Author Topic: 1978 750F The start of a big project.  (Read 18118 times)
Offline Jnel
Re: 1978 750F The start of a big project.
« Reply #50 on: March 04, 2017, 12:46:17 PM »
Ok.  Got it. Appreciate the input.  Easy fix.  I don't mind burning up some more wire.  Thanks Cal
Offline Jnel
« Reply #51 on: March 13, 2017, 09:37:42 PM »
Some photos to let you folks know im doing a little something on this project.  Lots of reaserch time involved.
happy to be here... even if I have no clue whats going on!
Offline Jnel
« Reply #52 on: March 14, 2017, 02:35:45 PM »
Yes I'm going for the frame kit.  Im just kind of screwing around fitting things and see how they look.  I actually put the tires and rims on too. But i took them off and removed the tires. Im going to pick some new sneekers out shortly.   I wanted to see about seat hight and position of the rear controls and general geometry of me sitting on it.  I don't really know about the rear vontrols and the clip ons.  I dont know how comfortable its going to be.  I sent the rims to my son for blasting and powder coating.  The front shocks are coming back off too.  The uppers are rusted so bad i didn't put the new seals in and no oil in the shocks.  I guess i need to visualize a little bit.   I even put the rusty rear shocks on.  Playing with seat position.  Playing with a design of the oil tank and its position.
Its likeva puzzle and i kind of enjoy it.
Offline Jnel
« Reply #53 on: April 26, 2017, 10:39:39 AM »
Anyone got thoughts on rear spring replacement?  What's popular?  Benefits for longer springs or shorter ones?  My stock size is 13 3/16.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline Jnel
« Reply #54 on: May 03, 2017, 04:41:59 PM »
Anyone have suggestion about the rods that hold the rear of the motor in place?  I'm going the make a bracket that hold the rearsets in place. But these long bolts or rods are too long.  What do builders do?
They're long to accommodate the old very thick plates that held the foot pegs and rear passenger pegs.
  The only thing i can think of is put more threads on there and cut the excess off. Or... have new ones made.
Any thoughts?  They will be appreciated.
John
« Reply #55 on: May 03, 2017, 06:06:19 PM »
Most people either have the bolt shortened and turned with new threads OR source (or make) a new bolt.
Offline Jnel
« Reply #56 on: May 03, 2017, 06:28:50 PM »
Any ideas on the grade of steel?  Hard I would think.  Cut the threads before the Harding process I would guess?  I need a machinist.
Offline slikwilli420
  • Master of Disaster
« Reply #57 on: May 03, 2017, 07:10:49 PM »
It's unhardened mild steel. Nothing fancy. Get a piece of rod the right size and thread both ends.
Offline Jnel
« Reply #58 on: May 03, 2017, 07:15:12 PM »
Thats good news.  I can thread the one i have then.  Then cut it to lenth.  I appreciate the info.
Thank you Willie!
Offline Jnel
« Reply #59 on: May 04, 2017, 10:53:36 AM »
Fancy Fancy Cal.  I think threads and nuts on both ends are going to work for me.  You make your own,  thats cool.  I don't have that skill.  I'm going out source this job.   I want to hang around your shop for a week.  I could learn some cool tricks.  I could sweep up and keep the place real clean?  😁
Offline Jnel
« Reply #60 on: May 04, 2017, 10:54:30 AM »
Offline Jnel
« Reply #61 on: May 17, 2017, 03:00:17 PM »
Did a little work on the valve cover and the heads.  Local gun shop had brushes for cleaning the barrels.  Worked great on the end of a drill.
Sent from my SAMSUNG-SM-N930A using Tapatalk
« Reply #62 on: May 17, 2017, 03:11:28 PM »
FYI, Chewbacca just posted up re-zinced engine mount bolts for sale.
Offline Jnel
« Reply #63 on: May 19, 2017, 06:47:02 PM »
Anyone have thoughts about cutting the last 10 inches off of the stock F modle gas tank, then putting interior walls on each piece and weld the tank back together to make an oil tank in the rear portion?
Crazy?  Seems like a good project.   Saves fuel cost at the pump.😃
Offline Jnel
« Reply #64 on: June 13, 2017, 04:33:49 PM »
I ssem to have an issue removing the piston from my front brake assembles.  The rear came out no problem.  The two  fronts are being stubborn.  Shot some liquid wrench in behind the piston thru the banjo fitting.  Heated it up.  Wont #@%&* budge.
Offline Jnel
« Reply #65 on: June 13, 2017, 04:45:34 PM »
I've heard about using air pressure.  But my compressor has not got the strength.
Offline kmb69
« Reply #66 on: June 13, 2017, 05:07:13 PM »
Better be careful if they are that stuck. If they brake loose from compressed air, they can become DEADLY projectiles!!
Use a grease gun to pressure them out and you can better control the removal.
Offline Jnel
« Reply #67 on: June 13, 2017, 05:45:40 PM »
I'm not in love with the grease idea. But i can take some safety precautions with the air.  Maybe in side a blanket or packing material.
Offline Jnel
« Reply #68 on: June 13, 2017, 07:11:51 PM »
Ok... I'll give it a try.  Thanks for all the ideas.  Grease it is. But I still like the danger of the high pressure air
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #69 on: June 13, 2017, 07:37:58 PM »
Is the master cylinder still attached to the caliper? If so, just use brake fluid and pump them out. If not, the grease gun works a treat and the mess is very minor. You're going to be cleaning up the calipers anyway (stuck piston=cleaning) so the grease is no big deal.
yeah, just scoop the grease and reuse later
« Reply #70 on: June 13, 2017, 08:45:11 PM »
Peace through grease,
Offline Jnel
« Reply #71 on: June 16, 2017, 12:37:28 PM »
Ok... moving right along to the next issue... bleeder for the disk brakes.  That thing is welded in there.   Its going to break for sure.  Anyone got a trick for removal?
« Reply #72 on: June 16, 2017, 01:43:02 PM »
You may need to drill it out.
Offline Vintage King Motor Sports
« Reply #73 on: June 16, 2017, 01:44:09 PM »
That is a very cool bike.
Offline Jnel
« Reply #74 on: June 16, 2017, 02:23:38 PM »
Cal you just want to weld everything.
