Author Topic: CB750 Wet Sump Conversion - Sumpthing  (Read 129679 times)
Offline FuZZie
Re: CB750 Wet Sump Conversion - Sumpthing
« Reply #25 on: February 12, 2018, 03:20:24 PM »
Yea NickRafAcosta may have put him to task posting it in racing.
Offline underdog
« Reply #26 on: February 12, 2018, 03:32:32 PM »
  I kind of like it myself. CB750A's are wet sump with no tank and get along fine. Also, it must use up some HP pumping oil up into the tank, albeit probably miniscule. I also like to see the regular guys making quality parts and trying new things. Even if you don't care for it, you have to respect the work that went into it. ;)
Offline gschuld
« Reply #27 on: February 12, 2018, 05:09:52 PM »
As someone who does a bit of complicated metalwork myself, I’m thinking the price is very reasonable for what is offered(assuming it performs as intended of course)
I couldn’t care less what kind of pets and plants he has😁, but feel free to share.  I would like to see the results of his work tested by someone well known and respected around here to offer a fair non biased opinion.  I think that would benefit everyone.
George
« Reply #28 on: February 12, 2018, 11:05:09 PM »
we've also blown several engines to heaven during the early stages.
How did your conversion blow the engines to heaven? Did you not understand the oiling system in the early stages?
Offline turboguzzi
« Reply #29 on: February 13, 2018, 01:43:00 AM »
I think you are a bit severe here scottly.  Someone can understand pretty well an oiling system but once you introduce to it a major change like this, it will not necessarily behave like you have in mind. Oiling system dev is one area that even factories use trial and error to develop.  happened to me with my supermono racer oil system design, took a few tries to get it to function right.
  • Moderator
« Reply #30 on: February 13, 2018, 04:55:24 AM »
Sorry on my part for being a doubter Bert but with the Internet being what it is today, we have to make sure by vetting and that shoe thing that cropped up twice had me in real doubt but it's sorted now and thanks for the return of my email and please check out my reply.
In respect of the product and the price, I don't see a problem there.
For the minimalist cafe racer guys and people that want to get rid of the clutter, Ideal.
For the Drag Racer struggling to find a place to put Nitrous bottles, air shiffter tanks and the like, Ideal.
For the Roundy Roundy Road Race guys that want to lower the center of gravity, Ideal.
For the people with to much money and don't need it, just send the $500 to me, that will be Ideal as well.
Carry on.
Sam.
Offline turboguzzi
« Reply #31 on: February 13, 2018, 05:03:32 AM »
just sell each donor a run on your auto sam, i think you could have a nice business going on there :)
  • Moderator
« Reply #32 on: February 13, 2018, 05:25:16 AM »
Stop it you two, you just made me pee myself laughing.  ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline voxonda
« Reply #33 on: February 13, 2018, 06:01:28 AM »
Hey folks,
I would like to try one in my CR. Expecting no temp issue's due to use of large oilcooler. Also feel it can have a positive effect on weight and weight distribution, cause weight is centered more front/down. Only setback is, due to deep sump cant use my 4 into 1 exhaust......
Cheers Rob
  • Moderator
« Reply #34 on: February 13, 2018, 06:18:33 AM »
I thought you might like it Rob and while your on, what happened to the dry clutch you were developing ?
Sam. ;)
Offline voxonda
« Reply #35 on: February 13, 2018, 06:25:20 AM »
Sam. ;)
Sam,
Yes I like the idea for the mentioned reasons. The dry clutch was a dual effort and since the relationship has ended, the development has come to a stop. Secondly my health issues stopped me from doing virtually anything, but things are still improving so I should be able to make some renewed efforts in that direction.
Rob
  • Moderator
« Reply #36 on: February 13, 2018, 07:14:54 AM »
Sorry Rob, I forgot about your health issues, I can't remember sod all since my accident.
Offline gschuld
« Reply #37 on: February 13, 2018, 08:55:50 AM »
Rob,
I hope your feelings better soon.  And I’m very glad you are interested in trying one on your road racer.  Perfect center of gravity situation, but yes, it will require not using the 4 into 1 system, so a 4 into 4 type exhaust would be the way to go for your road racer.  I have matching 4 into 1 exhausts myself(including spare) and custom made fiberglass belly pans that are form fit to them.  Plus all my oil tanks and mounts, custom oil lines, oil cooler setups, etc are done and ready.  Too far down that path to change out everything related for me.
But for drag racers like Billy and Frankie, etc. putting the oil weight low and fwd is a big positive as well.  If starting a new bike from scratch, totally worth considering.
Anyway, Rob’s seal of approval would do wonders for consumer (and supplier) confidence in this product.
George
« Reply #38 on: February 13, 2018, 09:19:37 AM »
4 into 4 and some sump showing.... shades of MV Augusta.. oooh yeah..
Offline FuZZie
« Reply #39 on: February 13, 2018, 09:45:27 AM »
That's a good point!
Offline slikwilli420
  • Master of Disaster
« Reply #40 on: February 13, 2018, 10:23:43 AM »
Rob,
George
George, remember that the 4-4 would be a weight penalty, not to mention a big cost. Additionally, now that you are wet sump, you will need a much larger belly pan. AHRMA rules dictate a 1qt capacity pan for dry sump or full engine capacity plus nominal reserve for wet sump. It will take a lot of redesigning to get it all right.
Offline gschuld
« Reply #41 on: February 13, 2018, 10:28:51 AM »
Well, I don’t have to worry about it as I’m too far down my current path to change everything now.  But I am very curious as to how it works out in a demanding road race application.  If if can handle that, it should be able to handle most anything.  Go Rob.👍
George
Offline Captain
« Reply #42 on: February 13, 2018, 10:39:38 AM »
 Anyone discussing this subject should reacquaint or educate themselves with the very reason Dry Sump is used in the first instance
  # 1 most effective means of removing air from the body of oil
 # 2  more effective and efficient cooling
 There are more but the above are two of the most important in HD environments (racing)
 Captain
« Last Edit: February 13, 2018, 10:45:25 AM by Captain »
Offline Bert Jan
    • sumpthing.
« Reply #43 on: February 13, 2018, 10:46:13 AM »
Hey folks,
Cheers Rob
Hey Rob,
I see you're my neighbour (in terms of how far the internet reaches) so we could make this happen very quickly. I'd like to hear some thoughts from you, and even better, would love if you could take the kit for a spin. The exhaust clearance is an issue but only to bikes that are done yet. My main focus was on builders still tinkering with the tank, but now i see there could be a demand in other sectors aswell, which is cool!
(Ik volg je al een tijdje omdat ik die droge koppeling een heel toffe vinding vond. Kan er nu niks meer over vinden helaas maar las wel hierboven dat dat een beetje is gestopt. Heb je een email adres zodat we wat sneller kunnen communiceren? Ik zit in Groningen maar moet voor klanten dikwijls naar de randstad. Binnenkort even afspreken? Neem ik een kit mee en kan je er even naar kijken.)
« Last Edit: February 13, 2018, 10:49:01 AM by Bert Jan »
« Reply #44 on: February 13, 2018, 10:49:34 AM »
Anyone discussing this subject should reacquaint or educate themselves with the very reason it is used in the first instance
  # 1 the most effective means of removing air from the body of oil
 There are more but the above are the most important
 Captain
Could you say that again in a bit more simpe language? I'm not sure i understand it fully.
Dry sump provides better air/oil separation and the separate tank helps keep oil cooler than having it stored in the engine.
  • Moderator
« Reply #45 on: February 13, 2018, 11:04:20 AM »
Hey folks,
Cheers Rob
Hey Rob,
Bert, I brought Rob in on this because he is a top guy in the world of CB750 racing and is right on your door step, about 165km I think it said.
Sam.  ;)
Offline Bert Jan
    • sumpthing.
« Reply #46 on: February 13, 2018, 11:04:59 AM »
 Captain
Read it a couple times more, got it and deleted my previous message asking for the explaination. I get it now, thanks.
I'm afraid we will never know for sure why the engineers made the 750 dry and his little brothers all wet. Could be a performance thingy but to be honest, the hondamatic and the 350/400/500/550 and 650 are still around so i think we'll be fine. In the tests, we've had oil being cooler than stock system.
As said before, the reason i started with designing the kit is for it to be used for cosmetic reasons. In the last months i came to the conclusion road racers and other performance people might want to use it aswell. That's why i added the tabs on the inside (thanks to George) so those in need could fit a custom anti-slosh unit. Otherwise you can just leave those tabs.
Today, we went to the box-factory because i wanted to ship the kit in a special made shippingbox for safety reasons. Here's a picture:
This box is damaged because we took it in and out 20 times. They boxes are ready this Thursday and the first kits will get shipped Friday.
« Last Edit: February 13, 2018, 11:10:41 AM by Bert Jan »
Offline Bert Jan
    • sumpthing.
« Reply #47 on: February 13, 2018, 11:07:16 AM »
Hey folks,
Cheers Rob
Hey Rob,
Sam.  ;)
Thanks dude, i know Rob (not personally) because i followed his dry-clutch on dotheton couple years back. Let's see if we can meet up soon. Small world aye ;)
  • Moderator
« Reply #48 on: February 13, 2018, 11:34:11 AM »
The world is only as small as the Internet Bert, hahaha.
I've had Rob's address for quite a few years, it was just a simple step to find yours and put them both into Google maps to see how close you were.
Captain, I wonder why Honda stopped making Bikes with dry sumps, the CB750 must have been one of the last ones they made.
Sam. ;)
Offline deviant
  • You've been mostly-dead all day.
« Reply #49 on: February 13, 2018, 11:56:39 AM »
Sam. ;)
They didn't.  They continued to make dirt bikes dry sump until the CRF.  They went to wet sump on the CRF to lose weight.
