Author Topic: Think these fork tubes are salvageable? RUST  (Read 3705 times)
Offline Lupo_00
« on: August 07, 2018, 10:55:25 PM »
What do you guys think?
Online Kevin D
  • SE Michigan
Re: Think these fork tubes are salvageable? RUST
« Reply #1 on: August 08, 2018, 04:11:41 AM »
It looks like the wheel and the fender are going in different directions. Make sure the fork tubes are straight.
71 CB750 K1
107,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: August 08, 2018, 07:31:34 AM »
Seconded. Those tubes look bent.
Fork (;D) over the cash and buy new ones.
--Evan
1975 CB750K "Rhonda"
« Reply #3 on: August 08, 2018, 08:13:28 AM »
They look bent to me.
 Probably straightenable.
 Many prefer new chrome ones, as you can then run smaller headlight ears.
Offline Lupo_00
« Reply #4 on: August 08, 2018, 01:46:20 PM »
Yeah I think you guys are right about the forks being bent. Is this a full replacement thing or just a new tubes thing? (Already have a new upper triple tree on the way to replace the cracked one)
« Reply #5 on: August 08, 2018, 02:01:54 PM »
Probably needs a lower tree  they are fairly easy to straighten.
 And the bearings and races probably got dimpled.
Offline przjohn
« Reply #6 on: August 08, 2018, 03:08:34 PM »
what is your budget? That is an important consideration. Some would try and work magic on stuff and others, (Myself Included) would opt for new tubes and some Ebay clamps.
« Reply #7 on: August 08, 2018, 04:35:43 PM »
That front end is FUBAR!  I'd check the frame too...
« Reply #8 on: August 08, 2018, 04:48:06 PM »
The fork tubes are shot from rust alone. Save yourself so time and can them. The slightest imperfection in the finish will cause a leaking fork seal. I also agree they are probably bent.
Offline Lupo_00
« Reply #9 on: August 08, 2018, 06:03:52 PM »
Alright I’ve got a new upper clamp already on the way. I’m going to eBay a used lower clamp and stem and buy new tubes.
Is there anything else I might as well take care of since I’m going this deep? New springs? Judging by the photo they’re probably leaking as is anyway. Makes sense to me considering the forks are bent.
Online Kevin D
  • SE Michigan
« Reply #10 on: August 08, 2018, 06:31:59 PM »
That front tire is dry rotted.
Is the rim bent?
71 CB750 K1
107,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Lupo_00
« Reply #11 on: August 08, 2018, 08:22:04 PM »
Is the rim bent?
My bank account hopes not at this point.  I'll take off the wheel tomorrow and check... Tires are going no matter what.
« Reply #12 on: August 08, 2018, 08:54:23 PM »
Spin the  wheel before you  take it off. Remove or loosen bolts on caliper if need be.
 Right now you are better off with a rolling bike while you wait fo parts.
When you do pull it, check the axle for bend.
« Reply #13 on: August 09, 2018, 07:31:59 AM »
springs, seals, boots, oil
Offline Lupo_00
« Reply #14 on: August 09, 2018, 03:15:01 PM »
As in replace the boots? Or clean them up?
Offline przjohn
« Reply #15 on: August 09, 2018, 03:25:36 PM »
Is there anything else?
A second job maybe? Delving deep into classic bikes is known to hurt the wallet along with a long list of other problems. You ain’t married is ya?
« Reply #16 on: August 09, 2018, 08:23:55 PM »
If you dont care about original , look for a 77/78 k fork they are better.
Or an F fork if you want to go big brakes..
Offline pjlogue
« Reply #17 on: August 10, 2018, 01:54:35 AM »
Check your frame at the steering head.  It may just be the way the picture was taken but the bottom of the steering head looks like it is bent to the right.
-P.
Offline Lupo_00
« Reply #18 on: August 10, 2018, 11:08:40 AM »
Will 77-78K forks work with 69-76K triple tree or will I have to match that?  Looks like the F and 77-78K have the same offset.  Unsure how that translates to the 69-76Ks.
Will take a closer look at the frame today.
« Reply #19 on: August 10, 2018, 05:06:50 PM »
They fit, spacing is same but offset is different,
 If you run  the  later trees  you may be hitting the tank at full lock.
Offline Lupo_00
« Reply #20 on: August 10, 2018, 07:14:20 PM »
So I’ll be fine with my early trees and late forks?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #21 on: August 13, 2018, 04:28:16 AM »
Yes both are 35mm OD sobthe fitment as far as the trees go will be the same. Post a wanted add on the forum for tubes. Im sure someone has a set they will come off of for a reasonable price.
Doing that right now for a extended set with very good results.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Tews19
  • I am no
« Reply #22 on: August 13, 2018, 06:21:48 PM »
Lupo, keep the fork lowers though. Take them apart, polish them real well then sell. It will help offset the cost??? Maybe someone would even trade?
Sent from my SM-G955U using Tapatalk
1970 Honda CB750 survivor.
Online PeWe
« Reply #23 on: August 13, 2018, 09:40:22 PM »
I got a complete old fork for a little bit less than $100 a year ago. Up to K6 model.
« Last Edit: August 14, 2018, 10:37:46 AM by PeWe »
Offline Detroit350f
« Reply #24 on: August 14, 2018, 05:12:34 AM »
if your brake rotor took some of that blow, it's probably bent or out of true. this can be fixed pretty easily.
