Author Topic: Ignition Static gap adjustment question  (Read 4773 times)
Offline Darkdragono
« on: April 05, 2016, 04:31:26 PM »
Hello,
        I have a 76 cb550k and am in the process of setting up the timing but when i gap the points at "full open" with 0.015in(0.04mm) the back plate adjustment on 1-4 doesn't get to the point where my light flickers when i go to the f mark on 1-4, so my question is am i going past max lift of the cam where the points are closing and that's why i'm getting these results?
Offline Deltarider
  • I'm back
Re: Ignition Static gap adjustment question
« Reply #1 on: April 05, 2016, 11:26:38 PM »
First, it should be between 0,3 - 0,4mm.
Then, make sure cam is at it heighest when you measure. BTW, what breakerpoints do you have? Original (TEC) or aftermarket like Daiichi?
CB500K2-ED Excel black
Offline DaveBarbier
« Reply #2 on: April 06, 2016, 05:18:34 AM »
Also, your question seems wrong. There is no 'static gap adjustment' because there is no 'dynamic gap adjustment'. It's just 'gap adjustment'. I just want to be sure you're not confusing gap with static timing.
Offline Darkdragono
« Reply #3 on: April 06, 2016, 03:16:17 PM »
Thx for the replays guys but here's a pic of my clymer book where im getting this info from. its all Original (TEC)
« Last Edit: April 06, 2016, 03:21:19 PM by Darkdragono »
Offline wowbagger
  • Not much of an
« Reply #4 on: April 06, 2016, 04:32:30 PM »
Dino did a great video on this process:
« Last Edit: April 06, 2016, 04:34:51 PM by wowbagger »
Offline Darkdragono
« Reply #5 on: April 06, 2016, 05:03:16 PM »
thx yeah i did watch the video but he never showed the feeler gauge size he only said it that's like telling somone to get them a 1/2 inch wrench blind folded at least to me i have to see it to learn it.
Offline wowbagger
  • Not much of an
« Reply #6 on: April 06, 2016, 05:23:33 PM »
Set your gap to 0.03mm. The 0.04mm should not be able to slide into the gap.
Offline Darkdragono
« Reply #7 on: April 06, 2016, 05:48:00 PM »
Well with those size's the feeler gauge is so thin it flex's but in the video that does not happen so it would really be 0.12-0.16 inch or in millimeter 0.30-0.41 am i wrong to say so.
Offline DaveBarbier
« Reply #8 on: April 06, 2016, 05:51:44 PM »
Ah dwell, that makes sense. I always thought of those as separate things. Carry on.
Offline wowbagger
  • Not much of an
« Reply #9 on: April 06, 2016, 05:54:37 PM »
Yeah, you're right. Should be .3mm.
Offline Darkdragono
« Reply #10 on: April 06, 2016, 06:01:09 PM »
ok cool so i think i understand now my book is misinformed and show the wrongs size's thanks everyone for clearing that up  :D
Offline jonda500
« Reply #11 on: April 06, 2016, 06:03:51 PM »
0.004" = 0.1mm!
0.012" = 0.3mm
0.016" = 0.4mm
I like to set mine at 16 thou - because as the points heels wear down the gaps will get smaller
John
A starter clutch thread:
Online carnivorous chicken
« Reply #12 on: April 07, 2016, 05:33:57 AM »
0.004" = 0.1mm!
0.012" = 0.3mm
0.016" = 0.4mm
John
Not sure how this works -- as the points wear the gap should get slightly larger, and they should wear more or less evenly unless they're installed slightly off. On 350fs, 400fs, and 550s, I set the gap closer to .3 than .4 as it is better in terms of timing.
Offline Deltarider
  • I'm back
« Reply #13 on: April 07, 2016, 07:57:29 AM »
I'm with jonda500. Over time gap will decrease.
Offline Darkdragono
« Reply #14 on: April 07, 2016, 05:13:17 PM »
I made a drawing in paint for the understanding for gap wear and yes 0.16 is the way you want to set it up.
« Last Edit: April 07, 2016, 05:27:32 PM by Darkdragono »
« Reply #15 on: April 07, 2016, 05:45:35 PM »
Gotcha, I thought Jonda was talking about uneven wear of the surface due to misalignment, not the surface that meets the cam.
Offline Deltarider
  • I'm back
« Reply #16 on: April 07, 2016, 11:58:21 PM »
Gotcha
I don't understand  the drawing. Left breakerpoint is not shown as it sits in reality so...
Offline gtmdriver
« Reply #17 on: April 08, 2016, 12:02:38 AM »
One of the best investments I ever made was in a set of go/no-go feeler gauges.
Two sizes on the same blade.
If a 0.3mm gauge will fit and a 0.4mm won't then the gap's correct.
Offline Darkdragono
« Reply #18 on: April 08, 2016, 03:54:37 AM »
Gotcha
Well my point with the drawing was not to be identical on each side so to show that the setup would have to be completely different to increase the point gap with wear.
so here's another drawing with sides that look the same but notice the contact point has to be at the top in order to increase the points gap over time with wear.
Offline Deltarider
  • I'm back
« Reply #19 on: April 08, 2016, 04:59:51 AM »
I'm sorry but the drawing still doesn't represent real live. You've got the 1+4 points depicted wrongly. Gap decreases over time on both set of points. Anyway start with opening of 0,4 mm and you'll have reserve.
Offline DaveBarbier
« Reply #20 on: April 08, 2016, 06:33:30 AM »
He's not trying to show how points work. Above it was said that the points decrease over time then other members refuted saying that it would increase over time. He just drew it up showing if it was to decrease or increase over time how it would have to be positioned.
Offline tennesseebreeze
  • Better to be lucky than smart.
« Reply #21 on: April 08, 2016, 06:41:06 AM »
Hello,
While setting my ignition timing plate with a 12v light, the way the Honda shop manual said; I also did not see the light go out or flicker. I'm curious what that means for the timing and if I we should consider it a failed adjustment.
'79 CB750F, '73 CB500K2, '78 CB400A, '71 CL100
Offline Deltarider
  • I'm back
« Reply #22 on: April 08, 2016, 07:21:43 AM »
Pardon me, I know what it was about. It was about whether the pointsgap increases or decreases when the fiber part wears. Well, as well for 1+4 as for 2+3 breakerpoints gap decreases. In his picture he puts it's increase for the one set and decrease for the other. That's just not correct.
1. Is ignition key switched on?
2. Is emergency switch in the 'run' position?
3. If 1 and 2 are answered with yes, does light come on when you open the breakerpoints with your fingers?
4. If yes on 3, it's not adjusted rightly yet. If the light still does not come on, it indicates there's no current.
« Last Edit: April 08, 2016, 07:35:30 AM by Deltarider »
« Reply #23 on: April 08, 2016, 07:42:47 AM »
I was saying that the light does not go OFF when I turn the plate left and right. It remains on. So there is no adjustment at which the light comes on, because it's always on.
Offline Deltarider
  • I'm back
« Reply #24 on: April 08, 2016, 08:10:10 AM »
You should start with setting the breakerpoints gap. Just rotate the crank (you can use the kickstarter for this) until gap is at it's widest. Forget about marks and lights in this stage. Set the gap between 0,3 and 0,4mm. Then and only then it makes sense to set the timing. You should start with 1+4. Now turn crank until F 1,4 (yellow mark in the pic) is in line with the mark. Look for the right timing by slowly moving the base plate until light comes on (or flickers) at F 1+4. After that you can adjust 2+3. First the pointsgap by adjusting the breakerpoint when it is open at it's widest. Again, forget about marks and lights in this stage. After that and only then it makes sense to set the timing of 2+3. Now turn crank until F 2,3 is in line with the mark. Look for the right timing by slowly adjusting the 2+3 plate until light comes on (or flickers) at F 2+3.
I don't know how experienced you are, but if you feel you're lost completely, you could start by first bringing both sets breakerpoints and the 2+3 plate in the middle of their adjusting range and start from there. It helps us when you attach pics.
« Last Edit: April 08, 2016, 08:41:00 AM by Deltarider »
Offline DaveBarbier
« Reply #25 on: April 08, 2016, 04:07:56 PM »
I'm not arguing with you about that, I'm on your side :).
He's not arguing with you either. He specifically says:
The guy just drew up a picture showing how it would have to be set up for the gap to increase and how it would have to be set up for the gap to decrease knowing full well that this isn't reality. I just think you missed his original point. No problem :)
I'm leaving this thread now because I can't help the guy out. You guys are much smarter on this stuff than I am.
Offline Deltarider
  • I'm back
« Reply #26 on: April 09, 2016, 12:11:13 AM »
Aahh... I got it now. Sorry.
