Author Topic: 1976 cb550 Cafe Build "Boxed Project"  (Read 6307 times)
Offline Flexia
Re: 1976 cb550 Cafe Build "Boxed Project"
« Reply #25 on: April 20, 2017, 04:14:09 AM »
Bearing isn't the problem. The seal that going in the retainer is. It doesn't want to seat In the retainer
Sent from my Pixel XL using Tapatalk
Offline Flexia
« Reply #26 on: April 20, 2017, 05:23:51 AM »
Should that seal set into the retainer. Or does it actually sit in the side sprocket cover?
Offline Flexia
« Reply #27 on: April 20, 2017, 10:39:29 AM »
It looks to be 48. The dust seal.  It's the only seal that comes with the wheel bearings from allballs
Offline Flexia
« Reply #28 on: April 25, 2017, 02:20:41 PM »
This is how she sits right now.  I'm still waiting on front hub adapters for the brakes so I set up a 2x4 to imitate the front wheel height.   Now it's time to spend more money and order shocks to get the rear frame finished up.  Also going to make a seat cowl hopefully this weekend at a buddy's body shop with all the metal working tools you could think of.
« Reply #29 on: April 26, 2017, 08:23:37 AM »
Looks like you resolved the bearing retainer issue. You might consider the new CognitoMoto rear disc hub to partner with your GSXR front end!
Now, you're just showing off!  ;) ;D
Offline Flexia
« Reply #30 on: May 03, 2017, 06:02:32 PM »
Got to play this weekend on the English wheel.  Im happy with how the cowl turned out.  Still have some trimming to do.  It isn't a Meyerbuilt that's for sure but I'll take it for the first time using the English wheel.  Now for the seat pan and electronics tray.
Offline Flexia
« Reply #31 on: May 29, 2017, 06:22:09 PM »
Finally getting somewhere with the holiday.  Made some shock mount brackets and got my belly pan made and welded.  Next up I think will be some fiberglass work for the seat pan. And then dealing with the wiring if only my hand controls would come in.....
