Author Topic: So I AM burning oil! (Still)  (Read 10345 times)
Offline Davez134
Re: So I AM burning oil!
« Reply #25 on: November 23, 2016, 10:30:15 AM »
Just want to say how much I love the frame kits. This took me 15 minutes to get to this point!
Just looking at seals on number 1 cylinder, nothing looks obviously wrong. Will post close ups once I get springs off.
« Last Edit: November 23, 2016, 11:17:08 AM by Davez134 »
Offline Davez134
« Reply #26 on: November 23, 2016, 05:22:04 PM »
While Im waiting to remove the valve springs and do a proper leak down test,  I wanted to pressurize the cylinder. I used my air compressor and threaded my compression gauge with the check valve removed into the spark plug hole. I removed the rocker arms, so I know the valves are closed. I heard what sounds like a decent air leak from the cam chain tunnel area. I'm assuming this is not good, as that would mean that air is leaking past the rings. My questions so far:
Does this not mean much because I did this on a cold engine?
If it is a ring and not a valve, I would assume the compression would differ between cylinders right? (it does not, was 160+ on all but that was when warm)
How do I go about diagnosing the right way? Ive tried to read about it, but not comprehending it (Ive never dealt with a problem like this before) I'm getting a leak down tester Friday.
Thanks!
« Last Edit: November 23, 2016, 05:26:18 PM by Davez134 »
« Reply #27 on: November 23, 2016, 06:54:03 PM »
Any oil in the cylinder?  How much pressure?  Check your other cylinders.  Could be many reasons on the leak. Wouldn't freak out about it yet.
You could be down on one cylinder and it run fine and have no issues for a long time.  I forget the spec for the variance...if it is outside the recommended variance between cylinders it starts affecting running.
David
Offline Davez134
« Reply #28 on: November 23, 2016, 07:50:04 PM »
David
So, i feel a little better now. I tried my other cylinders and they sounded the same as far as the amount of air leaking out, so i concluded pressurizing the cylinders cold and just listening for air is useless. I figured I'd try it while I was waiting for parts/correct tools.
« Reply #29 on: November 24, 2016, 02:24:09 PM »
If your compression test read 160psi across all 4 bores, they it is highly unlikely you have an issue with rings on any cylinder. Also, the intermittent issue of smoke upon startup but not when warm, is further indication (in my opinion) that the issue is in the head, not the block. Rings burn oil the hotter the oil/engine becomes. And a 10% variance within the 4 bores for compression is the Golden Rule.
Yep, the old rule of thumb was that, if it blows smoke under acceleration its rings, if it puffs at start up or during deceleration, its valves....
« Reply #30 on: November 24, 2016, 09:37:27 PM »
Ride the bike to about and give throttle to higher rpm on 2:nd or 3:rd gear, close throttle completely, wait a few seconds and open  again. If you see a cloud behind the bike it is the valve seals. Easier if a friend drive behind that can smell eventual oil burn too.
I had a car that could cause real problems for the other behind me :) Thick nice smelling cloud.
Oil smoke during accelearation, rings as written by others.
- Is it really only too wide end gap, too tight must cause problems too, or?
- Only oil rings that affect this?
« Last Edit: November 24, 2016, 09:41:00 PM by PeWe »
Offline Davez134
« Reply #31 on: November 25, 2016, 11:12:08 AM »
Two things to report. First of all, I have intake and exhaust seals. No obvious damage, but I'm going to pull and replace.
Second, that valve spring removal tool is great! Works just as in the video! I love tools that work as they are supposed to.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #32 on: November 25, 2016, 11:13:46 AM »
Were you able to get all valves? 2 and 3 EX would be the ones I would be worried about using that tool.
--Evan
1975 CB750K "Rhonda"
Offline Davez134
« Reply #33 on: November 25, 2016, 11:20:47 AM »
I don't need to remove those, but I held the tool against those 2 (2/3 exhaust) to check clearance, and there is just enough. The top of the tool rests against the frame rail, but squares up enough to give it a tap.
Offline evanphi
  • Apparently I'm an
« Reply #34 on: November 25, 2016, 11:41:53 AM »
perfect. good to know if I need it.
You should make a little video of using it on our bikes. There aren't many on youtube about the tool.
--Evan
Offline Davez134
« Reply #35 on: November 25, 2016, 11:59:26 AM »
I'll make one on the install. I was making it for removal, just a half assed video, and my phone fell off where it was propped.
Offline evanphi
  • Apparently I'm an
« Reply #36 on: November 25, 2016, 03:36:05 PM »
;D
--Evan
Offline Davez134
« Reply #37 on: November 27, 2016, 11:05:27 AM »
Here ya go: removal..
Installation..
Offline RevDoc
« Reply #38 on: November 27, 2016, 11:13:47 AM »
 ;D Glad to see it worked out so well for you, Dave.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline evanphi
  • Apparently I'm an
« Reply #39 on: November 27, 2016, 12:17:54 PM »
Thanks for the videos! I'm going to send them to my father in law. We were talking about the tool today. He's a mechanic.
--Evan
Offline Davez134
« Reply #40 on: November 27, 2016, 12:32:20 PM »
No problem. And just to let you know, I replaced all 8 seals while I was in there, and it worked just fine on 2/3 exhaust valves too.
Offline evanphi
  • Apparently I'm an
Re: So I AM burning oil! (Valve spring removal video)
« Reply #41 on: November 27, 2016, 02:55:04 PM »
Excellent. Good to know for future. :D
--Evan
« Reply #42 on: November 28, 2016, 09:46:50 AM »
Dave  push the down a small amount and rock the valves back and forth to check stem clearance. Check the exhaust valves first
Offline Davez134
« Reply #43 on: November 28, 2016, 09:56:15 AM »
Well, I already have it back together. Valves seemed to be solid in the guides, but I didn't actually measure. The head only has 5000 miles on it so I didn't even think it would be that. Should have measured though 😕
How exactly should I check the valve stem clearance with the head installed? Hondaman's book only shows with the head off...
« Last Edit: November 28, 2016, 04:00:10 PM by Davez134 »
Offline Davez134
« Reply #44 on: November 28, 2016, 09:58:23 AM »
Started her up today, still smoking. And after replacing all valve seals with ones I had from CycleX, seems to be a little smoke from all 4! Maybe I need to go on a long ride to burn off residual oil? But, I did do a proper leak down test, and I'm only losing 3%.
« Last Edit: November 28, 2016, 10:52:28 AM by Davez134 »
Offline Davez134
« Reply #45 on: November 29, 2016, 08:13:58 PM »
I rode it hard today. Little smoke on startup, but nothing after it was warm. Pulled back in the driveway, after idling for 30 seconds I gave it throttle and there was a small puff of smoke. I'm fearing it is a guide/stem clearance issue now. Going to give it a few more rides though.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #46 on: November 29, 2016, 09:26:22 PM »
Great thread, thanks to all contributors.
I have a motorcycle problem.
Offline Davez134
« Reply #47 on: December 07, 2016, 09:26:49 PM »
Well, I don't think it's good news. Still smoke from #1 on startup. Also after idling for a bit when warm and giving it gas, there is a puff of smoke still. It is running great otherwise. I fear the guides may be worn, causing movement of the valve stems and warping the seal. Only one way to find out I guess.
Offline halllzy
Re: So I AM burning oil! (Still)
« Reply #48 on: December 07, 2016, 11:08:55 PM »
Are you getting a funky smells?  My 750F has grown been a bit smoky upon start up but it does not smell like burning oil.  Way less mid summer, more smoke spring and fall (not really temperature dependant either)
 +1 to all contributors
Sent from my Nexus 6P using Tapatalk
« Reply #49 on: December 08, 2016, 06:29:07 AM »
This engine has fresh honed bores, new piston rings and correct end gaps not too small?
