Poll
Battle of the CB750's
Beemerbum’s 1971 CB750K1 Barn Find Basketcase Restoration
30 (66.7%)
Drew_ATL’s CB750K Gold-Wheeled Bikini Special Built by Bill BentON Racing
15 (33.3%)
Total Members Voted: 43
Voting closed: August 31, 2018, 09:29:15 PM
Author Topic: Vote for Bike of the Month September 2018  (Read 4545 times)
« on: August 15, 2018, 09:29:15 PM »
http://forums.sohc4.net/index.php/topic,173467.0.html
DSCF6908 (2) by Donald Leonhardt, on Flickr
DSCF6906 (1) by Donald Leonhardt, on Flickr
37883966_10216841961466026_5874856812376752128_o by Donald Leonhardt, on Flickr
37157067_10204587019190816_8252950744991268864_o by Donald Leonhardt, on Flickr
37779617_10216821150905775_3843228859214331904_o by Donald Leonhardt, on Flickr
37717598_10216811514344867_4364469646489812992_n by Donald Leonhardt, on Flickr
https://drive.google.com/file/d/1G5iVreSIwfUDuw48bhtuzTeJLR5P2v8R/view?usp=sharing
Squirley's 1976 CB750F Cafe
http://forums.sohc4.net/index.php/topic,126782.0.html
Unfortunately rendered ineligible due to change in possession prior to completion of nomination.
« Last Edit: August 16, 2018, 09:54:43 PM by SOHC4 Cafe Racer Fan »
Re: Vote for Bike of the Month September 2018
« Reply #1 on: August 16, 2018, 10:28:14 AM »
beemerbum, Drew_ATL and Squirley:
Please post up a brief summary (with photos) of you builds, so the members can get the "story" behind these beautiful bikes -- what you started with, what you were trying to achieve, what you did, who helped, who provided any specialty parts, etc.
Offline squirley
« Reply #2 on: August 16, 2018, 09:21:46 PM »
Hi all,
I have been a long time member here and have had the pleasure of having been awarded bike of the month with my first cb550 build going on 8 years ago haha.  Unfortunately, most of the build pictures that I documented over the last 4 years building this bike are now gone (thanks imageshack).
About 4 years ago I started this project as a surprise gift for my brother.  I finally made a final push to get it done as a gift for his wedding day.  Here's a little bit about it, and please feel free to check out the more current pics on photobucket.
Life began as a broken, pieced together 76 super sport.  I quickly tore it down to pieces as most was not salvageable.  The frame has had a lot of work put into it, and all of it was done by me in my garage with my trusty tig.  All tube was hand bent by myself including all the manual machined and cnc'd parts for upper and lower shock mounts, caliper brackets, rear set mounts, etc .  The rear frame was cut off and the rest can be seen in the pictures.
The tank started life as a Royal Enfield.  Most of it has been cut apart and massaged into what you see now, once again all done in my garage. As for the oil tank, it was built from scratch as well.
The front end is a gsxr with a harley hub that i machined to fit, just like my first build way back when.  However, thanks to Cognito, the front steering stem conversions made it much more of a simple transplant.
Once i had the raw frame shape ready, i shaped a foam seat to follow the rail lines.  I must have spend a week's worth of hours hand sanding and bondoing the seat to get it ready for a female mold.  Once the female mold was made, it was time for several more weeks of sanding to get a smooth, consistant shape.  Finally, I laid it in carbon fiber and vaccuumed it to acheive what you see now.  I made a seat pan from carbon fiber and then had it upholstered in buffallo (i apologize for forgetting the name of the individual that upholstered the seat for me).
I did a top end rebuild on the engine and complete carb rebuild and tune to get it on the road.  I will leave it up to the new owner to build the engine if desired haha.
A big thank you goes out to Godffery for the rear rotor work and to Calj737 for providing me some awesome stainless engine bolts! Thank you very much gentlemen.  And thank you to this forum for the knowledge and support.
I apologize if you have all viewed these pics in my build thread, but they are all i have left...
Underside frame showing shock mounts, added frame gussets, under seat pan sheet metal and brake lights:
Week's of work to get this far:
One-off underslung bracket and rod.  Also, Godffrey's fine rotor work:
Home made tank and filler:
Thank you all,
Jens
« Last Edit: August 17, 2018, 03:20:16 PM by squirley »
« Reply #3 on: August 16, 2018, 09:53:11 PM »
Hi all,
My brother and new owner on the bike made this worth it ten fold!
Thank you all,
Jens
Apologies to Jens and all members.
When I nominated this bike, I was unaware that it was no longer in Jens' possession -- now in his brother's possession.  Unfortunately, this makes the bike ineligible for Jens - and it should not have continued to the voting thread here as set forth in BOTM rules 1-2.  http://forums.sohc4.net/index.php/topic,8929.0.html
I apologize for the confusion this has caused.  I am ZEROing out the vote, taking Jens' bike out of the poll (I will be happy to nominate it for his brother if he becomes or is a member for a future month), and proceeding anew.
SO, if you have voted, you will need to vote again!.
Offline Drew_ATL
  • What’s a Torque Wrench?
« Reply #4 on: August 17, 2018, 08:58:06 AM »
AKA 'Captain Marvel'
Bike Summary:
Bill and I have a history going back about a decade, about 3 months ago I had the opportunity to pick up his '71 K1 for a very reasonable price and during what was to have been a basic restoration, Bill's vision took hold.
Piece by piece he has built something truly unique, a 70s style drag racer. I like it for numerous reasons, but mostly because it is one-of-a-kind. After we started to see her take shape with all of the gold + custom tank/side cover paint scheme, I realized that the perfect moniker was 'Captain Marvel' ~especially since that Marvel movie is due out in 2019 featuring a female lead.
Bill will have to chime in with the impressive list of improvements and his hard work.
*Additional Pictures Attached*
« Last Edit: August 17, 2018, 09:21:01 AM by Drew_ATL »
I blame Bill, he made me love these bikes! :)
...respectfully watching and learning.
« Reply #5 on: August 17, 2018, 09:18:43 AM »
Bike Summary:
Drew or Bill,
Knowing Bill's reputation, I presume this bike is MORE than meets the eye in terms of performance.  Can you give a quick synopsis on what was done to the drivetrain to compliment the 70's drag racer paint?
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: August 18, 2018, 08:51:12 PM »
OK. Not sure about the synopsis being quick,  but the bike is!
Here you go. But first a shout out to Andrew who gave me pretty much free rein. Drew,  I think it works.....lol, thank you.
Starting at the front
Bridgestone Battleaxe 100x90x19, new tube and rimband of course.
Buchanan's H/D SS spokes and nipples.
DID Gold anodized rim 2.15x19
Drilled front disc
Rebuilt brake caliper,  Ferodo pads, and VHT gold flake paint
Polished fork lowers
Microblue ceramic wheel bearings
Tapered steering head bearings
Old school 1/4 fairing
CB400F 1975 handlebars, wires run through them
Napoleon mirror
Dogleg polished brake and clutch lever
Gold accent grips
Gold anodized engine cover bolts
Mini chrome tachometer
Mini front turn signals
Dyna S electronic ignition
Unknown chrome 4-1
Old school multi colored paint scheme
New tank trim, 550 Gold badges, new cap sealing rubber
Chrome oil filter and large head bolt
Browns chrome plated shifter
Browns chrome plated float bowls, drain plugs and clips
New OEM petcock
K&N air filter
New rubber grommets
Yuasa Powersports AGM battery
Cafe seat
Gold drive chain
Progressive Suspension rear shocks
Rear rim DID Gold anodized 2.50x18
Bridgestone Battleaxe 130/80x18
New tubes and rimband
Barnett clutch springs
New OEM throttle and clutch cables
Chrome gauge cover speedo
Shorty chrome rear fender
Old school Lucas look a like taillight
Chrome tag holder
Browns chrome axle nut, brake backing plate
Black powder coated stabilizer bar
Custom red anodized rear brake adjuster
Braided oil lines by Rafi
Black and chrome oil pressure gauge
Browns chrome front motor mount
BentOn Racing m/c cap
Chrome special handlebar bolts
Bullet rear turn signals
There's more,  but I'm hungry,  lol
Thanks for all who helped,  Bill
Oh yeh, Microblue ceramic rear wheel bearings all 3
Black anodized handlebar end weights
Chrome axle large spacer
Checkered flag speedo face
New OEM float valves and gaskets
Chrome and gold anodized allen bolts
Exhaust header allen bolts
Gold anodized clutch cable adjuster
We took off weight where feasible,  rear grab rail,  heavy turn units
Rear fender and taillight,  exhaust pipes, seat, wheels, mirrors,  sprocket cover, shocks, drilled disc,
There's a few more little things I'm forgetting,  but that's most of it.
« Last Edit: August 18, 2018, 09:28:51 PM by Bill/BentON Racing »
BentON Racing Website
BentON Racing Facebook
Offline beemerbum
« Reply #7 on: August 19, 2018, 12:12:53 PM »
I now regret not taking more photos before I began cleaning. I used wire wheels and sandpaper to get the frame as clean as I could. It was wiped down with solvents before I painted it with Rustoleum Appliance epoxy. Following Hondaman's advice, I ground off the shoulders on the right side motor mount. I was fortunate in that the wiring harness was original and intact. With a battery installed, everything, lights, turn signals, horn, etc. worked. I did have to remove the PO's switch relocation bracket from the handle bars and return it to its original location The PO had installed running boards with the shifter and brake pedal relocated. These were easily replaced with footpegs, pedal (a 1971 sans tab) and shifter via eBay. In assembling the clutch, I of course broke a corner of the lifter plate. The brake master and caliper were rebuilt using OEM parts. As everyone knows, the fershluginer c-clip in the master requires the tool from MotionPro. The crank bearing clearances were plastigaged and were within spec. The cam had some light surface rust on the lobes, easily removed with CocaCola and steel wool. The cylinders were honed and new rings (stock size) installed. I used a Vesrah gasket set which has proven leak free so far. In the interest of stock as a stove, I used a set OF JIS "Phillips" screws on the engine covers. The MotionPro T handle with JIS bits is the way to go with these screws. I was suspicious of the wanky way the oil pump turned so to be safe I ordered a re-built unit from CycleX. $86 worth of peace of mind. In the boxes and baskets that came with this bike was a bizarre 4 into 2 exhaust (rusty). Having come so far, I sprung for the repop HM300 exhaust from DSS($1495 plus $19 shipping). The carbs were redone by Hondaman. I rebuilt the petcock using non Honda parts fro CB750.com. That was a mistake and I have since installed a genuine Honda petcock. While I remember I had installed an aftermarket cam chain tensioner unit from CB750.com. I then got a letter from them advising that the rollers on their unit were occasionally disintegrating and offering a refund. A nice gesture on their part. Up come the cylinders and new head gasket to replace with genuine parts. This and other similar experiences proved the value of genuine parts. I did a lot of ordering from 4 into 1 as well as DSS. In all, my goal was to recreate the bike I first saw in Chicago, late '69 if memory serves. I was riding a Triumph when I spotted a red bike at a curb. I literally sat down to count exhaust pipes , look for oil (non visible), wonder at a disk brake and be amazed at a button that said "start".
Offline beemerbum
« Reply #8 on: August 19, 2018, 01:04:17 PM »
I forgot to mention that the original seat had been stored in the house away from the bike and was in excellent condition. That was a bit of good fortune
« Reply #9 on: August 22, 2018, 09:17:57 AM »
Come on, people.  We are nearly a week into voting and only 21 votes cast.
Offline HondaAddict
    • Videos on my CB550K restoration and other projects
« Reply #10 on: August 22, 2018, 05:20:28 PM »
They're both beautiful bikes. Well done!
1976 Honda CB400F
1975 Honda CB550K (sold in 2020)  Project thread | Videos
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1984 Honda V65 Sabre (sold in 2020) Project thread on V4Musclebike.com | Video
1986 Honda Z50R
« Reply #11 on: August 27, 2018, 04:54:09 PM »
Only 35 votes cast, so plenty of members have yet to vote to make a difference.  PLEASE REMEMBER TO VOTE.
« Reply #12 on: August 31, 2018, 12:31:53 PM »
As the end approaches, only 42 votes cast.   :(
    • BentON Racing
« Reply #13 on: September 01, 2018, 03:07:16 AM »
Congratulations to the winner! Nice restored bike you have. Always loved the Candy Red. Good job young man.
« Reply #14 on: September 01, 2018, 11:37:23 PM »
Congratulations Beemerbum! Great looking bike.
Offline Drew_ATL
« Reply #15 on: September 03, 2018, 06:44:12 PM »
Congratulations!
Offline beemerbum
« Reply #16 on: September 06, 2018, 03:22:49 PM »
Awesome piece of work Drew!! Seems its easier to just put together what Soichiro designed, rather than come up with an individual piece of art. Thank you all.
