Author Topic: CB750F Rider  (Read 4899 times)
Re: CB750F Rider
« Reply #25 on: August 11, 2018, 06:20:23 PM »
 You will have to mill down the swing bracket, or change the bracket.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #26 on: August 11, 2018, 06:24:29 PM »
Well crud.
Maybe someone will trade me....
Sent from my SM-N910V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: CB750F Rider
« Reply #27 on: August 12, 2018, 12:26:19 PM »
It's a rattle can with a clearcoat. Have any suggeations?
VHT makes a Caliper paint.  Available at most auto parts stores.
My first preference is powder coat.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #28 on: August 12, 2018, 08:19:49 PM »
Ok. So can I get a 500 or 550 one? They look identical. What years are interchangable?
Also, can I reuse the backing of the K model caliper on one from the 450, 500 or 550?
Thanks
Gus, Austin, MN.
Re: CB750F Rider
« Reply #29 on: August 12, 2018, 08:22:36 PM »
500 used a narrower bolt pattern and different piston.
 500 has 38 mm piston, smaller than 750.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #30 on: August 12, 2018, 08:53:44 PM »
So has to be 75 to 76 F or A model?
Damn. Is it easier to get the larger bracket?
I'd really like to stay stock-ish
Gus, Austin, MN.
Re: CB750F Rider
« Reply #31 on: August 12, 2018, 09:18:49 PM »
What you listed  plus 77 and 78 750 K modelsl
Re: CB750F Rider
« Reply #32 on: August 13, 2018, 02:21:18 AM »
Frank, are you sure that mid year k caliper won't work?  I had a 73-76 K caliper mocked up on my 75f for a while and it appeared that it would work fine.  The only reason I did not use it was because I was adding the second brake and the 73-76k calipers can't be made to work on the rh fork leg.
Re: CB750F Rider
« Reply #33 on: August 13, 2018, 05:20:01 PM »
It should work with the correct swing bracket,  if you want non F parts on the bike.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #34 on: August 13, 2018, 09:27:31 PM »
 Do the models pistons interchange?
Gus, Austin, MN.
Re: CB750F Rider
« Reply #35 on: August 13, 2018, 09:35:59 PM »
 I double disc'd my 76 F with two stock calipers and the stock M/C and loved the stopping power. I did ruin the front tire that came on it practicing emergency stops lol. I still have a wrecked 75F backhalf and a 77 F engine I'm saving for some custom cb I may build down the road.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #36 on: August 13, 2018, 09:40:31 PM »
Cool.
I ended up ordering new wheel bearings, next bearings and a battery.
I figure I will stop spending cash for a bit. Try to sell some old Harley parts.
Plan on reinstalling front end, do wiring, and see if it won't try over, maybe even start for a bit. Before I get to far I wanna make sure it runs and there are no other major issues, other than the trust I've fun into.
Big thing too will be tires, wheel strip and tubes.
Gus, Austin, MN.
Re: CB750F Rider
« Reply #37 on: August 13, 2018, 09:46:10 PM »
I think on the smooth caliper the piston has a closed end with tge swivel bump on it.
on the finned ones caliper end is open, and the swivel piece drops into open end of the piston.
 I think 750 smooth one may be 41 mm dia? maybe(500 uses 38mm ).... don't know what size or length the finned one uses.
 What kind of Harley stuff ?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #38 on: August 13, 2018, 09:48:32 PM »
Tank, trees, bendix carb with real nice can cleaner.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #39 on: August 17, 2018, 08:00:58 PM »
Lots of little progress.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #40 on: August 20, 2018, 07:16:09 AM »
Hoping to hear it run this weekend.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #41 on: August 23, 2018, 09:21:20 PM »
Little more
Goodies from Benton Racing. Thanks Bill
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #42 on: August 24, 2018, 09:12:04 PM »
This caliper situation is making me crazy. It was labeled cb500. Wasn't spaced enough. Arm looked the same so hooked it up.
When I put the tire on hits disc. I need some advice on what to get.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #43 on: August 25, 2018, 09:44:13 AM »
Went down to the local deal for odds and ends and what was sitting out there?!
The owner heard I was fixing one up and let me ride it....
It was amazing!!!
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: CB750F Rider
« Reply #44 on: August 26, 2018, 07:48:19 PM »
Had a couple buddies over to finish things up.
Gus, Austin, MN.
Offline kap384@telus.net
Re: CB750F Rider
« Reply #45 on: August 26, 2018, 08:11:25 PM »
Thanks for saving an 'F'.  Looking good!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
