Author Topic: 1978 750F The start of a big project.  (Read 17718 times)
Offline Jnel
Re: 1978 750F The start of a big project.
« Reply #25 on: February 12, 2017, 11:59:58 AM »
When i get home, I'm going to try the EZ Out approach i guess.  I have a small drill press that i can set up and get a good straight, center bore to remove some material and get ready for the ez out or maybe a re-tap.  No way for me to weld an extension on it.  I soaked it for two days, put the heat to it and still snapped it.
I used a hand Impact wrench on a lot of the parts and with good luck. This one... not so much luck.
Offline Jnel
« Reply #26 on: February 12, 2017, 12:04:06 PM »
I'm definitely going to use anti-cease on everything  when it goes back together.
Offline Jnel
« Reply #27 on: February 12, 2017, 01:49:26 PM »
I've had some good luck with bigger sizes. But this little guy is going to be a pain.  I just know it.  I'm feeling drill and tap in my future and hopefully not oversize drill.
Offline Jnel
« Reply #28 on: February 12, 2017, 04:17:19 PM »
Hey... thats good info.  I have the bits.  I'll rig up the drill press.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline Jnel
« Reply #29 on: February 12, 2017, 05:31:56 PM »
Don't worry if i drag you to charleston, it's going to be for more then a little job like that.
Offline Jnel
« Reply #30 on: February 20, 2017, 07:40:38 PM »
Worked through some tough grinding and sanding. Went down to metal in 95% of the frame. But... its done. My fingers are killing me.  A labor of love im told.  I had no idea how bad it was.  I promise, i will never sit by and let another bike get that bad.  Know i feel pretty good about its condition. Cleaned off a bunch of tabs, extra metal associated with the center stand, side covers, and wiring.  Much cleaner now.  I almost started to dress up the original factory welds, but passed on that idea.
Offline Jnel
« Reply #31 on: February 20, 2017, 07:56:56 PM »
I'm going to hold off on cutting the back end.  I'm thinking about using the original plastic cover back there.  I thought it would bring a little bit of the original equipment to the party.  Plus... i think its a good place to tuck a custom brake light in there. Maybe I'm crazy, but you can get a pretty big light in there. The original light can almost fit inside the hump. When it comes to being seen... bigger and brighter is a good feeling for me. So this idea is not finalized yet.  I think an oil tank back there is a possibility as well.
Offline Jnel
« Reply #32 on: February 20, 2017, 07:59:34 PM »
Frame kit?  What you talking about Willis?
Offline Jnel
« Reply #33 on: February 20, 2017, 08:06:22 PM »
Oh ... I've seen this.   Very cool.  I thought it was great for race applications.  You think this for me?  Wait... you think im going to be rebuilding?  I think not. But i am going to make sure that timing chain is right befor it goes back in.  Who sells this kit?
Offline Jnel
« Reply #34 on: February 20, 2017, 08:12:34 PM »
Man... things changed so much !   But i cant tell you how excited i am to learn all of this.  I can't thank you enough.  I'm a sponge these days and it's great to see all of the advacements for these old girls.
Regards from newb.
« Reply #35 on: February 20, 2017, 08:36:21 PM »
I recognize that oil tank/seat.  My buddy fabricated it and his wife did the upholstery.
Offline Jnel
« Reply #36 on: February 20, 2017, 08:49:09 PM »
750CRF...  thats cool.  Did he ever go into production?   This photo that i grabbed from Pintrest, i believe, is responsible for my motivation on the back end of this project.  I'm a fan of form and function and this is a pretty good job of meeting the needs of both.     Got any contact info on your friend?
Offline Jnel
« Reply #37 on: February 21, 2017, 06:19:39 AM »
Cal...  do you have any ideas for exhaust. I like the original sound of the 4 into 4.  But now that I'm building a different style of bike and needs to sound a little more threatening.  But not too loud. Performance is important but I want to be able to sneak home too.  What's popular?
Offline Jnel
« Reply #38 on: February 21, 2017, 06:20:51 AM »
I I like 4 into 2 but only for symmetry. 4 into 1 seems like the choice for a lot of people
Offline Jnel
« Reply #39 on: February 21, 2017, 07:23:29 AM »
Thanks Cal.  Centet stand is history!
Appreciate your hep man.
Offline Jnel
« Reply #40 on: February 24, 2017, 07:49:58 AM »
I still can't believe that i did this.  I'm completely responsible.  Its a long sorted story and im sure I'll need therapy as a result. But this 17 years of gunk built up in the carbs and the gas tank is worse.  4 cans of carb cleaner and a lot of brushing.  I'm starting to come down now from the buzz now.  I promise I'll never do this again.
They look better now.  Everything moves pretty smooth.
Offline Jnel
« Reply #41 on: February 24, 2017, 07:51:27 AM »
I donk think they'll ever look prety again!
« Reply #42 on: February 24, 2017, 08:27:51 AM »
Send them to Nils (restocycle.com) and they will look better than they did when they were new.
Offline Jnel
« Reply #43 on: March 02, 2017, 03:57:27 PM »
Ant thought on how this would work for a motor or work stand?  Was thinking it would fit on a standard motor stand that I have already.
I'm open to suggestions
Thanks
Jnel
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #44 on: March 02, 2017, 04:07:29 PM »
You will have to trim the angle iron down to fit around the output shaft and seal area. The other side may need trimming to not interfere with the clutch cover. Someone on here put a stopper at the top also to allow inverting the engine and removal of the bottom case half.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Jnel
« Reply #45 on: March 02, 2017, 04:10:12 PM »
Yes... fit to work.  My stand rotates 360.  But you thinl this will work?
Offline Jnel
« Reply #46 on: March 02, 2017, 04:37:27 PM »
Ok... great!  Its simple.  I can whip this up in no time and get this motor off the small bike lift and on the stand were I can get all around it.   Baby steps.   Thanks for the help and support as always.  And I thought YouTube was the best source if info.   What was I thinking?
Thanks guys
Offline JoeCooley
« Reply #47 on: March 02, 2017, 10:31:32 PM »
Good luck with the project. I wish I had a stand when I did mine recently.
Offline Jnel
« Reply #48 on: March 04, 2017, 11:10:51 AM »
This worked out pretty well.  It's going to make things so much easier.
Offline Jnel
« Reply #49 on: March 04, 2017, 12:01:34 PM »
You mean.... like this?
