Author Topic: 1972 CB500 - Gas tank retrofit - what others will work ?  (Read 6591 times)
Offline danielzink
« on: January 13, 2017, 06:53:33 AM »
Hey All,
New guy to the forum.
New 1972 CB500 owner and I have a quick question.
Do other year/displacement gas tanks fit without modification ?
Thanks, Dan
Offline whitjonw
  • Motorcycle Maniac
Re: 1972 CB500 - Gas tank retrofit - what others will work ?
« Reply #1 on: January 13, 2017, 05:22:27 PM »
Why do you ask, I wonder ?
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline BPellerine
« Reply #2 on: January 13, 2017, 05:30:04 PM »
there is one year cb650 tank that looks good.
1978 CB 750K ard and webers
another anfob
Offline danielzink
« Reply #3 on: January 13, 2017, 07:53:55 PM »
to keep the thread on point...please feel free to contact me with individual questions....
Otherwise...the original tank is in a state of disrepair...
Would a 1975 CB550 tank fit ?
Maybe a 1976 Cb400 tank ?
Upon researching...the 'bay....a specific search for "1972 CB gas tank" turns up a pretty slim selection...
Thanks for everyone's replies so far..
« Last Edit: January 13, 2017, 07:55:28 PM by danielzink »
Offline whitjonw
  • Motorcycle Maniac
« Reply #4 on: January 14, 2017, 03:13:49 AM »
I fitted a '74 550 tank to my'73 500. Same tank through 1976 for the K series. In fact, when I changed my search to 550 that's when I found my tank as there were a whole lot more tanks available using 550 in the search.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline danielzink
« Reply #5 on: January 14, 2017, 07:37:46 AM »
yes to a '75 550.
I should amend my earlier reply that any 500/550 tank from a 4 cylinder 500/550 will fit. The 500 Twin is a slightly different beast.
You certainly can make other tanks fit, but it will require some fab work. But the 500/550 is a plug-and-play solution.  :D
Perfect. Thank you both so much !
Offline Scott S
« Reply #6 on: January 14, 2017, 09:28:51 AM »
 Be aware that the petcock changed over the years. Somewhere around '75-76, Honda went to a one year only version that was prone to leaking and is not rebuildable. If you get a tank that uses that threaded on petcock (versus the kind that bolts on with two screws), be prepared to spend $100 on a new petcock. Factor that in when buying a replacement tank.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #7 on: January 14, 2017, 09:37:41 AM »
Yep. The 1975 CB750K has that petcock.  Pricey for the OEM Honda petcock and it's not readily available.  You need to keep your eye out on eBay for a NOS one.
« Reply #8 on: January 14, 2017, 01:45:04 PM »
The 400 tank wilm probably fit and have more room underneath than the 500 tank.
« Reply #9 on: January 15, 2017, 04:46:07 AM »
I wonder if a CX500 tank would fit. I'll have to check that... have both.
Offline Johnie
« Reply #10 on: January 15, 2017, 07:07:19 AM »
Let me know if you think any of these will help you out? Got them from a closed Honda dealer.
« Last Edit: January 15, 2017, 07:09:45 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline whitjonw
  • Motorcycle Maniac
« Reply #11 on: January 15, 2017, 06:52:23 PM »
You are welcome and good luck in your search !!
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline roach374
« Reply #12 on: September 20, 2020, 08:12:09 PM »
Sorry to reawaken a zombie thread, but I'm in the same boat. @danielzink, did you find a CB550 tank that fit? Confirmed that the length of the tank is different and the seat needs to be farther back?
« Reply #13 on: September 21, 2020, 12:43:29 AM »
Thats only if you use K3,  K0 to K2 are OK except petcock. Never tried F
« Reply #14 on: September 21, 2020, 12:51:28 AM »
F tank and late K tank with lid over fuel cap have different length seat...
Offline Bankerdanny
  • Endeavor to persevere
« Reply #15 on: September 21, 2020, 05:47:53 PM »
An F seat will work with a K tank,  but there is a gap between the tank and the seat. The F tank only works with the F seat,  to use a K seat you would have to figure out how to move the hinge.
Offline XC204
« Reply #16 on: September 22, 2020, 04:34:36 AM »
Of its a modified bike (different seat) a cb650 tank fits with a few more front mount posts and rubbers need shortening ,I made a new rear mount (tank is longer) and I tucked the coils in tighter by modifying the stock coil mounts because tank has narrower tunnel.
