Author Topic: Build 201  (Read 27646 times)
Re: Build 201
« Reply #150 on: December 03, 2018, 05:40:49 PM »
Nice, any chance you can make a new pieces with 2 bends that steps down on the front tank mount..
Offline Daggless888
Re: Build 201
« Reply #151 on: December 04, 2018, 01:57:35 AM »
Looks great.  I assume it's a runner??
Thank you she certainly draws attention when I’ve taken it out.  I’m just working on all the small things.  Still running too rich. I’m down to 98,s but I think I will need to get it to the dyno. I’m running out of knowledge on tuning. A couple of small things to adjust. Speedo needs to be tilted up slightly as it’s a bit hard to see when moving. Not happy with seat to tank join so will work on that. Tank strap needs to be properly finished. Big hurdle is getting the compliance done so I can legally ride on the roads. Will have the result in a couple of days.
Offline Daggless888
Re: Build 201
« Reply #152 on: December 04, 2018, 01:58:59 AM »
Very nice...
Anyone considered nominating your bike for Bike of the Month?
David
Cheers David. No nominations yet.
Offline Daggless888
Re: Build 201
« Reply #153 on: December 04, 2018, 02:03:17 AM »
Thanks 754. I’m just waiting for the screws to turn up for the front strap. I’m going to carry the metal right through so it balances. Will post some photos once it’s completed properly.
Re: Build 201
« Reply #154 on: December 04, 2018, 09:42:57 AM »
Very nice...
David
David,
FYI - This is why I asked if it was a runner.
Re: Build 201
« Reply #155 on: December 04, 2018, 09:49:30 AM »
Daggless,
I'm inclined to nominate the bike BUT I'd prefer to do so for February.  January already has 3 bikes up for nomination.  Just my $0.02 but voting for more than 3 bikes really thins down the votes per bike versus being a more straight-forward binary vote.  That said, if 2 members get impatient and you accept, it's out of my hands.  Plus, none of the 3 nominated so far has accepted -- but it's only December 4th.
Offline Daggless888
Re: Build 201
« Reply #156 on: December 07, 2018, 03:29:54 PM »
Compliance been done. Have a list of 6 things I need to do to pass. Front mudguard is 40mm too short. I have the original gsxr guard that I can put on to clear it. Need a reflector on the rear number plate!!!! A couple of nuts needed replacing with loc nuts. Swing arm pivot bolt is 7mm too short. Needs to have 2 threads past the locking nut. Will need to get a new one made or get original lengthened. Will sort that out this week. Having an issue with charging. Just tracing all the wires back to find out what’s going on. Scratching my head a bit at the moment.
Offline Daggless888
Re: Build 201
« Reply #157 on: December 09, 2018, 11:40:19 PM »
Make sure the battery NEG cable is pinched between bare metal and the motor mount. Painted frames will interfere with that.
Then chase the Reg/Rec wiring for the GREEN and the BLACK. The GREEN needs a really good connection to Earth, and the BLACK wants a solid connection to your switched 12v circuit. These tend to be the most common points of reduced charging connections.
Thanks Cal. I chased all the negatives and roughed up a couple that looked like they needed cleaning. There’s a voltage reading on the speedo and I noticed it dropped when I went round the block. Put the meter on the battery and it would charge from 2000 rpm up till 4000. Then it would just stop charging until I turned it off and back on again. Almost like it would reset itself. Then as soon as hit 4K it would turn off again. I grabbed reg/rectifier off other bike and put it in and problem gone. Was a brand new one but must have got a dodgy unit. So now we need to tidy everything up again and get on with the tuning.
Offline Daggless888
Re: Build 201
« Reply #158 on: December 09, 2018, 11:46:15 PM »
Daggless,
Cheers SOHC. I’m picking it will be late January before I get all the bits n pieces completely sorted. Off to Australia for a bit of r n r straight after Xmas. Hoping to get back down to Phillip island for the international classic. Really enjoyed the racing there last year.
Re: Build 201
« Reply #159 on: December 18, 2018, 07:26:10 PM »
Daggless,
After seeing the number of bikes nominated I was inclined like SOHC recommended to hold off until Feb nominations are opened up.
Hope you enjoy the Christmas on the beach and the racing at Phillip Island.
Offline Daggless888
Re: Build 201
« Reply #160 on: December 19, 2018, 01:23:15 AM »
Daggless,
Cheers RAF. looking forward to a break and some good weather. Unfortunately the beach isn’t looking good for us this year. Wettest December on record or close to it. Limited ride time lately. Enjoy the snow and the holidays.
Offline Daggless888
Re: Build 201
« Reply #161 on: December 28, 2018, 04:18:30 PM »
Have been chasing my electrical problem for a good month. The battery would discharge when the bike was running and would hold its charge when turned off. The ignition switch burnt out which was weird as no load was on it. Just straight form battery to ignition and back to moto gadget. I put a good reg/rec in and thought my problem had gone. Checked the search engine of the forum and got the multi meter out and chased everything I could think of. Thought it was the field coil so took it out and tested it on the battery and turned magnetic instantly so put it all back together and found that the field coil was shorting out against the cover. There’s a small clip wrapped around the 2 wires that was resting on the cover when installed. Bent this up and problem instantly fixed. I still find electricity confusing but fingers crossed it appears to be working correctly. It’s charging a healthy 14.5 volts now. Just need to wait for a new ignition switch to arrive. Went for a good ride today and the mid range this bike has compared to others is brilliant. The straight shot manifolds and bigger valves Makes a noticeable difference. I need to get the certifier guy back now for its final check. He needs to take it for a ride to make sure it rides ok. Can’t wait to see his face when he gets back :-). Once I get it registered I want to get it straight onto the Dyno just to see where it’s sitting. I’m picking a healthy 55hp. Just in time for some good weather over the next few months.
Re: Build 201
« Reply #162 on: January 07, 2019, 10:45:35 AM »
Hi Daggless88,
Your CB550 has been nominated and seconded for the coming BOTM poll.  To be eligible for voting, please post that you "accept" the nomination in the following thread:  http://forums.sohc4.net/index.php/topic,175508.0.html
Congratulations and good luck!
Don
