Author Topic: Ole' Blue CB750  (Read 12551 times)
Offline WesTenRacing
Re: Ole' Blue CB750
« Reply #50 on: February 10, 2017, 02:19:57 PM »
I don't want a side cover or custom look.  I like the look of the exposed tank. I am going for a cleaned up functional look.  Something that could have been done in the late 70's.  The oil tank will not be covered and the left side will be open.  The electrics will be housed behind and under the seat.
Re: Ole' Blue CB750
« Reply #51 on: February 11, 2017, 09:00:12 AM »
Installed a steering stabilizer.  Used the threaded hole on the right lower triple and made up a tab and welded to the frame.
The threads in the triple are poor. I'll have to address that.
Re: Ole' Blue CB750
« Reply #52 on: February 11, 2017, 11:40:24 AM »
Ive never seen one mounted cross ways like that [I have 3 bikes with stabilizers]
I would have welded the tab on the R side.
Re: Ole' Blue CB750
« Reply #53 on: February 11, 2017, 05:03:44 PM »
Hey Stev-o
A lot of late model bikes have them installed crossways.
I like it because it's tucked up out of the way and not interfering with anything.
I also want the adjuster on the left so I don't have to take my hand off the throttle to adjust it.
I do appreciate you checking in and advising.
Re: Ole' Blue CB750
« Reply #54 on: February 11, 2017, 05:10:03 PM »
I'm looking for some advice on relocating my side stand as far forward as possible so that it is more hidden when up.
I did some testing with steel tube propping the bike up at the forward location and it seems fine.  I just don't want to go ahead and change it if I'm missing something "obvious".
TIA.
Offline innovativems
    • Innovative MotoSports
Re: Ole' Blue CB750
« Reply #55 on: February 11, 2017, 06:05:17 PM »
TIA.
I relocated mine on my cb400f forward. I used the stock bracket and an adjustable aluminum side stand from an rc51.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Re: Ole' Blue CB750
« Reply #56 on: February 19, 2017, 09:52:58 PM »
Finished the rear brake set up today.  I shortened the pivot/arm shaft and cut the frame tube to suit.
The brake "lever" was made by cutting the brake pedal off at the spline and making and welding a lever to it.
The brake rod just had to be "adjusted" to clear the swing arm.
I made up a stay rod but I'm not sure if it's the one I'll ultimately use.
All of these parts will be painted or powdered black.
Still have to figure the brake light switch.
« Last Edit: February 19, 2017, 10:00:09 PM by WesTenRacing »
Re: Ole' Blue CB750
« Reply #57 on: April 01, 2017, 11:40:14 AM »
I'm going to purchase tires and am looking for some advice. I'll be using the stock wheel sizes.  After some research I think the tire of preference is an Avon Road Rider.  It seems to be a quality product with the appearance I am looking for.
My questions have to do with sizing. 1.  How big of a tire will fit my rim sizes?
                                                     2.  Is there "optimum" sizing that suits these bikes?
TIA.
« Last Edit: April 05, 2017, 08:31:23 PM by WesTenRacing »
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: Ole' Blue CB750
« Reply #58 on: April 01, 2017, 12:05:57 PM »
Nice clean job on the rear set.
Re: Ole' Blue CB750
« Reply #59 on: April 01, 2017, 12:09:32 PM »
Thanks!  You and a bunch of others here set the bar pretty high.  I'm just tryin' to keep up.   ;)
Re: Ole' Blue CB750
« Reply #60 on: April 01, 2017, 12:18:43 PM »
Avon's are great tires.   I run 100/90-19 & 120/90-18's
Re: Ole' Blue CB750
« Reply #61 on: April 01, 2017, 05:20:26 PM »
+1 on the rearsets...this is gonna look good
Re: Ole' Blue CB750
« Reply #62 on: April 14, 2017, 09:02:37 PM »
Test fit my Godffery duals before completing the teardown. All fit with no issues.   8)  I'm not running a cable driven speedo so I'll make a spacer to replace the drive assembly.
Now I can complete the frame mods.
Offline palepainter
Re: Ole' Blue CB750
« Reply #63 on: April 14, 2017, 09:22:52 PM »
That brake set up looks killer.  I got rid of my speedo drive as well.  It a bit rough and made some bad noises.   :)  So I just split the housing and used the spacer that is internal.  I use GPS speedo from an app for my Iphone that will be mounted on my existing dash bracket.
Re: Ole' Blue CB750
« Reply #64 on: April 14, 2017, 09:34:11 PM »
Thanks.  I like duals.
Does the internal spacer look good?  What's the difference between it and a "homemade" spacer?
Offline palepainter
Re: Ole' Blue CB750
« Reply #65 on: April 14, 2017, 09:43:13 PM »
Yes.  It looks pretty good.  I polished it right up.  It has one machine groove in it, but looks just like a spacer.  Really, the only difference was..I don't have a lathe, and this was a fast accurate solution for me.  :)
« Last Edit: April 14, 2017, 09:56:46 PM by palepainter »
Re: Ole' Blue CB750
« Reply #66 on: April 14, 2017, 09:47:27 PM »
Nice!  Thanks for the pic.  I may do the very same.   :D
Re: Ole' Blue CB750
« Reply #67 on: April 15, 2017, 10:48:22 AM »
Relocated the side stand forward and removed the remaining frame tabs, cleaned up some tubes and added some lightening holes.  They're not finished yet. They still need to be chamfered. Then it'll be on to the right side.
After that I'll install a Gordon frame kit.
Offline GV1390
  • Express Gratitude.
Re: Ole' Blue CB750
« Reply #68 on: April 19, 2017, 04:21:46 AM »
Looking good as usual, Jan! Can't wait to see this thing in person.  :D
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Re: Ole' Blue CB750
« Reply #69 on: April 19, 2017, 04:56:01 PM »
I would be tempted to weld tubes in them holes.
Re: Ole' Blue CB750
« Reply #70 on: April 20, 2017, 08:50:06 AM »
I get the whole speed holes thing but I wonder if taking it from the engine mounts will weaken it.
Re: Ole' Blue CB750
« Reply #71 on: April 20, 2017, 04:14:34 PM »
There are tubes welded in.  ;)  I wouldn't compromise the structure just for aesthetics.  We'll.....................not knowingly!   And yes, I realize that I have not "lightened" anything.  The tubes and welds weigh more than the material removed.   :o
Re: Ole' Blue CB750
« Reply #72 on: March 29, 2019, 03:04:25 PM »
Hello everyone!
I'm finally getting back to this project.
I would like to purchase a new fuel tank and would like some advice.
I'm a little hesitant to make a purchase without getting feedback from you guys.
TIA
Jan
« Last Edit: April 09, 2019, 06:01:53 PM by WesTenRacing »
Re: Ole' Blue CB750
« Reply #73 on: April 09, 2019, 06:03:24 PM »
Anyone?
Re: Ole' Blue CB750
« Reply #74 on: April 09, 2019, 08:09:18 PM »
Hello everyone!
TIA
Jan
What advice are you looking for?
