Author Topic: Any ideas on how to get this oil filter bolt off?  (Read 15677 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Any ideas on how to get this oil filter bolt off?
« Reply #50 on: March 04, 2018, 02:40:20 PM »
holy fuk when is this bolt coming off!
cb750 k6 - ugly
« Reply #51 on: March 04, 2018, 03:14:31 PM »
Somebody send him a goddam oil filter housing. Geez!! this is getting ridiculous. You WILL spend more money unless you give the fukr away  ::) It's an old SOHC4 and you have to spend money on them especially when you #$%* them up.
Offline scunny
  • don't call me expert
« Reply #52 on: March 04, 2018, 10:51:25 PM »
What Frank said. Your vice grips are the wrong way round.
I couldn't remove mine and ended up carefully cutting the head off, remove filter housing and the rest of the junk bolt was easy. You can't reuse that bolt anyway.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #53 on: March 05, 2018, 12:41:33 AM »
have you knocked the flange part of it around in the undo direction with a chisel yet?try and use the shallowest angle you can get a bite on.
« Reply #54 on: March 05, 2018, 01:53:24 AM »
You know the old saying, “If you can’t be handsome, be handy”? You must be FCUKING BEAUTIFUL!
Ha ha, sorry for adding that swear word mate, but that is THE quote of this whole sorry thread! ;D
Offline DaveBarbier
« Reply #55 on: March 05, 2018, 03:07:01 AM »
Perfect, haha. I was considering adding something like that.
Offline rotortiller
« Reply #56 on: March 05, 2018, 04:23:18 AM »
I think a lesson can be learned here. Don't over tighten the bolt and use a 6 point socket to remove it. I have seen new bikes with the same issue back in the 70s. Once you muck up the bolt head you basically will have to blast to get the thing off. Hopefully the threads are not bound from corrosion, however at this point you don't know. If the bolt head is dremel'd off at least you now have access to get the bound threads apart (heat and lube) without destroying the crankcase. So you wreck an oil filter housing with the dremel, get a new one or spin on filter.
rt
Offline Dos
  • Owner of a cb350f
« Reply #57 on: March 05, 2018, 05:27:59 AM »
Update: I had a friend come over and try with the vice grips, he threw his back out.
Stay tuned for more bull#$%*!
« Reply #58 on: March 05, 2018, 06:03:20 AM »
 Ha ha - now were starting to get a body count.  ;D
Offline Swoop
« Reply #59 on: March 05, 2018, 06:18:41 AM »
Starting to sound like a Tim the Toolman episode.
« Reply #60 on: March 05, 2018, 06:31:41 AM »
Ha!
Offline DurangoCB
« Reply #61 on: March 05, 2018, 06:53:25 AM »
I love how everyone is all over this thread, then pretending to not be enjoying it.  You owe this guy a beer, I say.
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
Offline evinrude7
  • not a kung-fu
« Reply #62 on: March 05, 2018, 06:55:06 AM »
hahahaha!
cb750 k6 - ugly
Online PeWe
« Reply #63 on: March 05, 2018, 07:01:25 AM »
Tiger saw with blade long enough, cut the filter cover in half. Then  easier to grip the struggling piece of bolt.
Off with bolt and the cover remains and pee on it while you scream, get that, get this. Finalize with petrol and flame the sh!t.
Order new parts and be happy.  I guess there is a spring and a  washer to not forget inside with oil filter.
Offline Ezile
« Reply #64 on: March 05, 2018, 07:58:31 AM »
I had this exact problem and actually took it to a guy who works on classic bikes. He charged me $50 and got it off... he actually just used a flathead screw driver and notched it / pushed it.
I had tried everything to get the bolt off and the bolt was WAY more mangled than any of your pictures have shown.  The fact that he did it with a flat head screw driver made me pretty impressed.  I didn't read this full $hit $how of a thread, but hopefully that helps.
good luck.  My bike was out of commission for 30 days last year because I couldn't get the oil filter bolt off. I know the pain.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #65 on: March 05, 2018, 08:18:16 AM »
I told you how to get it off the day you posted it. Vice Grips won't help, neither will BP Blaster or such.
Go to the hardware store and buy a cold chisel (these are made for metal vs a wood chisel), you want one about 8" long.
Position the chisel parallel to the front of the engine with the edge resting on the flange at about the 11 o'clock position so that the shaft is mostly vertical. Parallel to the cylinders is important because then when you strike it with the hammer the chisel will bite into the flange and not into the housing.  A basic claw hammer might work, but a small sledge is better.
« Last Edit: March 05, 2018, 08:19:58 AM by Bankerdanny »
« Reply #66 on: March 05, 2018, 08:36:23 AM »
 Weld on a nut, it's that simple. Bring it over I'll do it for you for free.
Offline aminemed
« Reply #67 on: March 05, 2018, 09:17:36 AM »
this is like following a tv show, any news ???
in case you need a new case
https://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_226784/
had the same issue with the bolts of my petcock..welded a nut and all done !
Offline Flyin900
« Reply #68 on: March 05, 2018, 11:15:44 AM »
Time for the gallon bucket of pop 🌽 as this is going to take a little longer. :o
Feel for you DOS..... as it seems your committed to those vice grips.
« Last Edit: March 05, 2018, 11:17:48 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Sigop
« Reply #69 on: March 05, 2018, 11:54:52 AM »
Great thread.  Almost better than Game of Thrones. I don't know whether to laugh or cry.  Feel for you Dos.  I think we have all suffered our own version of "Oil Bolt."
CB750 K3  Original Owner and Operator
Offline Mr. Mike
« Reply #70 on: March 05, 2018, 11:56:38 AM »
At the expense of the OP...it is getting rather dramatic, and being curious by nature, I keep coming back to watch the story unfold. Vise grips, chisels, bodily injuries, hammers and the like...I hope it doesn’t turn into another “Murphy’s Law” episode.
Hey DOS...all sarcasm aside, we all hope you get it taken care of with the least amount of damage, because honestly at some point to one degree or another we’ve all been there.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Swoop
« Reply #71 on: March 05, 2018, 12:23:18 PM »
+1
« Reply #72 on: March 05, 2018, 12:32:16 PM »
Is it too early to mention to Dos that he needs to take a look at his swingarm bushes? ;D
Offline Dos
  • Owner of a cb350f
« Reply #73 on: March 05, 2018, 12:37:01 PM »
Buddy came over. Got it off, thank god.
« Reply #74 on: March 05, 2018, 12:39:18 PM »
the oil filter bolt from hell,was giving everyone the #$%*s,you mustve loosened it for him?
