Author Topic: 130/90(80? 70?) x 18 rear tire recommendations? UPDATE 3" wide rim  (Read 1677 times)
Offline SKTP
I have a 1978 cb750k with an 18" rear Lester mag. I have been using Dunlop 404 120/90 x 18 for the last few tires but was thinking I might like to try a 130. This seems to be a not popular tire size. Any recommendations welcome.
« Last Edit: June 07, 2018, 10:20:05 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 130/90 x 18 rear tire recommendations?
« Reply #1 on: June 06, 2018, 09:33:48 AM »
What width lester?  If it's 2.15, it will just get big chicken strips and square off fast.
Online PeWe
« Reply #2 on: June 06, 2018, 10:06:29 AM »
My CB750K6 had a Metzeler ME99 130/80-18 back in the 80's. Front 3.50-19. The tires should be a wide as possible back then. Front had to be squeezed in when mounting the wheel.
130/80-18 is available today too.
It has stock size rear today, 4.0-18. Front 100/90-19. Next will be stock 3.25-19. Both rims stock. Good handling with stock size tires on stock sized rims.
Offline SKTP
« Reply #3 on: June 06, 2018, 11:44:44 AM »
Ok I am pretty new to tires and still figuring this out....It seems that if I go 130/80x18 there are options.
for example: https://www.revzilla.com/motorcycle/continental-road-attack-2-tire
Here's how my bike looks with the 120/90. I will have to measure the rim width as I am not sure how wide the Lester is.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
Re: 130/90 x 18 rear tire recommendations? UPDATE 3" wide rim
« Reply #4 on: June 07, 2018, 10:03:12 AM »
I guess I will change my question to:
What rear tire would you run if you had an 18" Lester Mag that is 3" wide (Sports Touring type riding) Thanks
I have been using a 404Dunlop 120/90....Thinking of trying a 130/80 130/70?...pros? Cons? Thanks
Maybe these? https://www.bikebandit.com/tires-tubes/motorcycle-tires/pirelli-sport-demon-motorcycle-tire/p/11681
I need to clean my rims!
« Last Edit: June 07, 2018, 10:39:26 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Bankerdanny
  • Endeavor to persevere
Re: 130/90(80? 70?) x 18 rear tire recommendations? UPDATE 3" wide rim
« Reply #5 on: June 07, 2018, 12:07:54 PM »
You measure between the beads, not where you are measuring. But look for the wheel size to be cast into one of the spokes near the rim end.
Offline SKTP
« Reply #6 on: June 07, 2018, 05:05:22 PM »
Talked to Don. He's running a 140/80-18 on his 18" Lester on a 550.
Thank you as Always Don...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #7 on: June 07, 2018, 05:45:46 PM »
That us a 2.15 or 2.50 rim.   Narrower than stock 17 in wheel which is 17 in.
 Are those pics in Solvang ?
« Reply #8 on: June 07, 2018, 05:48:56 PM »
All the Lester's I have, have the size cast into the rim or the spokes, or maybe it's stamped, can't remember...
Offline SKTP
« Reply #9 on: June 07, 2018, 06:09:16 PM »
Pics are in Cambria. Drove 540miles that weekend.
I am pretty sure my 18" Lester is the larger width. Will look for the stamp tonight.
I ordered 130/80x18" of this https://www.bikebandit.com/tires-tubes/motorcycle-tires/pirelli-sport-demon-motorcycle-tire/p/11681
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #10 on: June 07, 2018, 07:32:51 PM »
You will be ok with a 130.
 My 130 16 is huge.
« Reply #11 on: June 07, 2018, 09:36:25 PM »
It is huge, they were the biggest when they came out  25 years ago, and they are still huge now.
 I have held 3 or 4 other 130 90 16 in the past 2 weeks, and these are still big.
 Will post measure ment later, it and an old style Phantom.
 Phantom 137.5 wide UNINFLATED.. it will probably narrow with air.
 Conti         141    wide inflated..
« Last Edit: June 07, 2018, 09:47:43 PM by 754 »
Offline Bankerdanny
« Reply #12 on: June 08, 2018, 07:52:14 AM »
My 550 had a 130/90-18 on it's 2.15-18 Lester when I bought it. It looked ok, but when I put new tires on I went to 110/90, which looks good.
