Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
You can glass bead blast the powder coat off. Far easier than Aircraft Stripper.
I hope when it's time for the final build that you install your forks correctly. They're reversed in the picture
Forks are still backwards
Agreed, but the downside is how heavy they are. The weights I'm using are steel instead of lead and they are 1/4 oz each, so there are five on either side of the rim (10 total) opposite the stem. I bet if I had used a plastic push-in stem it would be more like 2...
Yeah, but my rim is already powdercoated and I didn't want to drill out the stem hole. The only ones I could find were the ones I bought. 'WPS' or something brand.
