Author Topic: 1978 CB750K skill builder (read: low budget)  (Read 30952 times)
Offline Davez134
Re: 1978 CB750K skill builder (read: low budget)
« Reply #100 on: November 25, 2017, 03:21:32 PM »
I like these bars, they look good and feel well made.
I need to modify the stop on the lower tree. The clip on part of the bar can touch the tank.
« Reply #101 on: November 25, 2017, 05:27:40 PM »
I have a set of those clip-ons plus spares in case you need more.....!
Offline Davez134
« Reply #102 on: November 25, 2017, 08:54:16 PM »
Thanks! But hopefully I won't need more, that will mean something bad happened!
Offline Davez134
« Reply #103 on: November 26, 2017, 02:58:22 PM »
Ok, fixed my steering stop so there will be no contact with the tank.
M6 time-sert drilled and threaded.
M6 bolt for the new stop
« Reply #104 on: November 26, 2017, 03:31:32 PM »
You are probably gonna have to add a jamb nut on there or it may just vibrate out of there.
Offline Davez134
« Reply #105 on: November 26, 2017, 03:54:50 PM »
Yeah, for sure. This was just a test fit.
« Reply #106 on: November 27, 2017, 01:49:23 PM »
The triples and bars look good Dave.
Offline Davez134
« Reply #107 on: December 09, 2017, 05:17:25 AM »
How are you guys mounting these type of fiberglass seat pans? (I have not modified the frame) I know I will drill out the back lower part to mount to the frame tubes, and I will place some thin rubber pads under where it contacts the frame to get the height right. I was wondering about securing the front. I will have the stock battery box, oil tank, etc. Any suggestions?
Offline Davez134
« Reply #108 on: December 24, 2017, 04:26:52 PM »
It's a roller now! Tires mounted (shinko 712) seat is upholstered too, haven't figured out a way to mount it yet though. Took some pics out of the garage with its older sibling
« Reply #109 on: December 24, 2017, 05:20:34 PM »
Looks good Dave!
Frankenstuff came up with a mount for cafe seats, I dont see em on his website but I have a couple. If you are interested, I'll dig em out and shoot ya a couple pics and see if they will work for you.
Offline Davez134
« Reply #110 on: December 24, 2017, 06:14:14 PM »
Looks good Dave!
Thanks, that would be great! I have an idea, but it would be hard to access. I'd love to see what you are talking about.
« Reply #111 on: December 26, 2017, 10:05:18 AM »
Looks good Dave!
I used the Frankenstuff mounts on my old 750 - a rubber clamp around the frame rail with a tapped mount for the seat.  Mine kept cracking in half (the rubber portion).  I noticed that the ones that failed were close to the oil tank.  I think Frankenstuff changed the "formula" on the rubber to make them stronger.
I ended up using these. https://www.lossaengineering.com/products/lossa-seat-tab-kit
Offline Davez134
« Reply #112 on: December 26, 2017, 01:09:29 PM »
Seat upholstered, just sitting on the frame for now
And, a few outside
« Last Edit: December 26, 2017, 01:53:24 PM by Davez134 »
Offline Davez134
« Reply #113 on: December 26, 2017, 01:23:24 PM »
Looks good Dave!
I wish I had welded in tabs before powder coat. Dumb oversight.
« Reply #114 on: December 26, 2017, 02:07:25 PM »
Dave...below is a pic of the mounts, they are yours if you want em.  They are unused, I had planned to use them on my 750 F cafe but sold it [and dont recall what I used].
I never heard of them cracking or a changed material, so Don's info may be valid...
Offline Davez134
« Reply #115 on: December 26, 2017, 04:53:45 PM »
Those could work, the only problem is that the upholstery pan would have to come off to access those top screws and it is attached to the seat by threaded studs coming out the bottom.  Ill post up a picture in a little bit of what I am trying/thinking so far and get your guys opinions.
Offline Davez134
« Reply #116 on: December 26, 2017, 06:18:50 PM »
Ok here's what I'm thinking:
Use these
Mounted here
To attach to upholstery pan and seat from underneath with 10mm nut
And to the rear here
It will sit on some 1/8 inch rubber strips on the bottom.
Concerns? Ideas?
« Reply #117 on: December 27, 2017, 11:06:44 AM »
Those are the mounts I originally used.  I got one of the first batches.  They work great in providing a mount point that has some cushion.  The ones on my right side (oil cooler side) kept splitting.  Like I said, Frankenstuff said he changed the rubber material so later runs might be okay.
Dave, I, too had your dilemma re powdercoating.  I ended up touch up painting over the welded in tabs (along with a later installed Gordon's frame kit).  All of it was hidden anyway (but I KNEW!).
« Reply #118 on: December 27, 2017, 11:10:28 AM »
Dave - I dont see a problem with your mounting idea, I say go with it.
« Reply #119 on: December 27, 2017, 11:17:02 AM »
Use these
Mounted here
Concerns? Ideas?
That should work.  I would include a grommet under the head of the nut (between the nut and the seat) to displace the force of the nut against the fiberglass (to help guard against stress cracks).
Offline Davez134
« Reply #120 on: December 27, 2017, 09:01:22 PM »
Good idea. If I can find the right size, I may put one in the hole I drilled in the seat
Offline Davez134
Re: 1978 CB750K skill builder (read: low budget) Rear wheel help!
« Reply #121 on: December 31, 2017, 02:28:01 PM »
Ok, what am I missing here? While looking at the bike the other day, I noticed the rear tire seemed to be off the centerline of the bike, to the left side a bit. Then I noticed the sprockets don't line up. I've been checking parts diagrams as well as looking at the other 78k I have in the garage, and it seems I have it put together right. Nothing makes sense to me here. Any ideas or experiences?
« Last Edit: December 31, 2017, 03:32:46 PM by Davez134 »
Offline jgger
« Reply #122 on: December 31, 2017, 03:43:42 PM »
There are a couple of threads going on now about that very issue. Bobby R  has one and may be able to point you in the right direction...............if he is sober (it is new years eve ).
« Reply #123 on: December 31, 2017, 04:03:06 PM »
yeah, looks like you have some kind of parts/year mis-match.  You ever check hose engine and frame numbers?
I think jgger meant BobR, not Bobby R...2 different dudes
Offline Davez134
« Reply #124 on: December 31, 2017, 04:09:08 PM »
Yeah, that's one of the first things I did. It's for sure a 78k motor and 78k frame according to vin numbers. I have its twin in the other garage, so as soon as I get home from the gym (yes I'm working out before all the crap I'm gonna consume later!) I'm going to take some measurements. The other one lines up fine.
