Medyo those headers are beautifully bent i'm quite jealous haha
Nice build! Have you found the gasket that goes between the mid pipe and turbo? And the gasket that goes between the turbo and exhaust?
Tim I just ordered some exhaust gas material online and I was going to cut out my own. Not the best scenerio but the seller on ebay who used to sell Z1r TC exhaust gasket kits ran out of stock for the the moment.
My buddy managed to finish up the exhaust work. We had originally planned for the wastegate to route back into the dump but honestly this setup looked badass. Will probably end up welding some exhaust tips on to keep my foot at a solid state.
The carb was too tight to fit directly onto the turbo so we ended up rerouting it a bit forward to accommodate. The rear fender has also been removed as we're mocking up a water/meth tank that will replace it as I believe i previously mentinoned. The battery and rectifier will be mounted on top of the meth tank. More pictures to come.
Here's a flick of a GPZ900 with a mr.turbo kit I just picked up over the weekend. Got it for less then the billet block core for the CB
came with two spare engine as well. The previous owner broke off the oil feed line in into the oil pan. Once I pulled the pan I realized the engine was BUILT
H beam rods, pistons, crank etc. Just got the oil pan back on and the carb rebuilt and started it up for the first time tonight. Sounds healthy but lean as the mr.turbo air filters missing. Anyone got a S&S super B or Bendix air filter out there they're willing to part with? A seller on ebay wants 500$ just for the cover.
