Author Topic: Wheel alignment (offset from each other) question  (Read 16952 times)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Wheel alignment (offset from each other) question
« Reply #25 on: January 28, 2018, 05:51:20 AM »
How old is your current rear sprocket, and is it worn at all? You might find that purchasing a new sprocket for your bike and using your old one, cut down, may be an alternative if it is old already. Look for wear of your teeth.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Yamahawk
« Reply #27 on: January 28, 2018, 05:58:50 AM »
I can look at Pat's shop on Thursday, see if he has a junk one on an old CB550 wheel, if you want... that is, if nobody here has one to send you!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #29 on: January 28, 2018, 07:55:57 AM »
I think I got one around somewhere...I will try to look today
« Reply #31 on: January 28, 2018, 11:40:18 AM »
 My thought is, if the two wheels are lined up in a straight line does the rest of the bike care if other things aren't pointed straight ahead?  Granted, the chain line should be pretty good and the frame/forks shouldn't be in a twist.
Offline DaveBarbier
« Reply #32 on: January 28, 2018, 02:21:51 PM »
Looks like Cal's to the rescue again.
And Don, yeah I somewhat agree. But if the wheel's centerline is 2" to the right of the center of gravity of the bike, would that make things handle differently? No idea.
Offline tlbranth
« Reply #33 on: January 28, 2018, 04:56:27 PM »
If the forks weren't at their center point, I'm betting you'd have an exciting wobble at some speeds.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline DaveBarbier
« Reply #34 on: January 28, 2018, 06:36:23 PM »
Yeah I want excitement on my terms when it comes to motorcycle riding. Not a bike induced quick low side or speed wobble at 70mph.
That being said, forks are centered and front wheel is only off by a couple millimeters.
« Reply #35 on: January 28, 2018, 06:40:06 PM »
Dave, I was in and out of my shop several times today and still forgot to go digging for that sprocket...maybe get another chance later this week?
Offline DaveBarbier
« Reply #36 on: January 29, 2018, 02:20:05 AM »
I posted in the wanted section and Cal's going to shoot one over for me. If it doesn't come since he's a lying bastard I'll let you know :)
Thanks for the effort, haha!
Offline DaveBarbier
« Reply #37 on: February 03, 2018, 12:35:25 PM »
Got the sprocket from Cal and yes I need to replace the studs with longer ones. How do these studs come out? I have a vise grip and the one I'm working on is spinning out but it seems to be hung up. It came out a few threads but now it's very tough and the pliers are beginning to spin on the stud. There isn't a head on the other side, right? Should just spin out after a few profanities?
Offline DaveBarbier
« Reply #39 on: February 03, 2018, 12:55:35 PM »
Ok never mind, I got a different one out. That first one is just stubborn. I'll keep at it.
Offline Yamahawk
« Reply #41 on: February 03, 2018, 01:47:29 PM »
Try one of these, as the stud looks a lot like an exhaust stud from my RD350 lol... And replace the studs with bolts! Make sure they are proper grade bolts, and not allens unless you have clearance for the head.
https://www.ebay.com/itm/KATONAH-TOOLS-1-2-Drive-Stud-Extractor-Puller-Remover-Mechanic-Tool-Truck-Car/160863034268?hash=item25742f1b9c:g:Y0YAAOSw3mpXN1zd
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline DaveBarbier
« Reply #42 on: February 03, 2018, 02:04:53 PM »
I refuse to buy a tool to remove these, haha. I'll drill them out after welding on another nut. And just for clearance I'm going with studs.
Offline DaveBarbier
« Reply #43 on: February 03, 2018, 02:52:48 PM »
I did have to get bolts, studs of the grade, length and pitch I need are hard to find.
Offline Yamahawk
« Reply #44 on: February 03, 2018, 03:50:24 PM »
Yeah, the bolts are readily available, studs maybe not... regular hardened hex bolts will give you the clearance a nut on a stud should.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline DaveBarbier
« Reply #45 on: February 04, 2018, 10:50:54 AM »
Holy mackerel got them out with just vise grips but man, that one was tough. I just used a dremel and made two flats for the vise grips to get a hold of. I also did a bit of research and a lot of times on studs, the threads that get inserted into the part are machined a hair larger to be more of a friction fit to reduce the possibility of removal when removing the nut. Interesting.
Offline Yamahawk
« Reply #46 on: February 05, 2018, 04:08:46 AM »
I have found Loctite used on many studs and bolts on rear sprockets. They don't like them coming loose :)
I have had to heat them to release the Loctite. Yours, however, don't seem to have any residue from Loctite in the threads.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Yamahawk
« Reply #47 on: February 05, 2018, 06:21:06 AM »
heh he did.. and twisted the nut and stud off... ;)
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Yamahawk
« Reply #48 on: February 05, 2018, 06:32:33 AM »
He might not have threaded the single nut on enough due to the mangling of the threads with the vice grips, but he did weld a nut on. Probably a good idea to try the double nut first, as that gives more stud to apply torque to.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline DaveBarbier
« Reply #49 on: February 05, 2018, 09:09:41 AM »
Did double nut first and they stripped the threads on a stud. Then tried vise grips and got all out except one. Welded on a nut and after it cooled broke the stud. Tried vise grips again with making two flats and tightened the vise grips with both hands and used propane to heat the aluminum and it spun out but I had to use all my strength. This stud was more stubborn than most.
