Author Topic: Need small, OEM handlebar switches.  (Read 5404 times)
elcid
Re: Need small, OEM handlebar switches.
« Reply #25 on: December 28, 2006, 02:55:43 PM »
well in that case why not use any random buttons for the horn, hi-low beam, sigmals, kill switch... any websites that sell all kinds of randomn switches & buttons that could be used?
« Reply #26 on: December 28, 2006, 04:53:58 PM »
On my 550 cafe I decided on 600F3 switches, just to be different. (because I had them too) Slightly smaller than original, like scondons they use blade type connectors and the choke lever is integrated in the left switch. Downside.... it took a while to fiqure out the wiring, and had to make a choke cable to fit.
Offline scondon
  • Mmmm......tasty bugs
« Reply #27 on: December 28, 2006, 05:11:18 PM »
   I thought along these lines at first but decided I wanted to be able to operate most of the switches while keeping both hands on the grips. Signals,lights, and horn should all be reached by the thumb, IMHO. The rest can be scattered wherever but I thought that the kill switch should remain in a familiar place in case someone either than myself needs to kill the engine. That left only the starter button.
  I'll be looking for different switches for other things(hidden power switch,etc..). If I come across any good sites for switches I'll post'em here. Any good electronics store in your area would be worth a walkthrough to get the creative juices flowing. I'm gonna hit Home Depot on the way home to see what they offer.
elcid
« Reply #28 on: December 30, 2006, 12:19:38 AM »
got any links for electrical switches & buttons?
Offline scondon
« Reply #29 on: December 30, 2006, 08:41:25 AM »
Found this while looking the other night. No "grouped" switches or "bar mount" stuff, but certainly a lot of switches.
http://www.action-electronics.com/switches.htm
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #30 on: December 30, 2006, 09:27:59 AM »
This place is good source for electronic and electrical parts:
http://www.allelectronics.com/
Jim
–Captain Horatio Hornblower
www.thehairynickel.com
Offline tsflstb
« Reply #31 on: December 30, 2006, 07:38:06 PM »
You can get around the starter button all together by getting a universal car-type ignition switch.  I bought one for $6.00 at the local Auto Zone.  You just crank the switch to start it.
I mounted it to a piece of sheet metal near the right side cover.  The white star shaped thing is my key ring.  It cleans up the dash quite a bit, but you need a third hand if you want to hold the clutch, hit the starter and give it gas at the same time.  I just start it in neutral.
« Last Edit: December 30, 2006, 07:40:38 PM by tsflstb »
Offline doug_id
    • My Cafe 550 Project Gallery
« Reply #32 on: January 25, 2007, 07:14:27 PM »
Hey Scandon,
Did you ever get your switch wired and working?   I bought the same one and I am STRUGLING trying to get everything working.   I am lousy with wires so it is probably just me.   I know that getting the electrics to work again is gonna be the hardest thing for me.   So far I have two idiot lights on and the starter relay clicks (low battery probably?).   I have got the headlight to flash like a turn signal but no luck getting the anything from either turn signal.    I am gonna go qwazy I can feel it.....    :o :o :o
Thx,
Doug
02 Concours
78 CB550
06 Stella 150 2t Scooter
