend a modern USD fork swap.  Buy an entire front from a mid-2000s GSXR (triple trees, forks, brakes, calipers, rotors, axle, and even the wheel if you like the forged style wheel).  You will only need to modify the steering stem -- press it out and press in a 750-length stem.  If you want spoke wheels, you can buy a new hub from Cognitomoto.com and relace to a rim and bolt on the modern rotors (the hubs are spaced to match the rotors).  You can buy a front end cheapest from a motorcycle wrecking yard, second cheapest from craigslist, third cheapest from ebay, and maybe somewhere in between there from the classifieds here.
For instance, I am selling forks and brakes from a 2007 GSXR600 in the classifieds.
« Reply #5 on: April 03, 2016, 10:02:15 PM »
If you don't like the look of USD forks on these old bikes, there are some very good RSU {Right side up} alternatives, usually cheaper as well.... ;)
« Reply #6 on: April 03, 2016, 10:42:59 PM »
Prior Gen Yamaha R6 front is a good conventional (non-USD) fork option.
« Reply #7 on: April 03, 2016, 11:32:52 PM »
If you go to USD... What do you plan for the back of the bike.?
« Reply #8 on: April 04, 2016, 01:01:25 AM »
Honda CBR 900 919, triumph triple 955 and 955 I and daytona up to 2004/5 use Showa RSU forks that are fully adjustable for rebound and damping in 43 and 45mm, the last model GSXR1100 with RSU forks was the 1989, 43mm , they are great forks, used a lot in classic racing, lots of adjustment, harder to get though. I just bought a complete set of the Triumph 955 I Showa forks with brakes and triples for $150 , an absolute bargain, great looking forks too... ;)  I'll post pics if anyone is interested..
  • BRAAAP!
« Reply #9 on: April 04, 2016, 04:28:36 PM »
@Retro Rocket I would love to see the pics!
For the rear end I think some piggy back shocks and a swing arm that will take discs would be sweet. But don't know if there are aftermarket swing arms?
Will the steer tube from the yamaha or the triumph swap over or do i need to get adapters or a different steer tube?
I found this for a gsxr swap.
https://cognitomoto.com/products/gsx-r-fork-on-honda-cb750-frame-conversion-stem?variant=512244181
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
« Reply #10 on: April 04, 2016, 04:37:13 PM »
There are lots of cheap Chinese piggy back shocks around, they are rubbish, there's been lots of threads about them here on the forum, they can be bought for as little as $16 dollars each direct from China... ;D :o
Here's the triumph front end, very similar to the Ohlins RSU front ends... I paid $150 for all this, I'll remove the triumph from the calipers.. ;)
« Reply #11 on: April 04, 2016, 04:38:47 PM »
How can you not be installing that??!!
« Reply #12 on: April 04, 2016, 04:44:21 PM »
I will be Steve, they are for the 1000, by the way, these are showa forks, the same company Honda has used since the 60's.   ;)
  • BRAAAP!
« Reply #13 on: April 04, 2016, 04:48:00 PM »
Dang, Looks like a good deal. From what I have found. I need to find that kinda deal! Will the steer tube swap right over or will you need to mod it?
I don't want crap shocks. So I will look into what is a good set. Any idea if there is a way to put disc on the rear too?
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #14 on: April 04, 2016, 04:48:42 PM »
RainCity,
Check out my CB550 Interceptor build. I used Yamaha R6 RSU forks and Works Performance nitrogen charged piggy back shocks. I really good setup for a period correct resto-mod.
http://forums.sohc4.net/index.php/topic,27159.0.html
Coincidently, I'm selling the shocks if you're interested. They work flawlessly.
I'm going to shell out big for some Fox Podium RC1 shocks.
« Reply #15 on: April 04, 2016, 05:02:38 PM »
I'm not using those clamps, I'm having custom clamps made to my specs with a new tube, I was only after the forks and brakes... ;)
« Reply #16 on: April 04, 2016, 05:13:07 PM »
Jimmy, pm me price and length of the shocks..thanks..
 Retro,  Them Triumph forx look the business..
« Reply #17 on: April 04, 2016, 05:42:03 PM »
Be aware that front end swaps are not usually a bolt on and go deal if you want to successfully improve the performance of your bike.  You will need to become very knowledgeable about motorcycle suspension and geometry and there will be necessary experimentation before you get it right.  I have found that improving stock components often yields better results faster...better oil, springs, fork braces, steering dampeners, cartridge emulators are all relatively easy improvements.
« Reply #18 on: April 04, 2016, 06:18:38 PM »
Agreed, I wasn't wanting to go into that here, there's plenty of other threads that cover that.. ;)
They do indeed Frank, same forks used on the Honda Fireblades of the late 90's, early 2000's, I'll stick some racetech valves in them and they'll be as good as the exorbitantly expensive Ohlins... ;)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #19 on: April 04, 2016, 06:49:11 PM »
No they won't but you can keep telling yourself that.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #20 on: April 04, 2016, 06:51:02 PM »
BTW, always check overall fork length.
A lot of sport bikes have forks much shorter than your stock forks. Try to find forks of similar length.
« Reply #21 on: April 04, 2016, 07:08:03 PM »
That can be dealt with quite easily, I've had spacers made that screwed straight into the top of the fork, relatively easy to have done, you can either paint the extension or have it hard chromed. I'd rather go for a quality fork/disk/wheel or what ever, and make it fit, for a "straight" conversion length and offset should both be addressed... Also, using original size wheels and tires, instead of modern 17's, adds more height to the front end..
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #22 on: April 04, 2016, 08:34:23 PM »
Are these what you're refering to Mick? Not sure who made them or if they're commercially available for a wide variety of forks but it sure would solve the length issue.
« Reply #23 on: April 04, 2016, 09:12:33 PM »
Very similar, I had an engineer friend thread some steel tube {same ID and OD as the forks} both top and bottom so I could just screw it on and fit the stock preload adjusters to the top, all I needed was a similar sized spacer internally so the preload adjuster worked as intended, if I had a lathe I could have made it myself, a good friend just bought a big lathe so that should make things easier in the future...
Like this..
« Last Edit: April 04, 2016, 09:18:11 PM by Retro Rocket »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #24 on: April 04, 2016, 09:33:30 PM »
Like this..
That's a much nicer solution. Stealthy.
The one I found looks odd with the preload adjuster sunk so deeply.
