Author Topic: Deleting handlebar risers  (Read 1467 times)
Offline Frozenoak
« on: May 11, 2017, 09:36:06 PM »
I purchased a second top triple (just in case this goes horribly wrong) and I'm going to remove the handlebar risers this weekend .  Any words of wisdom?
On a side note, I did a search because this topic has to have come up before but got no results.  What would you have searched for? Or what do you call this procedure.  I tried "handlebar riser delete", "riser removal" and "clamp removal"
Projects:
1977 Honda CB750F
1985 BMW K100RT
Online scottly
Re: Deleting handlebar risers
« Reply #1 on: May 11, 2017, 09:44:47 PM »
Try searching for shaved triple.
http://forums.sohc4.net/index.php?topic=66377.0
Offline Frozenoak
« Reply #2 on: May 12, 2017, 07:18:15 AM »
Perfect, that's what I was looking for.  Never would have thought of shaving them.
Projects:
1977 Honda CB750F
1985 BMW K100RT
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: May 12, 2017, 08:45:34 AM »
My pal did his guzzi triples with a hacksaw and a sanding block.
Guess when he first began modding he didn't have much in the way of power tools  ;D
Offline SKTP
« Reply #4 on: May 12, 2017, 09:02:43 AM »
I did it...It wasn't very difficult and I was Very Pleased with the result. I think I used a drill, hacksaw and metal file.
http://forums.sohc4.net/index.php/topic,68423.msg1014728.html#msg1014728
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Frozenoak
« Reply #5 on: May 12, 2017, 09:20:02 AM »
I am somewhat concerned with integrity of the triple when done, which is why I bought the second triple.  In the end, I'll have a couple of huge holes and I'm wondering if and what problems that might lead to.  Safety first! Am I right?
From the linked thread, this is close to what I'm aiming for.
Might even try to do the LED mod. :-)
Projects:
1977 Honda CB750F
1985 BMW K100RT
Offline SKTP
« Reply #6 on: May 12, 2017, 09:23:54 AM »
Oh yeah...sorry...I guess I didn't delete the risers?!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Frozenoak
« Reply #7 on: May 12, 2017, 09:30:40 AM »
I may delete the gauge mounts as well because I've mounted a GPS speedo/tach into the headlight bucket.  So long as the structure isn't compromised.
Projects:
1977 Honda CB750F
1985 BMW K100RT
  • Holy Cow! I'm a
« Reply #8 on: May 12, 2017, 02:48:31 PM »
If you're concerned about a making weakend tree, why not purchase a stronger better cooler tree?  Swap a lower too!
Offline Frozenoak
« Reply #9 on: May 12, 2017, 03:05:07 PM »
Mostly because , cooler is subjective.  I'm guessing you mean billet aluminum or some such.  I'm trying to avoid that as I think it's less cool.
If I could fabricate my own tree I'd be down for that.  Speaking of that, if this does go bad I may try to mold a newer stronger one from the remnants, assuming the failure will be a hairline fracture I catch before I kill my self.
Projects:
1977 Honda CB750F
1985 BMW K100RT
Offline Frozenoak
« Reply #10 on: May 15, 2017, 08:03:56 AM »
Turns out, it was much ado about nothing.  It was a lot of filing and sanding but went pretty good.  I did end up welding the holes closed for cosmetic purposes but any concerns with structure were taken care of also.  Now to figure out how to remove the rest of the powder coat with out removing anything else.
I wish I had taken some before pictures.
Projects:
1977 Honda CB750F
1985 BMW K100RT
« Reply #11 on: May 15, 2017, 08:17:40 AM »
Nice job.   Plan to get it powdercoated?  My coater burns off old powder...
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #12 on: May 15, 2017, 08:19:48 AM »
I cut mine down just enough for rivets, as wasn't keen on removing too much metal
Offline Frozenoak
« Reply #13 on: May 15, 2017, 08:24:05 AM »
Haven't made that decision yet.  Odds are, I'll paint it with the tank.
Wish I had seen this yesterday.  That looks awesome, and would have saved be about 4 hours of filing.
Projects:
1977 Honda CB750F
1985 BMW K100RT
Offline Gamma
« Reply #14 on: May 15, 2017, 08:26:06 AM »
I left the front lugs, as I intend to use this gauge mounting plate, the missing gauge is a Koso electronic speedo
Offline Frozenoak
« Reply #15 on: May 15, 2017, 08:27:42 AM »
That's a good looking cluster.  I'm putting a gps speedo /tach into the headlight bucket.
I felt a little bit bad for destroying a perfectly good powdercoat but the truth is I'd have had to anyway as the powdercoater had covered some critical areas, like the handlebar cradle (or whatever you'd call the knurled crotch that the handlebars get clamped into)
« Last Edit: May 15, 2017, 08:32:43 AM by Frozenoak »
Projects:
1977 Honda CB750F
1985 BMW K100RT
