Time for more oil leak issues!
Oil filter cover o-rings sucks or more real, blows!
I used the thickest I could find from my filters on the shelf. KN, Hi-Flo, Emgo and 2-3 different Japanese filters.
I found old threads here about leaking filter covers due to bad o-rings.
Saw the front on my CB750 K6 was sprayed with oil more than expected so I changed oil and replaced filter with o-rings.
Oil filter cover o-ring had not much stick-out over the oil filter groove and was very soft. Measured the o-ring, almost 4 mm thick, 4.5mm wide.
It should be 4.5mm thick, round, not oval. ID 89mm.
The rubber material is too soft.
I have tried to find a little bit thicker or harder with no luck.
I ordered ID 89mm x 4.5 Nitrile 70 from a bearing and seal company. I hope this will be harder than the bad o-rings the filters have. No harder version like Nitrile 90 found. 5 cost around £12.5 GBP, 50 around £17.50 GPB so 50 ordered.
I ordered also a stock Honda when ordering from DSS (before BREXIT adding customs fee this way) to have something to compare with.
It would be better with harder rubber.
I torqued the filter bolt less this time, too much will probably collapse the o-ring. I hope it will withstand the pressure.
I'll have O-rings for replacement, hopefully an improvement.
Edit: That o- ring was harder in the 80's as I can recall.
