Author Topic: Must have motorcycle tools.  (Read 3898 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: March 26, 2019, 10:51:56 AM »
Seen this on another forum ( Garage Journal )
And was wondering tonthe SOHC4 community what is your must have for home bike shop.
Mine are
Motorcycle jack/lift table
Multimeter
Ratchet straps
Tire spoons
QD cleaner
JIS Screwdrivers (just recently learned how great these are)
Metric allen sockets
1/4 and 3/8 swivels
1/4 torque wrench
Paint markers
Points file
What do you guys consider must have?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline lafindufondu
Re: Must have motorcycle tools.
« Reply #1 on: March 26, 2019, 11:02:26 AM »
Hand impact driver has saved me a few times
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: March 26, 2019, 01:03:24 PM »
It has me too
Get some Vessel Impacta drivers.
Also in the past when a impact driver wouldnt save me i have cut a notch with a dremel and beat it to turn with a flat screwdriver and a hammer. Only in extreme cases has that happened.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: March 26, 2019, 02:22:30 PM »
For SOHC's, proper valve lash feeler gauges are a must have. I have used regular feelers from Autozone, but the small, tapered tip, one tool for both intake and exhaust makes the job SO much easier. https://www.ebay.com/itm/202535995281
« Reply #4 on: March 26, 2019, 03:16:59 PM »
 I love my heat gun ! Another tool I use all the time is a soft wire wheel and a cloth buffing wheel mounted on a stand.Great for cleaning bolt heads and threads and other goodies.A good vice is handy also. Chain breaker if you buy a lot of bikes to restore along with good tire spoons/levers. Assorted hammers of different sizes and materials.Brass drifts and other punches,picks and chisels are good yard sale buys. Tap and die sets are very handy to have around fixing threads. Oh the list could go on and on and on.
« Last Edit: March 26, 2019, 03:34:20 PM by ekpent »
Offline Scott S
« Reply #5 on: March 26, 2019, 04:17:20 PM »
 Well, a good socket set and screwdriver set (still need JIS.... I know) are mandatory. But these are the most used and most useful tools in my garage:
 - tiny, thin, cheap 10mm wrench.
 - scissor jack lift. Don't know how I lived without it. This and a center stand and you can completely remove the suspension on a bike
 - ratcheting handle with twist grip that spins the socket
 - ratcheting combination wrench set.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jaytee-nz
« Reply #6 on: March 26, 2019, 04:25:12 PM »
Magnet on an extendable / telescopic arm to pick up the nuts etc that you drop in to the cases (ask me how I know).
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7 on: March 26, 2019, 05:57:36 PM »
Mite-vac
Spring clip pliers
Zip top bags
Markers
Magnetic parts dish
Digital camera
Bore scope
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #8 on: March 26, 2019, 10:21:04 PM »
The Norton Project has required gratuitous use of the rubber mallet.
Offline spotty
« Reply #9 on: March 26, 2019, 10:21:20 PM »
beer fridge
i blame Terry
Offline jgger
« Reply #10 on: March 26, 2019, 10:25:13 PM »
I have given up on rubber mallets ever since I got a dead blow plastic hammer. Soooooo much nicer!
ken65
« Reply #11 on: March 27, 2019, 12:44:34 AM »
beer fridge
ha. love it.
dont forget the decals from the shops .
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #12 on: March 27, 2019, 03:42:05 AM »
I'm with you. They handle abuse much better.
« Reply #13 on: March 28, 2019, 02:43:12 PM »
 ;D
Sure.
Is it hard?
Offline Steve F
« Reply #14 on: March 28, 2019, 03:25:01 PM »
Carb sync gauges. timing light. DVM
« Reply #15 on: April 04, 2019, 05:03:33 AM »
Spark plug wrench and 10" of rubber tubing for starting spark plugs.
Also depends how deep you get into the project;  eventually you will need timing wheel, some play doh, machinist blue, lapping compound, buffer for polishing aluminum, welder, lathe.... sky is the limit  ;D ;)
« Reply #16 on: April 10, 2019, 08:18:09 PM »
....... the correct set of cir-clip pliers for a master cylinder!
Offline Kelly E
  • Geriatric Hooligan
« Reply #17 on: April 10, 2019, 11:12:22 PM »
I just used my new set of master cylinder pliers for the first time today on a crusty old original master cylinder. It was so much easier to have the right tool for the job.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #18 on: April 11, 2019, 06:00:03 AM »
Kelly ........ so true! I got my first pair of those long-nose, 90 degree pliers from Vintagecb750.com
Eventually I broke one of the tips (abuse). Now I keep a spare pair on hand....... true “must have”.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #19 on: April 11, 2019, 09:41:32 AM »
Japanese Industrial Standard (JIS) screwdrivers or driver tips. Their Phillips is different from ours.
« Reply #20 on: April 12, 2019, 04:50:20 PM »
I bought a set of JIS tips for my manual impact driver...... suddenly nothing is a problem to dismantle!
« Reply #21 on: April 12, 2019, 05:41:03 PM »
 Well fellows, took me almost 50 years, but I finally got a fab table
 30 by 48, and I love the rounded corners,
 This one won't bounce, guess how thick ?
 It cleaned up nice but I need  to fix the ends of the legs..
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #22 on: April 12, 2019, 06:22:57 PM »
Guessing 2in.
« Reply #23 on: April 12, 2019, 06:27:00 PM »
No, not that thick..
We had a round 2 Incher in the shop at one time, about - 3 ft across.
« Last Edit: April 12, 2019, 08:58:49 PM by 754 »
Offline Kelly E
« Reply #24 on: April 12, 2019, 08:47:17 PM »
I just got one recently too. Mine is not as thick as yours at 1/2"x48"x60" but it has a really good frame under it. I love being able to leave the welder ground hooked to the table, it makes it so much easier to weld little stuff. My friend drug it out of one of the barns and hauled it here from South Dakota last fall. It used to have his uncles still welded to it. 8)
1983 Honda CB 1100F
