Author Topic: Stuck away from home - troubleshoot help  (Read 1757 times)
Offline greenjeans
  • 1972 CB750K2
« on: May 15, 2016, 06:03:11 PM »
74 CB750.   New harness (partsnmore for a K0). New handlebar switches (also partsnmore for a K0).   I've got at least 750 miles on the set up.
I'm out riding in BFE with no frickin internet.  Currently, I'm posted up at a parking lot and am getting Internet.  But, I'll be offline for the next 3-4 hours.
Bike cut out.  It was the fuse.  Have many spares - keeps popping them.  Looked in the headlight bucket - all normal, nothin hot.    I took the right handlebar switch apart - nothing jumping out at me.  As soon as I put the switch to "ON" it pops the fuse.  If I disconnect the blk/white wire in the bucket, it will not pop the fuse, but of course will not fire the bike.
Can anyone think of a way I could bypass the switch so I can ride it home?  I do have a length of wire in my tool roll.  Or, anything else I could try before I get somebody to come get me ?
I'll be back on-line around 10ish
Offline Mantree
Re: Stuck away from home - troubleshoot help
« Reply #1 on: May 15, 2016, 06:46:46 PM »
I had a issue with the main fuse piping because of a short on the ignition positive that runs through the start stop switch try running a new wire to the ignition coil hot
Sent from my ME302KL using Tapatalk
« Reply #2 on: May 15, 2016, 06:55:58 PM »
My K1 was blowing fuses, turned out the rear brake light switch was grounding out.
Check all wiring, good luck GJ.
Offline Mantree
« Reply #3 on: May 15, 2016, 07:30:01 PM »
If we look at the wireing diagram they wire that you disconnected only goes to the coils so my first move would be to jump that strait to the ignition wire if it still blows then the wire is shorted and you can just replace it.  No the problem is that honda used a odd sized bullet conector at 3.9 mm and you will need a open berral crimper.  What you can do is replace them with standard crimp conectors to get you home hen do a proper fix when you are home and have time to wait for new conectors.  Your first move should be to follow that wire to the coils and see if you can find any damage.  When mine whent it was melted to the frame close to the coil, if you are lucky you might find where the wire is bad and could just heat shrink it to get home then replace it when you are  home.
Sent from my SM-G900V using Tapatalk
« Reply #4 on: May 15, 2016, 07:38:40 PM »
 I'd jump from the black/white in the headlight bucket directly to where the black/white usually plugs in at the coils.
Offline pmanning
« Reply #5 on: May 15, 2016, 08:09:42 PM »
Or, disconnect the black wire going to your horn.  Connect the horn black to the two black/white wires - one on each coil.  With the key on the bike should run.  Kill switch and horn will not function but you should get home.
« Reply #6 on: May 15, 2016, 08:30:26 PM »
so simple
Offline greenjeans
  • 1972 CB750K2
« Reply #7 on: May 16, 2016, 06:59:57 AM »
I love you guys.  Got her home this morning.  Used the wire from the horn as suggested.  Gonna go through everything this afternoon.
« Reply #8 on: May 16, 2016, 07:10:46 AM »
Glad to hear.  Let us know what you find.
Offline Mantree
« Reply #9 on: May 16, 2016, 07:43:49 AM »
Good to here
« Reply #10 on: May 16, 2016, 07:43:59 AM »
Good call on that P-Man  -  Do we have a new electrical Guru here ??
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #11 on: May 16, 2016, 07:47:52 AM »
What a great fix!
--Evan
1975 CB750K "Rhonda"
Offline greenjeans
  • 1972 CB750K2
« Reply #12 on: May 16, 2016, 09:00:40 AM »
I will be adding a wiring diagram to my tool roll from now on.
Thanks again guys.  All things considered, it turned out to be a pretty good adventure
« Reply #13 on: May 16, 2016, 09:05:54 AM »
I had the same problem due to a new cheap aftermarket rear brake switch. The wire with clear insulation around the plug connection glided down the wire and plug had contact with engine case. Fuse blew when using the brake.
Other side has 12V constantly, ground contact her will short regardless of brake used
This is a design flaw by Honda. Main fuse should not blow due to short circuit in brake light circuit. Better if the rear light 5A fuse feed brake light too. I had idea to feed with the brake switches with the additional brown wire seen in head light bucket.
- It would be nice to know exact what the problem was.  Right handle bar switch /harness?
« Last Edit: May 16, 2016, 09:26:23 AM by PeWe »
Offline edwardmorris
  • Youngish
« Reply #14 on: May 16, 2016, 10:27:51 AM »
What a great fix!
+1
Time to rig up a plug and play kit for this to keep in the tool pouch.
Offline evanphi
  • Apparently I'm an
« Reply #15 on: May 16, 2016, 10:55:55 AM »
What a great fix!
+1
Great idea.
--Evan
Offline greenjeans
  • 1972 CB750K2
« Reply #16 on: May 17, 2016, 06:57:17 AM »
Well, there's definitely a short in the blk/white wire somewhere in the handlebar.  Switch is coming off today.  Yuck
Update:  aftermarket bars that I had to drill.  Looks like I had left a burr.  Insulation had a good slice and left a pretty good chunk of wire exposed.  Can't believe it didn't happen sooner.  Must have settled and made the contact.
« Last Edit: May 18, 2016, 09:09:50 AM by greenjeans »
Offline Mantree
« Reply #17 on: May 18, 2016, 02:45:49 PM »
Get a debuting tool if you are drilling alot of holes it will make nice clean holes for pass throughs and hen if there is space a rubber grommet will protect the wire
