The SOHC/4 World Tour is in under way.
Paint needs both mechanical adhesion and chemical adhesion to the surface. If you polished the motor surfaces, you'll struggle to get mechanical adhesion. Self-etching primers can help overcome that, but a max of 320 grit sanding is my go-to.
A little bit of paint did more to spiff this engine up than all the hours of laborious cleaning I’ve spent over the past few months.
Sure looks pretty!
Quote from: DurangoCB on April 18, 2018, 05:28:21 PMSure looks pretty! You’re too kind!
