Author Topic: The Amalgam: honda past meets present, take 2! or 3?  (Read 42438 times)
Re: The Amalgam: honda past meets present, take 2! or 3?
« Reply #200 on: July 26, 2017, 10:28:14 AM »
So, where does the exhaust exit, it appears your radiator would be blocking it, were it a sohc4.
Offline jag767
« Reply #201 on: July 26, 2017, 10:38:21 AM »
It's behind the radiator. You can kinda see it here
« Reply #202 on: July 26, 2017, 10:41:39 AM »
Yes...figured you would not forget something important like that...
It is looking good.
Offline jag767
« Reply #203 on: July 26, 2017, 10:49:25 AM »
It is looking good.
Lol. There are only a handful of big things left to complete.  I'm sending out the tank to be fitted with the fuel pump this week. The offset sprocket should arrive shortly allowing me to weld in the chain roller. I need to make 2 plates for the 1 remaining motor mount, and I need to source metric tubing for the exhaust. I'm very undecided on what muffler I want, but I will likely go with a cone engineering setup of some kind. Since I need these welds to be flawless, I will tack up all the stainless with my mig, but will have a local guy tig it for me. If I only had a damn tig machine I'd just do it myself. Migging stainless with Flux core wire is a pain!
« Reply #204 on: July 26, 2017, 08:37:53 PM »
« Reply #205 on: July 26, 2017, 10:42:27 PM »
Wonder what the Delkevic mufflers would be like on it?  Light stainless design and whole system for 750/550 is inexpensive...
It would not be quiet I am sure...
The oil pan came out really nice.  Had a shop been charging that would have been an expensive custom piece.  Don't neglect insuring the bike for its value and a good appraisal by someone who know the effort and cost of builds and replacing same needs to be your appraiser.
Bet you are eager to throw a leg over her and go for a ride.
David
Offline jag767
« Reply #206 on: July 27, 2017, 03:14:44 AM »
 Haha I can't imagine what it would have cost. Wait til you see the other parts he is 3d printing and laser cutting for me.  If any of you ever need any stuff like that pm me, I will put you in touch with him.
As far as exhaust, I had a crazy idea I may try to do. Rather than buy a muffler, I may just make one but it will be more of the exhaust box look, by having a complex shape on the outside made up of a bunch of Lazer cut panels, but inside it's just a muffler. I like this idea because i've yet to hear an exhaust on this motor that I like, and since I'm not running a cat I have no idea what to expect. This gives me a lot of room to tune the sound should I desire and I could even chamber it if need be.
David
Offline jag767
« Reply #207 on: August 09, 2017, 07:23:18 PM »
Well we are getting closer. Got the chain region all wrapped up today, well minus a spacer or two. And look, a skateboard wheel!
« Reply #208 on: August 09, 2017, 07:51:33 PM »
Interesting improvised tensioner.  It should work and you'll have plenty of spares available if it wears down.
Offline jgger
« Reply #209 on: August 09, 2017, 07:59:21 PM »
That would be a twofer, 4 rollers for the chain and a seat pan out of one skate board! :D
Offline jag767
« Reply #210 on: August 10, 2017, 12:53:34 AM »
Lol I can't take credit, I have seen it done before and bought it as a kit. The only diffefence is I modified it to be used just to help route the chain and provide clearance. The chain still gets adjusted at the axle.
Offline jag767
« Reply #211 on: August 10, 2017, 12:54:16 AM »
Hahahaha  ;D
« Reply #212 on: August 10, 2017, 11:51:12 AM »
Oh no, not the skateboard brat-style seat! I liked the more comfy white one you had mocked up.
Offline jag767
« Reply #213 on: August 10, 2017, 01:25:17 PM »
Haha no, seat is staying. Wont stay white though
Offline jas67
« Reply #214 on: August 10, 2017, 01:48:02 PM »
I'm happy to hear it won't be staying white.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
« Reply #215 on: August 10, 2017, 08:19:33 PM »
XLNT!
Offline jag767
« Reply #216 on: August 15, 2017, 11:23:41 AM »
Currently doing the 2 into 1 y pipe, never did this before, took a little trial and error to make a plan. I'm waiting on the muffler before I go much further.
« Reply #217 on: August 17, 2017, 11:41:16 AM »
Does the stock Honda motor/ECU/wire harness use a A/F sensor, too? If so, are you going to weld a bung for it or bypass it?
Offline jag767
« Reply #218 on: August 17, 2017, 06:57:53 PM »
I haven't decided yet. If I can bypass it I will most likely. 1 less wire.
« Reply #219 on: August 18, 2017, 11:57:04 AM »
Still, it would be nice if you could get someone to jailbreak that CB500F ecu and unlock all of the hp and torque in that motor. I am not sure if you would need that AF sensor to do that properly.
Offline jag767
« Reply #220 on: August 18, 2017, 05:49:19 PM »
Tuning it isn't an issue at all. I can opt to weld in the bung and throw a bolt in it where it would t be seen. I've done that on a few bikes. Since this bike is officially going to be used for shows, I don't know how insanely aggressive I need to be. At least for the next year, it won't be ridden. I already have it set to be in the progressive NYC international show at the Javits center, and I'm trying for a few invitational shows.
Offline jag767
« Reply #221 on: August 19, 2017, 05:11:16 AM »
Someone order a fuel pump?
Offline jag767
« Reply #222 on: August 20, 2017, 05:11:28 AM »
Here's a good one. So the chain kept trying to derail on me and I couldn't figure out why. I mean I went nuts looking. Broke out a micrometer and measured it all, and it's almost perfect, and way better than a stock bike. Still couldn't find it. 3 hours I looked, and a buddy of mine comes over and figures it out in 5 minutes. The skateboard wheel is too narrow and the chain is flopping over it. Wider wheel and problem fixed, hahaha. What a pain!
Offline jas67
« Reply #223 on: August 20, 2017, 06:04:40 AM »
I would definitely wiring in all sensors to the ECU (AF, O2, etc) if you want it to run right.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline jag767
« Reply #224 on: August 20, 2017, 06:50:47 AM »
Lol you can make it run fine without it. Little 02 simulator and youre good.
