Author Topic: Oh dear ...  (Read 80994 times)
Offline Mark1976
Re: Oh dear ...
« Reply #350 on: July 21, 2024, 09:58:36 AM »
Voltage regulator connectors.
Strip wire, push through fiber board, push through connector (original), bend wire over.
Ya gotta love the simplicity of it, the plug and play of its day...
Start with the end in mind...
Offline 69cb750
Re: Oh dear ...
« Reply #351 on: July 25, 2024, 03:58:39 AM »
Back to the way it was ...
Offline 69cb750
Re: Oh dear ...
« Reply #352 on: July 28, 2024, 05:33:32 AM »
Brake light switched not fitted before 1953 !
Adding brake light.
Offline 69cb750
Re: Oh dear ...
« Reply #353 on: August 01, 2024, 04:53:59 AM »
Spiffy key and ignition switch
Re: Oh dear ...
« Reply #354 on: August 01, 2024, 12:26:36 PM »
Does the bottom section of the bracket have a warning light ?
Online BenelliSEI
Re: Oh dear ...
« Reply #355 on: August 01, 2024, 06:52:19 PM »
Brilliantly simple. My favorite.
Offline 69cb750
Re: Oh dear ...
« Reply #356 on: August 02, 2024, 05:19:54 AM »
I've owned a lot of old bikes.
First time I've seen anything like this.
Switch attaches to frame with large shoulder bolt.
Online BenelliSEI
Re: Oh dear ...
« Reply #357 on: August 02, 2024, 05:30:37 AM »
Lots of Britsh cars are wired the same way. My 1959 Austin Healey Sprite used those connections on the regulator and almost every lamp base.
Re: Oh dear ...
« Reply #358 on: August 02, 2024, 10:20:43 AM »
I see,solid mounting point.
Offline 69cb750
Re: Oh dear ...
« Reply #359 on: August 03, 2024, 11:30:31 AM »
Lots of British cars are wired the same way.
Ye old days gone by engineering.
Offline 69cb750
Re: Oh dear ...
« Reply #360 on: August 03, 2024, 11:35:18 AM »
I reamed lifter holes to remove Nebraska rust.
I sanded lifters to remove Nebraska rust.
Holes are .001" larger then lifters.
The lifter laying on cylinder is new.
I ground .002" from lifter side to make it fit the slot like the other seven.
Offline 69cb750
Re: Oh dear ...
« Reply #361 on: August 07, 2024, 04:30:25 AM »
1 and 4 at tdc, 2 and 3 at bdc
Online BenelliSEI
Re: Oh dear ...
« Reply #362 on: August 07, 2024, 09:50:33 AM »
Great shot of a truly unique design!
Offline Mark1976
Re: Oh dear ...
« Reply #363 on: August 07, 2024, 09:55:22 AM »
   Really looking forward to the topend install...
Re: Oh dear ...
« Reply #364 on: August 08, 2024, 12:15:46 AM »
Video when running would be fine.
I'm curious how that engine will sound.
Online newday777
Re: Oh dear ...
« Reply #365 on: August 08, 2024, 12:42:56 AM »
That is a cool picture!
Online newday777
Re: Oh dear ...
« Reply #366 on: August 08, 2024, 12:53:34 AM »
As a little inspiration for you, these I took of a square 4 at Baxter Cycles, Mern Iowa, in 2016 in their back room amongst the used bikes they had and thought how cool it would be to have it.
Offline 69cb750
Re: Oh dear ...
« Reply #367 on: August 08, 2024, 07:57:41 AM »
Here ya go -
There was a project bike on ebay ten years ago.
I owned a 29 Henderson, you cannot buy anything.
Life, money, patience can run out before you get it running.
I bought books, found parts are available, many times easier.
Online newday777
Re: Oh dear ...
« Reply #368 on: August 08, 2024, 11:21:47 AM »
And another.
Sounds kinda like a SOHC/4
Offline 69cb750
Re: Oh dear ...
« Reply #369 on: August 14, 2024, 04:29:49 AM »
Valve guides are worn, waiting for parts.
Offline 69cb750
Re: Oh dear ...
« Reply #370 on: August 14, 2024, 04:30:38 AM »
Offline Mark1976
Re: Oh dear ...
« Reply #371 on: August 14, 2024, 09:43:09 AM »
It's a place to start, replacing valves as well?
Offline 69cb750
Re: Oh dear ...
« Reply #372 on: August 15, 2024, 04:27:51 AM »
Valves and seats look good, will test after guide install.
Offline 69cb750
Re: Oh dear ...
« Reply #373 on: August 21, 2024, 04:13:37 AM »
Crankshaft gears and inserts
Offline 69cb750
Re: Oh dear ...
« Reply #374 on: August 21, 2024, 04:14:24 AM »
