Author Topic: Custom rearsets adjustments  (Read 2737 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: November 09, 2018, 07:46:33 AM »
I feel the lever doesn't have enough recoil or is it just me? I messed around with different adjustments at the arm and the stopper. The stock spring isn't used in here so maybe that's it. What do you think? https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/spg-brake-pedal_46514404670/#.W-WrQe_QZjo
I also at the same time feel the mechanism might be too sensitive and the wheel stops too abruptly.
Offline Darren Jakal
Re: Custom rearsets adjustments
« Reply #1 on: November 10, 2018, 01:11:07 PM »
Hey, why not use the original spring?
Mind if I ask how you attached the plate to your frame? Did you weld on tabs or ? I'm working on rear sets and may wind up doing something like this.
As to the wheel stopping too abruptly my guess would be that with the wheel under load (and actually being driven down a road) that the brake might behave very differently.
Good luck,
Offline AlekStooge
« Reply #2 on: November 10, 2018, 05:19:26 PM »
I would have to reconstruct my design if I wanted to use the original spring. I'm not sure how that would work. Most rearsets I've seen don't incorporate it.
Here is the only photo I have of the tabs. Yes they are welded on. It took a little bit more work than I thought. The ears stick out a bit from the frame. The angle of the tabs needs to be right otherwise the plate sits crooked and your levers do as well. It took several tries getting that angle right and then tacking it in place.
You might right about the wheel not being in contact with the ground. I was thinking the same thing. I never had a center stand on a bike so I'm not sure.
Offline DaveBarbier
« Reply #3 on: November 11, 2018, 04:45:47 AM »
Alek, you can use the stock spring and it’ll help a lot. If you ground off the little hook where the pedal originally slides on then you’ll have to weld it back on. Grind the forward most “ear” so it has a little relief so the spring has someplace to hook to. See the below picture of my old setup.
Here you can probably see the spring and how it’s hooked around the front ear.
You can bend your own hook so it actually works. Use heat to get it cherry red and bend it but somehow shield the rest of the spring. I don’t think it’ll maintain it’s spring if you heat the whole thing.
Offline AlekStooge
« Reply #4 on: November 11, 2018, 11:33:50 AM »
Cal, I don't follow, it sounds like the spring would come loose easily off the edge of the pedal. It probably works I just don't see it. Front brake rod pivot?
Dave, Is this the hook?
In your photo it looks like the spring would attach underneath the spacer. I can't tell. I don't have anything like that on my bike. When I refer to the ear I mean that whole hoop that the rear pegs attached to.
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/F++26.html#.W-iDee_QZjo
I'm thinking maybe there is a way to attach the rear stop switch spring to the spacer and that might work.
Offline DaveBarbier
« Reply #5 on: November 11, 2018, 06:37:44 PM »
Yeah, that’s the little hook. Put the spring back on and instead of it wrapping under the brake pedal as it normally does, just have it hit the tab on the left side of the picture. Cut a notch so the spring doesn’t slip. As I said before, you should be able to cut, heat and bend the spring so it fits nicely.
Offline AlekStooge
« Reply #6 on: November 12, 2018, 06:43:17 AM »
Ok now I see. Propane torch won't get it cherry though.... I'll have to make some calls.
Offline AlekStooge
« Reply #7 on: November 12, 2018, 01:20:09 PM »
Grab a bottle of MAPP gas. Works just fine.
You're not the first to tell me that. Really? I don't need a specific torch and tip for that?
Offline AlekStooge
« Reply #8 on: November 12, 2018, 01:45:44 PM »
Just Mapp gas alone will work, no oxygen? Anything else I'll need to know?
Offline AlekStooge
« Reply #9 on: November 12, 2018, 06:33:32 PM »
Does Mapp burn at a higher temp? I busted out my welding book. The values are shown with oxygen but look almost the same for Propane vs. Mapp. What I'm trying to get at is why Mapp will work better than Propane for bending steel?
Offline AlekStooge
« Reply #10 on: November 13, 2018, 10:29:22 AM »
I will try the propane first, it didn't get my cylinder studs cherry when I was removing them but those are thicker then the spring. I'll see.
Offline AlekStooge
« Reply #11 on: November 14, 2018, 09:26:15 AM »
Is this how the spring is supposed to sit? It feels loose maybe it's just because it's not under tension?
The hook part is long if I bent that I could wrap it around the tab. I think I should cut it but before doing that I tried to heat it up with propane in the area where I would bend it and I couldn't get it quiet cherry.
Offline AlekStooge
« Reply #12 on: November 14, 2018, 05:54:54 PM »
Good enough for you Cal? ;D
I haven't cut in a notch. I thought of bending the spring some more, but if it works maybe I should just let it be.
Offline DaveBarbier
« Reply #13 on: November 15, 2018, 02:23:20 AM »
Nice job, but I would rotate the pedal downwards so it’s always connecting the spring assuming it then won’t be too angled for your foot. Seems like it’s being held by the nut and bolt well enough.
Or bend it again and shorten up where the bend is.
Offline AlekStooge
« Reply #14 on: November 15, 2018, 05:41:07 AM »
The spring is in contact at this position, might not look like it. I could adjust it furthur downward. I think I'll bend the spring a bit more so it hooks more than it does now, if you know what I mean.
Offline AlekStooge
« Reply #15 on: November 16, 2018, 11:36:44 AM »
Is this where the rear brake switch spring mounts? I seem to have lost the corner bracket. Would I be able to make the switch work without the bracket by zip tying it to the back of the frame rail? Seems like it would work all the switch needs is to be pulled by the spring.
Offline DaveBarbier
« Reply #16 on: November 16, 2018, 02:27:50 PM »
The bracket which holds the brake switch is mounted with an engine frame bolt. Yes, that looks like the brake switch activator but maybe the image was flipped because it’s a weird perspective.
Offline AlekStooge
« Reply #17 on: November 16, 2018, 06:00:16 PM »
Here is the bracket I was referring to.
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/bracket-stop-sw_50157390000/#.W-910-_QZjo
Definitely not an engine frame bolt...
Offline AlekStooge
« Reply #19 on: November 17, 2018, 08:17:09 AM »
I see, it slides onto the bolt behind the frame rail. So I see a bracket
In the photo holding the brake switch that is welded to the frame. I must of cut that one off... so what's the one I was reffering to used for ???
« Last Edit: November 17, 2018, 08:21:00 AM by AlekStooge »
Offline DaveBarbier
« Reply #20 on: November 17, 2018, 11:32:20 AM »
The brake switch goes into that little bracket you linked to. Then it get bolted to the frame through a motor mount.
Offline AlekStooge
« Reply #21 on: November 17, 2018, 12:33:43 PM »
I read through that thread you linked to. It's different on the 78 that's why there is no tab welded on to the frame. I'll see what I can do either keep looking for that bracket, make one, or try to make it work without it.
Offline DaveBarbier
« Reply #22 on: November 17, 2018, 05:47:35 PM »
Yeah I know it’s different. It was stated in that post. It explains how it all goes together. You need the bracket and it’s to be bolted to the motor mount.
Offline AlekStooge
« Reply #23 on: April 28, 2019, 01:10:31 PM »
Like this correct?
